Moderator: skicrave
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000 3dcarsizemin=5000
3dcarsizemax=8000
3dcarsizemul=30000
car_day=hot_rod_red.mdl
car_night=hot_rod_red.mdl
ghost_day=hot_rod_red.mdl
ghost_night=hot_rod_red.mdlmisterblue wrote:hi IDT, in this version the demo mode option is enable (TMC version) ?
mtulbert wrote:IDT,
Great mod....You are amazing. One small bug that I found is in the custom settings menu. I get an error message and I think it is because it is trying to find the fade option and it is not there. It is not a biggy by any means, just thought you would want to know.
Regards,
M
ill.die.trying wrote:misterblue wrote:hi IDT, in this version the demo mode option is enable (TMC version) ?
yes, i think the bug that you brought up is still there, haven't had a chance to work on it yet but for sure i'll include it on the next update,
i've got a question though, as far as i know the use for the demo mode is for display purpose, not sure why your using it but if you're using it to do a simulation then i suggest you click the simulation or the flyover on the route info screen,
misterblue wrote:ill.die.trying wrote:misterblue wrote:hi IDT, in this version the demo mode option is enable (TMC version) ?
I actually do like this but it is not possible to accelerate the simulation speed.
You still did great job
I have a question: this version of mod V3.0 is the successor of version 3.0Final "skin1? Will you continue to update the version 3.0Final "skin1" because I like the skin of this version here. In your new version I find there is too much information at once.
ovalball wrote:Hi Julius,
On the Eu version(not alternative)the speed limit signs are showing twice,one above the other.This happens on both the emulator and the avic.Thanks.
ill.die.trying wrote:ovalball wrote:Hi Julius,
FIXED, link updated
Can you do anything about the number not being in the middle of the roundabout symbol.ie the exit number that is inside the symbol of the roundabout(don't know what they are called in the states)I know you fixed this before in IDT skin 1.I know it's a bit trivial but it does spoil the otherwise excellent appearance.TIA.PS it appears to be i only in the next turn icon not the primary one. (the small one)
Return to Hacks/Mods: F-Series
Users browsing this forum: Google Adsense [Bot], maddog hoek, nipLVII, Yahoo [Bot] and 8 guests
