AVIC "F" Series Bypass
From WIRE SIDE of small white plug
Mute wire (YEL/BLK) is in upper row, left pin
Move this wire to lower row, 4th pin from the left (empty pin between 2 black wires)
the pin directly below the mute wire does not work
Ground YEL/BLK & LT GRN and you're good to go
You're welcome...
  • Replies 275
Does this unit has video playback option from the SD card or something ? It will not play video from dvd format so not sure what the by pass is for.
video from the pioneer/ipod video cable
there is no dvd drive so you get no dvd video (buy the F90BT)
you need to bypass it to use the nav menus without pulling the parking brake
Yea but 15 minutes later it may do something different. This happened a lot when the bypass for the D3 and Z series was being discovered. Not to doubt you but were just looking for a little more verification. Thanks for the input though.
You're welcome...
Thanks chris!
I'll try it tomorrow and post back to confirm it works in another unit.
AVIC-F700BT :o:o
