D3 Bypass Problem
Hey guys,
I finished installing my D3 with no problems at all. EXCEPT ONE.
The bypass that I got from AVCI411 is not working for me and I'm 100% positive I did it correctly
The steps I took were as follows:
1. Remove yellow mute wire from harness and place it one spot directly above.
2. Ground both Parking Brake Wire and MUTE wire.
But unfortunately its still not working. I heard something about installing a TOGGLE SWITCH but I couldnt find anything on this site through the SEARCH.
Anybody know about this toggle switch, if so, can you let me know where to connect it?...
THANK YOU
You don't need a toggle switch, you just did something wrong. Double check your grounds are solid, double check that the wire you moved is firmly seated in the hole and making good contact with the pin, etc.
There are literally thousands of these done exactly the way described, and they all work fine
  • 1 month later...
I have not found a need to bypass yet. However, if I end up moving my iPOD location and I am already back there, I may as well do it. I am now just starting to play with the custom backgrounds. I matched my button colors quite easily.
Bluetooth is workin' like a charm.
