GTI Chooch Posted June 16, 2008 Report Share Posted June 16, 2008 I'm starting to think I should look into upgrading to VW's new RNS-510 unit they'll be using in the 2009 models. At least then I can keep my MFI functionality. the prices that I've seen for the RNS-510 are quite a bit higher than the F series. Plus the 510 doesn't have voice recognition or USB input (not without an adapter)....and I'd like to compare the sound quality... Link to post Share on other sites
omniphonix Posted June 16, 2008 Report Share Posted June 16, 2008 I'm starting to think I should look into upgrading to VW's new RNS-510 unit they'll be using in the 2009 models. At least then I can keep my MFI functionality. the prices that I've seen for the RNS-510 are quite a bit higher than the F series. Plus the 510 doesn't have voice recognition or USB input (not without an adapter)....and I'd like to compare the sound quality... Rumor has it a retrofit kit is in the works with a target price ~$2,000. Plan is to add the MDI for iPod/USB as well, but will likely use SD most of the time. Voice input is not that big a deal for me and the F-series can't voice-input nav destinations anyway which is what I would want it to do most. Trick will be to find the proper Bluetooth module and not try to jerry-rig that Skoda thingy. Link to post Share on other sites
doughboy04690 Posted June 17, 2008 Report Share Posted June 17, 2008 I have a 2005 Porsche Cayenne and was wondering if this could possibly integrate with the existing steering wheel controls I have now? Link to post Share on other sites
septicdeath Posted June 17, 2008 Report Share Posted June 17, 2008 Okay, I just read all the threads here (I didn't search elsewhere yet, so sorry if its there) BUT WE all know Pioneer has ISSUES with loop noise and interference on the RCA outputs, its so bad, some have actually used Speaker out to line level convertors to get clean signals to their amps. I actually took the time to solder ground leads to each of the RCA output barrels, and connected the cross connects them to a common ground on the frame of my z1 to help get rid of it, anyone have any comments on this yet? Thanks in advance. Septic Link to post Share on other sites
BlackBear Posted June 18, 2008 Report Share Posted June 18, 2008 What's the difference between F90BT and F900BT? As far as I can tell there are only three: 1. Pre-out are 2v lower on F900BT 2. Price is $300 lower on F900BT 3. Warranty one year on F900BT, two years on F90BT Both support MSN Traffic! Am I missing anything? Link to post Share on other sites
VBLUE42 Posted June 18, 2008 Report Share Posted June 18, 2008 Ipod cable comes with the 90. Link to post Share on other sites
qkslvr Posted June 18, 2008 Report Share Posted June 18, 2008 F90BT also has 3d landmarks. Link to post Share on other sites
psklenar Posted June 18, 2008 Report Share Posted June 18, 2008 And the price difference between the 900 & 90 is only $100, not $300. pat---- Link to post Share on other sites
bwolfe Posted June 19, 2008 Report Share Posted June 19, 2008 Does the F-Series support the multi-CD player? I saw no reference in the manual to this. Link to post Share on other sites
yoshi86 Posted June 19, 2008 Report Share Posted June 19, 2008 do anyone know if theres a bypass yet or if the one for the d3 will work? Link to post Share on other sites
rapchainz Posted June 19, 2008 Report Share Posted June 19, 2008 there is one available. search the forums Link to post Share on other sites
lordvdr Posted June 19, 2008 Report Share Posted June 19, 2008 The 90BT includes the Pioneer iPod cable, according to Pioneer What's the difference between F90BT and F900BT? As far as I can tell there are only three: 1. Pre-out are 2v lower on F900BT 2. Price is $300 lower on F900BT 3. Warranty one year on F900BT, two years on F90BT Both support MSN Traffic! Am I missing anything? Link to post Share on other sites
bronson96792 Posted June 21, 2008 Report Share Posted June 21, 2008 the pics look sweet cant wait to get one Link to post Share on other sites
lordvdr Posted June 21, 2008 Report Share Posted June 21, 2008 While waiting for my dealer to get the 900BT in stock I had a chance to play with the 700BT and it appears that the nav data is no more current than what Pioneer released last year. There's still a few streets in my area that were completed Mar 2007 that still aren't showing up. Link to post Share on other sites
HiFiSi Posted June 22, 2008 Report Share Posted June 22, 2008 While waiting for my dealer to get the 900BT in stock I had a chance to play with the 700BT and it appears that the nav data is no more current than what Pioneer released last year. There's still a few streets in my area that were completed Mar 2007 that still aren't showing up. That may be true. But with these new units, you can update the map data with a flash card or USB drive, so it will be a lot easier to update the database when Pioneer releases it. You won't have to buy a $250 update disk. Link to post Share on other sites
