  • entries
    10
  • comments
    19
  • views
    98,670
Condi's HACKMODE v1.1 - windows explorer!; SD/USB and AUTOUPDATE feature!
JasonH
Pioneer AVIC HACKMODE by Condi
Finally we've got full access to new Pioneer units!
After many tries, many scripts, I think that
its proper state to be released.
SO FAR CONFIRMED TO WORK ON:
  • F30BT (tested by me ;) )
  • X920BT (thanks to Krms!)
  • X930BT (thanks to Ralpharn!)
  • Z110BT with Z120BT firmware (thanks to PatrickFernandes!)
  • F920BT (thanks to Tudor Z!)
  • F20BT (thanks to wikke!)
I'm not responsible of any damage/brick,
so all of this you are doing at your own risk.
Its working on my unit perfectly,
but its not 100% sure that it will work on yours!
FOR EDUCATIONAL PURPOSES ONLY!
THERE IS NONE OF PIONEER SOFTWARE INCLUDED,
THIS 'HACK' IS MADE WITH FREE SOFTWARE,
= NO COPYRIGHTS ARE BROKEN!
On the new units standard testmode with windows explorer
is not working. Funny is, that on the newer units
there is no even explorer.exe ;)
Fortunately we've got GGS1080 with TESTMODE.KEY,
which is working on F30BT, and other units also, I think.
But plain Pioneers Service Mode is not handy and 'usable' for us.
To hack Pioneer device I used Pioneers 'service mode'.
OK, so everything what we will need is in the attachment.
Below are detailed instructions, but in few words
we need to delete Av.exe, and copy hackfiles to its place.
Source: Condi's HACKMODE v1.1 - windows explorer!; SD/USB and AUTOUPDATE feature! [updated: 08.05.2011]
3 Comments
Recommended Comments
Hey Condi excelent work here! I've tried this on my Z120BT and was able to follow your steps, however, I am not able to copy and paste USER file to the SD card. The selection is greyed out, unless I open USER and select all then copy. But when I move back to SD it will not copy to the root of SD even after the unit says that it is pasting the files. I have even made a "save file" folder on the SD to save to and it still didn't work. Am I missing a step or has Pioneer put a block on this?
Link to comment
Add a comment...
