qingz Posted February 4, 2010 Report Share Posted February 4, 2010 I have problem with Garmin XT on my F500BT. It crashes every time when I click any icons under "Points of Interest". Anybody have the same experience? Quote Link to post Share on other sites
ArthurJGuy Posted February 28, 2010 Report Share Posted February 28, 2010 Am I correct in understanding that I can launch other windows CE applications on top of the AVIC using leetlauncher? Has anyone found any updates on the USB input? The only thing I really want is to put my radar detector into the screen of the AVIC like guys with carputers do with the valentine 1 windows app. Quote Link to post Share on other sites
ivanlf Posted March 11, 2010 Report Share Posted March 11, 2010 Hi all!! My name is ivan and I'm italian. i've bought an avic f900bt and i follow the leetlauncher's guide and it works fine, but i have a problem with tom tom application. I put the map in the folder "tom tom " of the sd (the map is italia V845.2666 )then i activate the map but, the program still not work, it will display " no maps found". anyone would keep me a hand? thanks a lot and sorry for a bad english Quote Link to post Share on other sites
knorrr Posted March 15, 2010 Report Share Posted March 15, 2010 lucaspeedy,You need to copy some files from Testmode 2.3's testmode folder into LeetLauncher 3.0's testmode folder for it to wok with the latest releases of the AVIC firmware. Copy all the 0-length files without an extension (they are named like "45487613469745412354668745684665", etc) from Testmode 2.3's "testmode" folder into the LeetLauncher 3.0's "testmode" folder and it should boot. These files are like keys the firmware looks for before it will let you enter testmode. Hello everyone I have don this but my F900BT (Europa/ Netherland) hold with the leetlauncher display and the message "system is starting up. Please wait ...." And I am waiting and waiting but after 90 minutes I believe this is not good. What can I do?? I have make the SD card again (after format) I have start up many times? I have the same problem with and without any maps. But I have also don it with maps (MIO en TT) I have the 3.002.00 firmware on the system I have download leetlauncher again (version 3.00) he start with the time 12:00 Am after a little time he set the time to 06:06or something else. Please... help. Thanks Ron update: I have done a reset (pin left corner with the SD card in slot) I have a error Could'n copy '\storage card\leetlauncher\script\leetmenu.exe' to 'my flash disk\apl\leetmenu Line 4 (\storage card\leetlauncher\script\startmenu.mscr): copy ("\storage card\leetlauncher\scripts\leetmenu.exe", "\my flasdisk\apl\leetmenu", TRUE) I don't no this is helping to fix my problem but.... I hope so. Thanks a lot Rob. ======================== Update ======================== After the change earlier in this 55 pages I have change the copytool.mscr whit (but also only) Run(SystemPath("ScriptPath")\"..\LeetLauncher\LeetLauncher.exe") But now I have the message: Variable reference is empty. Line 2 (\storage Card\Testmode\copy Tool.mscr): run(systemPath("scriptPath")\"..LeethLauncher.exe") }/quote} I don't understand this. I am good in computer hardware but software ..... Please help me. I wanted also TT on my Pioneer FB90 BT Europe Thanks again. Quote Link to post Share on other sites
knorrr Posted March 15, 2010 Report Share Posted March 15, 2010 Mistake it is a part from message here at the top Delete this one. So it is one story Quote Link to post Share on other sites
FourG Posted March 15, 2010 Report Share Posted March 15, 2010 In most programming languages a single '\' in between two double quotes in a string declaration usually means you're using a control character (like being "\t", for example). Try escaping the "\"s in the command string (notice I left the first "\" that's outside the double quotes alone): run(SystemPath("ScriptPath")\"..\\LeetLauncher\\LeetLauncher.exe") Quote Link to post Share on other sites
knorrr Posted March 16, 2010 Report Share Posted March 16, 2010 In most programming languages a single '\' in between two double quotes in a string declaration usually means you're using a control character (like being "\t", for example). Try escaping the "\"s in the command string (notice I left the first "\" that's outside the double quotes alone): run(SystemPath("ScriptPath")\"..\\LeetLauncher\\LeetLauncher.exe") Thanks a lot a look for it but I did't make it self it is a copy from: viewtopic.php?f=64&t=18522&start=795#p206988 I will also try first to install the original update from pioneer. I have only update it from here viewtopic.php?f=34&t=29761 My be there is also a problem with this. I hope so for a solution. TomTom is so much better for my use. Rob Quote Link to post Share on other sites
knorrr Posted March 16, 2010 Report Share Posted March 16, 2010 16/mrt 11:15 uur It is working !!!! After the (original) Pioneer update he has update windows Ce with one version on the end x.xx.xxx.3 and Leetlauncher works!! Magnificent. Now I have the problem no maps found (i put them in the TT folder) but that I am looking for. Also the same problem with a Igi8 . Thanks a lot for so far I hope also when he is working TT is fast and I can put al my POI's (1000 +/-) with Europ mobilhomeplaces e.g. on my system. ================================================ The problems that I have now: - TomTom "no maps found" (I have try different maps but he don't foud it. Where have I put them I have set the maps in TT directory in a map Benelux or Europe - IGO he give after startup "initializing warning data" and hang-up the complete system +++is fixed. Have another content map copied and deleted de "old"one. - how can I use the radio Thanks again Ron (the Netherlands) Quote Link to post Share on other sites
Hube2002 Posted March 19, 2010 Report Share Posted March 19, 2010 has anyone seen this video on YouTube about leetlauncehr? Is it this far along here on this forum. This looks very cool. Quote Link to post Share on other sites
VBLUE42 Posted March 19, 2010 Report Share Posted March 19, 2010 Holly shit that looks nice. As far as I am aware though, he is no longer in development on this. PM him and see if he responds. Quote Link to post Share on other sites
ivanlf Posted March 19, 2010 Report Share Posted March 19, 2010 16/mrt 11:15 uur It is working !!!! After the (original) Pioneer update he has update windows Ce with one version on the end x.xx.xxx.3 and Leetlauncher works!! Magnificent. Now I have the problem no maps found (i put them in the TT folder) but that I am looking for. Also the same problem with a Igi8 . Thanks a lot for so far I hope also when he is working TT is fast and I can put al my POI's (1000 +/-) with Europ mobilhomeplaces e.g. on my system. ================================================ The problems that I have now: - TomTom "no maps found" (I have try different maps but he don't foud it. Where have I put them I have set the maps in TT directory in a map Benelux or Europe - IGO he give after startup "initializing warning data" and hang-up the complete system +++is fixed. Have another content map copied and deleted de "old"one. - how can I use the radio Thanks again Ron (the Netherlands) I have the same problem Quote Link to post Share on other sites
knorrr Posted March 19, 2010 Report Share Posted March 19, 2010 [quote="knorrr" The problems that I have now] =================================================== After reading 55 pages I believe that the radio is not working it is "normal" But how can I put maps in the TT file? Have nobody a solution?? PLEASE (not only for my I have read ) Thanks for the answers Ron Quote Link to post Share on other sites
FourG Posted March 20, 2010 Report Share Posted March 20, 2010 ===================================================After reading 55 pages I believe that the radio is not working it is "normal" But how can I put maps in the TT file? Have nobody a solution?? PLEASE (not only for my I have read ) Thanks for the answers Ron Sorry Ron, but until we get the APL DLLs figured out we can't tell the uCOM device on the AV board to change the audio source from the Navi sources (SD & USB) to other sources like the Radio, IPBus, iPod or AV1/2. I'm not sure if Leet got around to that, and none of us have his source to make modifications ourselves. Quote Link to post Share on other sites
abb1 Posted March 20, 2010 Report Share Posted March 20, 2010 This has been a download that I have always been reluctant to try because he has left the forum and this mod has been up before the 3.0 update without any changes. I think that I pm'd him about six months ago and did not get a response, actually, the PM wasn't even read Quote Link to post Share on other sites
leetcoder Posted March 30, 2010 Author Report Share Posted March 30, 2010 Hi avic411 people, sorry I've been away from the scene. Been extremely busy with work and have absolutely no time at all to work on this project. Another bad news is that someone broke into my car and stole my F900BT so now I don't think I will ever continue with this development anymore. To those that pm me, sorry that I didn't reply to you. I don't want to be a jerk, but I just don't have the time anymore. Consider the development of the leetlauncher over for now. For all developers that want to continue development on this deck and need help, you can always try to AIM me at BKnight209. If I don't answer, that means that I am away, just leave a detail message and I will try to respond to you when I am available. I'll try to point you in the right direction. If I ever decide to get a new deck, I might start a new project for whatever deck I am going to get in the future. I will most likely stay within the pioneer community. Thank you for all your support. Quote Link to post Share on other sites
Join the conversation
