VSS and Reverse wire for a 2004 Ford F150 Supercrew?
Use this forum to discuss wiring locations for your vehicle.
Sponsor
Sponsor
Postby jlhunter2008 on Sat Sep 01, 2007 3:48 am
Does anyone know where they are, and the colors of them. Thanks in advance.
jlhunter2008
Postby MisFit on Sat Sep 01, 2007 11:49 am
Reverse Light black/pink + DKP, gray plug, pin 13
Speed Sense gray/black radio harness
User avatar
MisFit
1000 Club
Postby jlhunter2008 on Sat Sep 01, 2007 3:28 pm
Where is the Reverse Light black/pink + DKP, gray plug, pin 13 located and what does DKP mean?
jlhunter2008
Postby MisFit on Sat Sep 01, 2007 3:58 pm
drivers kick panel
User avatar
MisFit
1000 Club
Postby big-fokker on Thu Mar 13, 2008 2:14 am
So do I need to run a jumper from the head unit to the kick panel to get to the reverse wire?
Do I connect the emerg brake wire as well?
big-fokker
Postby xoliex on Fri Mar 21, 2008 5:11 am
i'll be interested to know this as well because because when you buy the camera, the box needs that reverse signal as well, BUT the d3 also needs the reverse signal. so i guess i run a jumper wire from the kick panel and tap it into both of those wires!
xoliex
Return to Vehicle Specific Wiring
Who is online
Users browsing this forum: No registered users and 0 guests
