Australian Map Update
Moderator: skicrave
Sponsor
Sponsor
Postby 34by151 on Sun Mar 29, 2009 10:20 am
Usual Disclaimer:
These files are for hobbyist use only. Use them at your own risk I can not be responsible for your actions if something goes wrong. Make sure you take a backup of your system prior to any changes
Contained in this release:
Test mode setup for Australia
Australian Map Update Sensis R15.1 with 3d Buildings
SUNA TMC traffic Management
Key Beep removal mod
Updated DATA.ZIP
Updated SYS.TXT
Updated Fonts
This release has been tested on the Australian AVIC-F900BT
Download files from
http://www.4shared.com/file/95580165/5b ... part1.html
http://www.4shared.com/file/95583929/2a ... part2.html
http://www.4shared.com/file/95577170/2d ... part3.html
Links:
Sensis
http://www.sensis.com.au
SUNA
http://www.sunatraffic.com.au/home.html
Key Beep Mod
http://avic411.com/forum/viewtopic.php?t=17249
DATA.ZIP
Many thanks to GTIMatt for posting his data.zip and to lacehim for the Kph version. Included in the release is the second version of lacehim's changes. For info on this data.zip see http://www.avic411.com/forum/viewtopic.php?f=34&t=23003&p=155294&hilit=risk#p155294
SYS.TXT
Many tweaks added over time, too many to list here
Fonts
I have included the fonts need by the mods contained in this release.
Test Mode
Read the AVIC411 Faq's http://avic411.com/forum/viewtopic.php?f=32&t=19170
Instructions
This update will just fit on a 1Gb SD card but it is advisable to use a SD card greater than 1Gb.
1. Start you AVIC normally and verify you have the V2 Firmware installed.
Check Pioneer website for info and download of the V2.0 Firmware and how to check you have it installed Https://www.pioneer.com.au/avicf900btDownload.aspx
2. Check your map version.
Go into Settings / Navi Settings / About / Maps
Your Maps will display Sensis R14 or similar
3. Extract this update to the root of an empty SD card. Do not modify the directory structure
4. Insert the SD card and Start the AVIC
5. Use Test mode to backup your unit. A Directory called "Backup" has been created on the SD card for your backup. Copy your "Flash Disk" to this directory
Read the AVIC411 Faq's If you are unsure on Test Mode
6. Rename or Delete the Following Directories on "My Flash Disk". I recommend you rename the directories but it's up to you.
Rename My Flash Disk\Update\APL2\iGo\CONTENT to My Flash Disk\Update\APL2\iGo\CONTENT.bak
Rename My Flash Disk\Update\APL2\iGo\LICENSE to My Flash Disk\Update\APL2\iGo\LICENSE.bak
7. If you don't want the key beep mod skip this step. Go into My Flash Disk\DATA\Sound and delete the files PSG1Hi.wav, PSG1Low.wav, PSG2Hi.wav and PSG2Low.wav. Don't worry renamed copies of these files are contained in this update. These are called 1PSG1Hi.wav, 1PSG1Low.wav, 1PSG2Hi.wav and 1PSG2Low.wav To reverse this mod later just rename the files back to normal.
8. Copy The directories below SD Card\Update to "My Flash Disk". When asked say yes to overwriting files. Copies of the overwritten Files are contained in this release. The Main Files overwritten are DATA.ZIP EZRIDER.EXE and SYS.TXT copies of the original files will be copied to you flash drive as DATA.BAK, EZRIDER.BAK and STS.BAK These are the files from The V2.0 Firmware update
9. Restart Your AVIC
10. Verify you have the new Maps
The Map will now be "Australia R15dot1 Sensis [081027]
I have held back some updates to the standard TMC Traffic, The Phoneme file and some other mods. Once these are fully tested I will release these Updates as well
34by151
Re: Australian Map Update
Postby goldfinder on Sun Mar 29, 2009 11:45 pm
Excellent post 34by151 :D Keep up the good work.
goldfinder
Postby lacehim on Mon Apr 06, 2009 1:57 am
Just got a reply from Aussie Pioneer regarding the map update in August 2009.
"The 2009 update due to be released in August will be Sensis version 15.1"
All the above by 34by151 works great on my F900BT. Thanks for all your hard work 34by151.
Kia Grand Carnival 07 - AVIC-F900BT, 2xMovies2Go 9.2" headrests, Ipod Classic 120Gb, Reverse Camera
lacehim
Postby 34by151 on Mon Apr 06, 2009 9:44 am
Thanks Guys,
I have tested the phoneme update and that will be in my next release. I have also tested the Auto/Manual tune for the TMC and am completeing the screen changes. I'm hoping to release both this weekend.
Update will have
Phoneme File added to the 15.1Maps to give proper voice prompts on some roads
GTIMatt's latest Data.zip
New TMC options added to above for Auto / Manual Tune
New TMC icons for different event types
Options to exclude event type from route recalc
Options to include TMC text with icon on map
When Manual tune is selected up /down tune buttons apper on the TMC Contol center for Tuning.
On boot tuner will find the first valid TMC signal an lock on. You can then manually tune from that point.
I have not worked out how to start on the last saved TMC station as yet but will keep working on that.
Cheers
34by151
34by151
Postby goldfinder on Tue Apr 07, 2009 10:43 am
Looking forward to the update. Something new to try. :D
goldfinder
Postby lolek74 on Fri Apr 10, 2009 1:11 pm
Really nice. Love the tweaks.
lolek74
Postby YellowLemon on Sat Apr 11, 2009 12:27 pm
How does SUNA TMS work? Do you have to register for it somewhere? What station carries the correct RDS/TMC data?
YellowLemon
Postby 34by151 on Sat Apr 11, 2009 12:37 pm
Aussie units are pre registered for SUNA however the maps don't support it. I dont' know if the V1.0 units are registered or not my unit was shipped with V2.0.
If you add my update SUNA will start working. You will see both traffic data in the control center and icons on the map.
For those of you that have PM'd and emailed me about the update I'm still working on the screen changes. I hope to get that out to everyone before the end of the long weekend
For details on SUNA and the stations see the SUNA website using the link I posted
Cheers
34by151
34by151
Postby lolek74 on Sat Apr 11, 2009 2:25 pm
My unit had 2.0 out of the box and I could see some traffic information (on the separate screen but not on the map). unfortunately I managed to delete everything (by mistake) and didnt have a chance to explore it further.
lolek74
Postby 34by151 on Sun Apr 12, 2009 6:26 am
In the traffic events screen press one of the events and it will take you to the event on the map.
34by151
Postby 34by151 on Sun Apr 12, 2009 6:42 am
Updated Release
Usual Disclaimer:
* Phoneme File added to the 15.1Maps to give proper voice prompts on some roads
* GTIMatt's latest Data.zip (09 Apr)
* Swapped the position of the Delete Route and Voice Mute buttons
* New TMC options added to above for Auto / Manual Tune
* New manual tune buttons, press for 0.1mhz change, long press seek next station
Held back , still testing
* New TMC icons for different event types
* Options to exclude event type from route recalc
* Options to include TMC text with icon on map
* sys.txt Variable to set Tuner start mode
Download files from:
http://www.4shared.com/file/98059420/fd ... date1.html
Instructions:
1. Download files
2. Extract to the SD card overwriting files from the first release
3. Follow the instructions from the first release
Cheers
34by151
34by151
Postby lolek74 on Sun Apr 12, 2009 8:11 am
Great work. Thank you for that. I'll give it a try later on. Any plans for the future relases?
lolek74
Postby YellowLemon on Sun Apr 12, 2009 4:45 pm
Thanks mate! Legend!! :P
I don't have an AVIC F series yet but I want to get one...... could someone order a 900BT or 90BT from the US for a lot cheaper and put these maps on?
If yes, how would one then register a US unit for SUNA?
Ta!
PS SUNA is now being broadcast over 101.1FM in Melbourne and 97.3FM in Brisbane and on 106.5FM in Sydney.
YellowLemon
Postby 34by151 on Mon Apr 13, 2009 2:19 am
I have Updated the DATA.zip file
Added the TMC and signal status to the menu.
This will show
* Testing when you fin a new station
* No TMC signal id the station does not have TMC
* TMC Present if a TMC data is found
* TMC data type and key if TMC is found and locked on
Screen Pic Here
http://www.4shared.com/file/98207775/97213a46/tmc.html
download the new data.zip here
http://www.4shared.com/file/98207724/9d51fe95/DATA.html
Cheers
34by151
(70.79 KiB) Downloaded 754 times
34by151
Postby YellowLemon on Mon Apr 13, 2009 6:46 am
Thanks heaps for this, 34by151 !!!
Would you please be able to start a CHANGELOG or readme.txt so that user who would like
to use other data.zip mods in the future know what the differences are?
(say for example someone wanted to use a data.zip from another modder than GTIMatt...)
YellowLemon
Next
Return to Hacks/Mods: F-Series
Who is online
Users browsing this forum: Google [Bot], Marlysa and 10 guests
