GnatGoSplat Posted May 22, 2007 Report Share Posted May 22, 2007 Sounds to me like your N1's touch-panel or controlling electronics has become so degraded and so far out of spec that even a recalibration can't fix it. Quote Link to post Share on other sites
MAJALO22 Posted May 27, 2007 Report Share Posted May 27, 2007 The recalibration instructions above worked for me...to an extent. One of the options after the two used to recalibrate the touch panel is to test the touch panel. It shows a small "+" symbol every time you touch the screen so you can verify the calibration. After recalibrating, the touch area worked great apart from the bottom half of the right most 1/2" of the screen (if that makes sense) where no touch would register at all. I tried recalibrating a few times using differnt methods (finger, nail, stylus...) but all with the same results. I have a feeling recalibration will work up until a point where there may actually be a physical/electrical problem with the unit (mine is ~2yrs old D1). ...figured that [i]may [/i]help someone out there Quote Link to post Share on other sites
petershin_95 Posted July 6, 2007 Report Share Posted July 6, 2007 Avic n1 is crap.... i have the same problem, and i recalibrated my screen a several times just now and no change..... why dont they have a re-call on this problem? seems like everyone has the problem but no one knows how to fix it.... Quote Link to post Share on other sites
fieldsinv Posted July 12, 2007 Report Share Posted July 12, 2007 Follow the instructions by REMIX2112 posted Nov 2006. I just did it today and it works. I learned that all you have to do is press (EQ) button and then (BAND) to go back in the menu on the N1. If you are off calibration alot, I found that all need to do is not trace the outer white line. Just place your pointer a cm from the side. I just used a pointer once at the bottom and once at the top. The values changed ok. **It took me 3 times to figure it out.** Thanks Remix2112 Quote Link to post Share on other sites
ohlarikd Posted July 19, 2007 Report Share Posted July 19, 2007 Also followed instructions for D1, got into menu - thanks! Calibration had varying degrees of success - I noticed if you do it several times, you get different results, especially on the right side. But it did improve, and I think with some more effort, I can get it close to working again (I have issues on the right side of the screen being way off). Hopefully I can get it close enough to adjust my EQ settings again! Derek Quote Link to post Share on other sites
Aconite Posted July 25, 2007 Report Share Posted July 25, 2007 I HAVE NOT TRIED THIS and not sure if I want to I tried calibrating a couple of times on my D1 but there was no improvement with the right side of the screen. When tracing the white line, perhaps use a stylus and using the edging of the screen for support, trace about 1/8 to 1/4 inside the white line. I am thinking this may trick the unit into thinking that this is where the edge of the screen is and maybe fix some of the +/- issues. Or maybe trace the white line properly on the top/bottom/left of the screen but trace it 1/4" inside on the right side of the screen and continue with calibration as normal. Quote Link to post Share on other sites
popokrew Posted January 8, 2009 Report Share Posted January 8, 2009 I know this is an old post but I found it while trying to troubleshoot the screen calibration. For whatever reason, I cant "back" out of any screen. I see that its supposed to be the "band" button but that doesnt work. Then I saw that someone say to press EQ then band but that doesnt work either. Does anyone have any other ideas? Thanks! Quote Link to post Share on other sites
popokrew Posted January 8, 2009 Report Share Posted January 8, 2009 [quote name="popokrew"]I know this is an old post but I found it while trying to troubleshoot the screen calibration. For whatever reason, I cant "back" out of any screen. I see that its supposed to be the "band" button but that doesnt work. Then I saw that someone say to press EQ then band but that doesnt work either. Does anyone have any other ideas? Thanks![/quote] OK well I fixed my own issue and I wanted to post it so everyone knows what happened and what to do. I have a N1 HU with a N3 brain. After finding this post: [url=http://avic411.com/forum/viewtopic.php?t=16364]http://avic411.com/forum/viewtopic.php?t=16364[/url] I plugged my N1 brain back in, did the recalibration and was able to use the "band" button to go back in the menu at the appropriate times. My calibration was off about 1/2 in on each side and it really bothered me. I dont think Pioneer recalibrated the screen when I sent it back for the flex cable recall. Anyways, I hoped this helps other people. Quote Link to post Share on other sites
whitecivic Posted August 28, 2009 Report Share Posted August 28, 2009 i am not able to get into the main screen with the up up down down in on the joystick. can anyone help. i can get the reset with eject thing to make the screen retract and open again saying hit reset and i do then when i try the up up down down in thing i get nothing but the main menu pop up with inital settings screen. any help would be great. i need to start using this thing again and then maybe upgrade soon. Quote Link to post Share on other sites
carmike Posted March 3, 2010 Report Share Posted March 3, 2010 same as above poster^ Are we supposed to reset after hitting up down up down crap? Quote Link to post Share on other sites
ryan420 Posted March 3, 2010 Report Share Posted March 3, 2010 I have recalibrated my d1 with the service menu, you need to stay about a 1/4 inch away from the side of the screen.. what i did was used a bic pen cap and notched it a 1/4 inch away and ran it down the sides of the screen and then back out to the service menu and continued along with the setup..Very easy to do.. I will post some pic of the menu's i used to do this Quote Link to post Share on other sites
myclock187 Posted June 25, 2013 Report Share Posted June 25, 2013 I'm going to revive this thread... I've had my N1 since 2003 (maybe that's the problem right there) and the only problems i'm having is exactly what everyone else has been dealing with: The calibration is off especially on the left side of the screen and the +/- buttons aren't working. I've tried recalibrating 50+ times in the service menu following what everyone on the internet has ever posted about it and I still have had no luck. This past weekend while tracing the white lines around the edge I got it to say in blue letters, "values okay" or something like that and I got all excited because it was like my 30th time trying it and then step 2 wouldn't work and I couldn't back out with the band button so I had to reset and now after 30 more tries it just says in red, "invalid by the outside of a permissible value". I'm so frustrated. Nowadays I don't use it for Navigation because my android phone is much better, but I do have a backup camera and an ipod(audio) cable that would be nice to use but the settings in the menu for those items are on the left side of the screen and I can't access them! I wish Pioneer would have designed the stupid thing to work by selecting items with the freaking JOYSTICK that it has and not just rely on touch. I am basically reviving this thread because i'm sure some people still are having this issue and it'd be nice if someone has some answers. It'd be nice if someone could go into their service menu and see what permissible X/Y values are so I can just trace the screen paying attention to the values to try to get them into permissible range. Anyways, hopefully something comes of this. Quote Link to post Share on other sites
Join the conversation
