eldeep Posted November 2, 2009 Report Share Posted November 2, 2009 Start testmode or via - leetlauncher - applications - windows explorer - start - settings - control panel -and change usbclient to serial,, Now you should have connection as a windowsCE device and copy d/elete all you want,, hope this helps, PS: I have my Ipod or HD 160 Gb connected via USB to the f500 with a lot of music and videos and is working perfect,, look for topics in this forum for harddrives,, Good luck Quote Link to post Share on other sites
nastyplasty Posted November 2, 2009 Report Share Posted November 2, 2009 Thanks for the fast answer, eldeep. I will try the USB client switching solution you mention. Quote Link to post Share on other sites
eldeep Posted November 2, 2009 Report Share Posted November 2, 2009 Be sure you have a copy of the testmode on a SD card,, if not,, via USB you cannot boot,, You can find testmode on this forum,, Good luck Quote Link to post Share on other sites
nastyplasty Posted November 2, 2009 Report Share Posted November 2, 2009 Thanks for the advice, By the way, in my f500bt, leetlauncher boots from the USB and then hangs (I have not found any info on Leetlauncher running from an USB, maybe I am doing something wrong or it is not possible). I have also found test mode USB version but have not tested it yet. I will check if USB booting is possible first (I'd rather not removing the dashboard, screws, etc. to reach the Sd card I have at present just in case I introduce some noises in the dashboard). If it does not work, I will have to install testmode in the Sd card, but then I would boot always in test mode.... Will keep you informed. Quote Link to post Share on other sites
nastyplasty Posted November 4, 2009 Report Share Posted November 4, 2009 Good night, I have just tested the testmode 2.3 USB version and it boots from the USB stick without any problems. This way I can access the card and move files. It is a good solution. Anyway, this still makes me wonder wether Leetlauncher can boot completely from a USB stick. This could make possible to insert the USB stick everytime I wanted to use leetlauncher (as most people in this forum have been doing with the SD card). Will keep you informed. Quote Link to post Share on other sites
FourG Posted November 5, 2009 Report Share Posted November 5, 2009 Anyway, this still makes me wonder wether Leetlauncher can boot completely from a USB stick. This could make possible to insert the USB stick everytime I wanted to use leetlauncher (as most people in this forum have been doing with the SD card). If you look through some of Leet's MortScript files and replace any reference to "My Flash Disk" with "USB Disk" you might be off to a good start. The only other issue might be if he's hard-coded references to "My Flash Disk" into some of his custom programs (like the main launcher, say for sourcing images). Quote Link to post Share on other sites
nastyplasty Posted November 12, 2009 Report Share Posted November 12, 2009 Hi FourG, Sorry for the late answer but I have not had time to go to the car and test until now. I replaced all reference to "My Storage Card" for "USB Disk" in all files (not only Leet but also some files on the navigator folders). Unfortunately it does not work. I understand "My flash Disk" is the internal memory of the F500bt, I maybe wrong (that could be my next trial). Will keep you informed.... Quote Link to post Share on other sites
ricardocoronado Posted November 20, 2009 Report Share Posted November 20, 2009 Hi i am new here on the site, can't make garmin connect to my avic f900bt gps, can any one help me please. Quote Link to post Share on other sites
tomciopalec Posted November 20, 2009 Report Share Posted November 20, 2009 Used leetlauncher v3.0 on avic f700bt with 2.000 firmware and got tomtom working as well. This is very good looking beta, Thanks Leet for sharing this with us. cheers Quote Link to post Share on other sites
rad2085 Posted November 21, 2009 Report Share Posted November 21, 2009 Hi Guys Will leetlauncher work on the new F10BT series?? Also i was looking to run OZI explorer which is a topographic map software package, it would be very handy amongst the 4wd community. Any info greatly appreciated Greg Quote Link to post Share on other sites
VBLUE42 Posted November 22, 2009 Report Share Posted November 22, 2009 The F10 is not part of the same F series as before. The F10 does not run Windows CE, will not run Testmode, and does not use iGo software. The F10 is the same unit as the US Z110BT. So answer is no, there will be no hacks or mods for the Z110BT/F10BT. Quote Link to post Share on other sites
ballina226 Posted December 14, 2009 Report Share Posted December 14, 2009 Hello I have just bought a UK F500BT with software version 3.010100 and tried to load LeetLauncher v3.0 with no luck at all. After playing the mp3 file and re-booting the unit it locks with the Pioneer menu screen and will not go any further. I have the following on my SD card Application Data Garmin iGo8 LeetLauncher Testmode Tomtom Voices device.nng I have read all the posts but may have missed something on the 53 pages! Am i doing something wrong or is it the latest version of the software. Many thanks for any help. Quote Link to post Share on other sites
abb1 Posted December 15, 2009 Report Share Posted December 15, 2009 HelloI have just bought a UK F500BT with software version 3.010100 and tried to load LeetLauncher v3.0 with no luck at all. After playing the mp3 file and re-booting the unit it locks with the Pioneer menu screen and will not go any further. I have the following on my SD card Application Data Garmin iGo8 LeetLauncher Testmode Tomtom Voices device.nng I have read all the posts but may have missed something on the 53 pages! Am i doing something wrong or is it the latest version of the software. Many thanks for any help. I would not use this program as it is over a year old and there have been lots of updates to the initial firmware since. Combine that with the fact that Leetcoder is hardly ever in these forums anymore, I would not reccomend this, it could cause major problems Quote Link to post Share on other sites
mjksoft Posted January 14, 2010 Report Share Posted January 14, 2010 Hello Please let me know how did you install Garmin and iGo8 on the SD? and how do you select the program to run ? Regards; HelloI have just bought a UK F500BT with software version 3.010100 and tried to load LeetLauncher v3.0 with no luck at all. After playing the mp3 file and re-booting the unit it locks with the Pioneer menu screen and will not go any further. I have the following on my SD card Application Data Garmin iGo8 LeetLauncher Testmode Tomtom Voices device.nng I have read all the posts but may have missed something on the 53 pages! Am i doing something wrong or is it the latest version of the software. Many thanks for any help. Quote Link to post Share on other sites
ndy4eva Posted January 15, 2010 Report Share Posted January 15, 2010 HelloI have just bought a UK F500BT with software version 3.010100 and tried to load LeetLauncher v3.0 with no luck at all. After playing the mp3 file and re-booting the unit it locks with the Pioneer menu screen and will not go any further. I have the following on my SD card Application Data Garmin iGo8 LeetLauncher Testmode Tomtom Voices device.nng I have read all the posts but may have missed something on the 53 pages! Am i doing something wrong or is it the latest version of the software. Many thanks for any help. Please make sure you're running testmode v2.3. Older version doesn't work with firmware v3. Quote Link to post Share on other sites
Join the conversation
