In adition, you also have to set it to automatic to switch automatically...
To improve the visibility of the map during the
evening, you can set the timing for changing the
combination of the map colour.
1 Touch [Map] in the navigation menu.
2 Touch [Day/Night Display] to change the
setting.
Each time you touch the key changes that setting.
Automatic*:
You can change the colours of a map between
daytime and nighttime according to whether
the vehicle lights are On or Off.
Day:
The map is always displayed with daytime colours.
❒ To use this function with [Automatic], the
Orange/white lead of the navigation system
must be connected correctly.
❒ You can also change the brightness of the
screen between daytime and nighttime
with [Dimmer].
➲ “Operating the picture adjustment†➞
Page 142
P.S. in the hardware menu, you can see if the illumination wire is hooked up and working without having to pull the unit out.....
