F900BT GPS Antenna install and metal sheet
Moderator: skicrave
Sponsor
Sponsor
Postby ghostdunks on Mon Jul 13, 2009 8:18 am
Is it that big a deal if when I'm installing the GPS antenna that I don't use the sticky metal sheet? I've found a good spot for the GPS antenna in the OEM location for my car, fits snugly there, but won't fit the square of metal underneath it.
In the install manual, it says if installing the antenna inside the car to always use the metal sheet otherwise it'll affect the sensitivity of the GPS antenna....and not to cut the sheet into smaller pieces either..,..is it that much of a deal?
ghostdunks
Re: F900BT GPS Antenna install and metal sheet
Postby skippy2 on Mon Jul 13, 2009 8:57 am
Without going into too much detail... yes, it is important in antenna design to define a ground plane. On the other hand.. some GPS antenna have a build in magnet to prevent it from moving around. I don't know if the Pioneer antenna has a magnetic base BTW, I didn't install the unit myself. So suppose this antenna needs a metal plane to have optimal performance. The minimal size does matter, larger metal sheets normally have positive or no influence.
Do you have to use the supplied sheet? Not when the location you plan to go for is a metal construction part of the car, I'am inclined to say. And since this is the location the car manufacturer has 'designed' to be used for a GPS antenna, it might well be a metal base with no (or little metal) in the field of view of the antenna.
The practical approach.... Find a place with relatively little or no structural blocks (buildings) that could interfere with receiption, attach the antenna (with the supplied sheet if no metal base is present) and look at the GPS signal strength page. Then remove the metal sheet, place the antenna in the intended mounting location and see if receiption changes significantly. Remember that the GPS sats are constantly 'on the move' so changes in signal strength will always be present and use as little time as possible when moving the antenna.
skippy2
Postby venusfan on Mon Jul 13, 2009 3:32 pm
well that metal sheet suppied with my unit was too big so i cut it to the size of the antenna and place it on my dash.. No problem from it so far so knock on wood.
venusfan
Postby bloodninja on Mon Jul 13, 2009 3:50 pm
You definitely do not need the metal sheet. Just try to make sure that the surface you're attaching the gps to (super powerful magnet) is relatively flat. I don't use the sheet, and I always connect to 14 or so sattellites with a "green" connection in under a minute, so I'd assume it's just fine.
User avatar
bloodninja
Postby noxguy83 on Mon Jul 13, 2009 3:53 pm
No you dont really need tou use the sheet. If ou mount it to metal you will get slightyly better reception. in my vehicle I didnt want the antenna on the dash or visible so i used a piece of double sided tape and centered in in the top middle of my windshield above my mirror.(inside the vehicle) works just fine with high accuracy all the time.
noxguy83
Postby Egz on Mon Jul 13, 2009 4:32 pm
Mine is installed on my rear deck, with the magnet holding it to the metal deck, and which the fabric cover on top, and I get great reception. I didn't need to use the supplied metal.
Egz
Postby ghostdunks on Tue Jul 14, 2009 12:58 am
Thanks for the replies everyone, that makes me feel a bit better about not using the metal sheet if I can't fit it in. The Pioneer antenna definitely has a magnetic base, just wasn't sure if I HAD to attach it to something metal.
Actually, the OEM spot(R171 SLK) for the antenna is right above the rear-view mirror and there's no metal base for the antenna to attach to, just so happens that the fit is snug enough that I can just jam the Pioneer antenna in there and once I put the rear-view mirror assembly back on, there's no way that sucker's moving anywhere. Once its in there, the only thing between the antenna and outside is the windshield so it should be pretty good reception. If I get a chance, I'll try the practical test and see if adding the metal sheet underneath the antenna improves reception or not.
ghostdunks
2000 per day of income and no big huge starting capital
Postby WoolveWed on Sat Nov 07, 2009 7:49 am
Good day, sun shines!
There have been times of hardship when I didn't know about opportunities of getting high yields on investments. I was a dump and downright pessimistic person.
I have never imagined that there weren't any need in big starting capital.
Nowadays, I feel good, I started to get real money.
It's all about how to select a proper partner who utilizes your funds in a right way - that is incorporate it in real business, parts and divides the income with me.
You may get interested, if there are such firms? I have to tell the truth, YES, there are. Please be informed of one of them:
http://legalmoneynow.info
User avatar
WoolveWed
Return to General: F-Series
Who is online
Users browsing this forum: RPERRY1019 and 0 guests
