Z110bt installed... Not fully functionable
Moderators: ducatiboy, VBLUE42
Sponsor
Sponsor
Postby Mw350z on Fri Nov 06, 2009 8:18 pm
2008 350z non bose
Yes! I have searched... No luck! I just installed my new z110bt and I couldn't get the mute wire out without hacking up the harness to much. So I used extra VSS wire to attempt the video bypass. So my problem is the volume controls and the rear speakers aren't working. Yes! I pulled it out and check all the connections. I was using a guide on a 350z forum do my install and they had 3 grounds one was the green parking break(check) and the Black ground(check) and I did the by pass so I had a third on the same as the parking brake ground.(check) so I am wondering if that third ground could be throwIng the ATT? I have tried the turning off the AV and going to setting and turning off the mute, still no luck! Should un ground the 3rd ground? I am hoping you guys can help me before I decide to take it to a stereo place to fix it.
Thanks Marcus
Mw350z
Re: Z110bt installed... Not fully functionable
Postby CamelTowing on Sat Nov 07, 2009 3:10 am
What did you connect this "extra vss wire" to?
User avatar
CamelTowing
1000 Club
Postby Mw350z on Sat Nov 07, 2009 5:05 am
I have it ground to a bolt the hold the dash kit together it was the same one the guide I got had theres grounded to its also the same bolt I have the parking brake wire grounded. Should I undo that ground and leave the Parking brake. Also finding after my frist post, My gauges are lite but not working any knowledge about that promblem. I have have something about it being directly connected to my AC controls. which has a VSS wire I spliced in to.
Mw350z
Postby VBLUE42 on Sat Nov 07, 2009 5:48 am
WHAT!!!
2008 CIVIC COUPE EX, AVIC Z110BT, XM, IPOD 160GB, IPHONE 3G, INFINITY 62.9i COAX SPEAKERS FRONT & REAR, JL AUDIO SEALED POWER WEDGE 12" TMA BASS PAK, SMITH & WESSON.
I'm a Mac, you're a PC!!! 8-)
User avatar
VBLUE42
1000 Club
Postby Mw350z on Sat Nov 07, 2009 6:42 am
My z110bt is permently in ATT and I cant change the volume or get it off ATT. I couldnt pull the pin out, So I took some extra VSS wire and filled the pin location that the by pass is moved to instead of the mute wire. I grounded that and the Brake lead to a bolt on the left side under my AC control box and the black ground to the right side.
below
http://www.350z-tech.com/w/images/f/fa/DVD009.jpg
Also in doing the install some how I caused the gauges to not work beside the back lights. And doing some research I have found that the AC unit is directly connected to the gauges. The only thing that involves the AC controls is the VSS wire splice. I dont know what happen I am hoping its something simple like a connector is not connected. VBLUE got anything? THANKS
Mw350z
Postby Mw350z on Sat Nov 07, 2009 6:53 am
I believe my gauge problem is one of two 1. Fuse I just dont know which one 2. connection to AC controls
Mw350z
Postby CamelTowing on Sat Nov 07, 2009 8:13 am
Did you ground the mute wire too?
User avatar
CamelTowing
1000 Club
Postby Mw350z on Sat Nov 07, 2009 7:08 pm
Not the black/Yellow one just the extra VSS wire in the by pass pin location. and the parking brake. of couse the ground.
Mw350z
Postby CamelTowing on Sat Nov 07, 2009 8:17 pm
Did you leave the plastic cover on the mute wire, or could it be touching any metal?
User avatar
CamelTowing
1000 Club
Postby Mw350z on Sun Nov 08, 2009 12:02 am
There was a plastic cover on the metal clip on the end It might be touching the back of the unit. Could the wire be causing the mute to permently on? I have to pull it apart again any ways I got a HD unit separatly that gets here on Monday plus I am still having a problem with my gauges. No fuses were blown so it mass to be a connector.
Mw350z
Postby CamelTowing on Sun Nov 08, 2009 12:45 am
If you have to pull it out again anyway, go to Fry's, radio shack, home depot, etc and spend a dollar or two on a flat head eyeglass screwdriver and do the bypass the right way. Will establish if the mute wire is causing the muting problems or not
User avatar
CamelTowing
1000 Club
Postby Mw350z on Sun Nov 08, 2009 3:32 am
Yeah I am going to do the by pass the right now and hopefully that fixes that problem now I am still stuck with out gauges hopefully I will get it all figured put the third time around now. Thanks so much
Mw350z
Postby gixxer on Mon Nov 09, 2009 2:49 am
subscribed, having the same problem with my '08 f150. let me know if this helps you.
User avatar
gixxer
Postby Mw350z on Mon Nov 09, 2009 5:13 am
I fixed the gauges that's as simple as I didn't fullly connect the air control box and it came loose during reinstallsation. I will diffenently do that.
Mw350z
Postby Mw350z on Mon Nov 09, 2009 7:47 pm
DONE!!!! You have to do the by pass the correct way for the Mute to turn off. Thanks everyone for the help!
Mw350z
Return to Problems/Troubleshooting
Who is online
Users browsing this forum: No registered users and 0 guests
