Moderators: VBLUE42, ducatiboy
carcrafter22 wrote:I cant get the link to work it goes to some site that says I have to purchase the info what is the bluetooth problem is it the echo in the mic and what is the fix
ducatiboy wrote:carcrafter22 wrote:I cant get the link to work it goes to some site that says I have to purchase the info what is the bluetooth problem is it the echo in the mic and what is the fix
You can get to it for free, but there is a waiting period and it's not really intuitive.
Ok, how about I'll waste some of my bandwidth:
http://www.sminntech.com/AvicBluetoothFix.zip
Note, I'm just reposting what LeonPhelps posted. I have NOT tried this yet, I have extracted the files and poked around in the iso. But I have not stuck this into my Z1 to see if it does anything. I'm not "endorsing it" just posting it on a site with "easier" downloading.
I will eventually try this with mine, but I want to do it when I have time to do the new 2 wire ground bypass.
Seems like the end of SMinntechI will post something on my site once I test this.
campinfamily wrote:Would it be a problem, if I left the "flasher" connected and than did the new bypass? I am assuming the map update in 07 will "fix" the flasher bypass as well. So I might as well fix my BT now and switch the bypass now also.
tillithz wrote:so this fix may just be a band aid for the problem as well since the update was said to already be installed on bfly's unit? Ill go try this right now and post back
Return to Problems/Troubleshooting
Users browsing this forum: No registered users and 0 guests
