dianebrat Posted June 26, 2011 Report Share Posted June 26, 2011 - From the "men of few words" dept? Quote Link to post Share on other sites
Pogigreg Posted August 24, 2011 Report Share Posted August 24, 2011 Quote Link to post Share on other sites
providers Posted October 11, 2011 Report Share Posted October 11, 2011 Hi I just bought a AVIC-F30BT, how do I bypass it? My car has a can bus adaptor (Skoda SuperB) If I look in post 1, I should move the mute wire, my problem is the myte wire in this radio is in pen 1 and not 2 and the place where it should be moved to, there is allready a wire. And the hand brake wire goes into the canbus adaptor. Should I cut the handbrake wire from canbus adaptor and then ground the handbrake wire from the radio? hope you guys can help me out Best regards Providers Quote Link to post Share on other sites
jurjur Posted January 29, 2013 Report Share Posted January 29, 2013 Hi all... i read every post about software bypass.... but i don't know how to do it. i can get into testmode and i copied USER folder and NDATA folder to SD, i search DATA.ZIP file but i can`t find it. Please, i need help about that. I've got an AVIC-F840BT, fw ver 4.001.... on a Golf MKV with DSG... i can play videos without handbrake, but when the car reaches about 10km/h the warning message appears. Thank u. Quote Link to post Share on other sites
marchammer1987 Posted February 23, 2013 Report Share Posted February 23, 2013 I have the exact same problem. Can't find DATA.ZIP file in any of the folders. I have an AVIC-F9220BT. Quote Link to post Share on other sites
pod Posted February 26, 2013 Report Share Posted February 26, 2013 hi, i'm about to receive a HU F40BT. is this method work on it ? i'm newbie... thanks Quote Link to post Share on other sites
marchammer1987 Posted February 26, 2013 Report Share Posted February 26, 2013 I have the exact same problem. Can't find DATA.ZIP file in any of the folders. I have an AVIC-F9220BT. The reason why some of you (including my self) can't find the DATA.ZIP file is that it is only on units with Igo navigation. In my case (AVIC-F9220BT) the navigation is Pioneer's own navigation software. Quote Link to post Share on other sites
limskey Posted October 7, 2013 Report Share Posted October 7, 2013 Hello, I know this is an old post however, I'm a newbie to this stuff with the Pioneer head units. I recently bought an AVIC-X4500BT. Will moving the mute wire from row 1 and pin 1 to 2nd row, pin 4 work for this model? also, does anyone know if there are hacks/mods i can do for this model? i'm hearing not much for the AVIC model but just wanted to check with you all. Quote Link to post Share on other sites
Travolta Posted October 11, 2013 Report Share Posted October 11, 2013 Look here Quote Link to post Share on other sites
Beastaudio81 Posted November 7, 2013 Report Share Posted November 7, 2013 Thanks for this thread! Quote Link to post Share on other sites
abb1 Posted November 18, 2013 Report Share Posted November 18, 2013 I have been away from this forum for a long time. Can anyone confirm that this is the same bypass for the X950BT? Quote Link to post Share on other sites
eden Posted December 28, 2013 Report Share Posted December 28, 2013 Hallo, for what is this bypass ? Thnx Quote Link to post Share on other sites
madsonp Posted January 19, 2014 Report Share Posted January 19, 2014 I have a F90BT and had done the hard wire bypass on my system that worked fine. Recently the stereo froze up on me so I sent it in to get it repaired which involved getting the navigation board replaced. The outfit I sent it into also took it upon themselves to up-grade the maps in my system while they were at it. When I got it back, the bypass no longer worked, so I uninstalled the maps they put on it and reinstalled the maps I originally had on it and now the bypass works fine again, If anyone else has done the hard wire bypass and have everything hooked up correctly and it's still not working correctly you may have to do the software bypass for it to work if you have the newer maps on it. Quote Link to post Share on other sites
madsonp Posted January 19, 2014 Report Share Posted January 19, 2014 Hallo, for what is this bypass ? Thnx Read the first part of this thread. Quote Link to post Share on other sites
Weby Posted March 5, 2014 Report Share Posted March 5, 2014 I have a small question. I own a F940BT, and there is a possibility to disable this security via OSD. Is there any reason to do this bypass, besides the fact that this is illegal in my (like most) country ? Do I only gain the possibility of watching some videos while driving ? Thank you for your replies. Quote Link to post Share on other sites
