ill.die.trying Posted February 16, 2009 Report Share Posted February 16, 2009 found this online [2d] minguidancearrowsize=20 maxguidancearrowsize=65 minguidancearrowsize_zoomlevel=1200 maxguidancearrowsize_zoomlevel=0 guidancearrow_disappearlevel=600 guidancearrow_maxshift=12 [3d] guidancearrow_first_size=1.1 ; scale of 1st arrow guidancearrow_first_alpha=24 ; transp of 1st arrow guidancearrow_second_size=0.8 guidancearrow_second_alpha=12 ;guidancearrow_width ; ;guidancearrow_thickness ; ;guidancearrow_skew ; ;guidancearrow_zoomfactor ; ;guidancearrow_contour ; ;road_clip_plane_to_camera_height= ; ;road_clip_plane_camera_delta=50 ; ;3d_tmc_road_extra_width=200 ; disable_3d_labels=0 ; ;use_all_building_textures=0 ; not? ;building_camera_distance_near=10 ;building_camera_distance_medium=50 ;building_camera_distance_far=500 fade_distance_for_car=50 fade_distance_for_guidance_arrow=500 ;track_screen_ratio ;min_track_screen_ratio ;min_track_distance ;max_track_distance_lower ;max_track_distance_upper ;min_track_segments_shown ;max_track_segments_shown ;min_poly_distance ;max_poly_distance_lower ;max_poly_distance_upper ;min_poly_segments_shown ;max_poly_segments_shown [3d_config] roadsign_lines_per_screen=12 rotated_roadsigns=1 [bluetooth] send_showphoneui_on_dial=1 [config] SafeModeMinSpeed=40 autoset2donmap=1 autoset3doncockpit=1 hideroadaltname=1 overspeedrewarnbelow=1 [debug] show_poi_boundingrects=1 show_poi_areas=1 show_performance=0 ; cpu / mem / whatever bars on top of screen show_device_type=0 show_rawdisplay_info=0 ; handy for seeing what igo chooses as display driver ;max_memory= ;reserve_memory run_on_mio_mantas=1 topmost=1 ;nortc=1 ; dunno buildneworderlist=1 poi_labels=1 sim_speed_factor_max=8.0 strap_waypoints=1 fov=40 tts_min_ready_wav=1 tts_getaway_time=200 tts_expected_engine_delay=1400 supress_straight=0 supress_highway_enter=0 supress_trivial_left=0 supress_trivial_right=0 ;split_dual=0 ;join_dual=0 ;traincrossing=1 enable_buildings=1 enable_roadshadow=1 enable_roadsign=1 enable_landmark_occlusion=1 show_oneway_3d=1 ; 3d arrows in one way streets show_oneway=1 ; show one way on or off show_multinode_maneuvers=1 show_prohibited_maneuvers=0 show_priority_maneuvers=1 hide_itiner_crossing=1 show_gps_pos=1 ; this works again ;O) show_signpost=1 replay_tmc=1 tmc_all_stations=1 show_pedestrian=1 pin_sets_start=1 compass_type=2 show_ltn=1 disable_3d=0 ;disables 3d buildings and roads double_pixel_mode=2 ;3d mode fastdraw doublepixel_stable_frame_time=500 ;time in ms before leavin fastdraw skip_eula=1 show_arrows_on_route=1 ; little arrows in direction of route show_lane_info=1 loop_sim=1 smart_2d=1 earth=1 show_plural=1 show_residentonly=0 autosave=1 speedcam_enabled=1 gnome_dem_files=1 show_turn_penalty=1 ;disable_outlookpoi=1 [defaults] mainroadness=60 shortessness=50 simplificationness=40 [device] ;type="MIOC210" ; force device type ;typeid=3 ;In Igo8.exe: MIO device detected, use KernelIOControl method [feature] text_guidance=1 signpost_coloring=1 tmc_event_coloring=1 tmc_traffic_side=1 [folders] app="%SDCARD%/iGO8" ; change this if applicable ;sdcardpath="\Storage Card" ;exe="" ;data="\Storage Card\igo" ;custom,save ;content="\Storage Card\igo\CONTENT" ;textures="custom" ;models="custom" ;secondary_root="IPAQ\NAV" [gps] background_navigation=1 logging=0 ; see also mydata.tracks port=2 baud=38400 source="nmea" disable_advanced=0 ;default_latitude=48.857004 ;default_longitude=2.294760 [interface] ;theme="skin\igo8_plus.zip" skin="ui_igo8" minzoomglobe=100000 show_gps_config=1 show_tmc_config=1 show_orientation=1 show_exit=1 ; obvious disable_3dstick_labels=1 ; mapfontscale=130 ; for 2d and 3d map newalignment=1 ; ;default_poi_icon="Contacts" ; show_zoombar=1 ; also see zoomscale_disappearing show_timezoneslider=1 ; ;resolution_dir="320_240" ; ;maxzoom2d=60000 ; zoom out level (disabled get you into space ;O) minzoom2D=40 ; zoom in level 2d defaultzoom2d=1000 defaultzoom3d=500 defaulttilt3d=75000 autoscroll_on_click=1 ;angleoffset= ;Zoom2dpercent= popup_info=1 poi_show_all_btn=1 autotilt=0 ;autotilt_minzoom3d=40 ;autotilt_maxzoom3d=1000 ;screen_snap_distance=40 exit_on_restart=0 use_spec_fav=1 spec_fav_count=4 empty_favorites=1 drive_carefully=0 [itiner] show_only_ahead_of_car=1 [kml] default_icon=1 [loading] show_statustext=1 show_progressbar=0 progressbar_x=85 progressbar_y=134 ;loading_bmp="loading.jpg" ;text_fontcolor=xFFFFFF ;text_fontsize=30 ;text_x=100 ;text_y=400 ;text_w=600 ;text_align: LEFT = 0,CENTER = 1,RIGHT = 2 JUSTIFY = 3 text_align=1 [local] dateformat=6 ; [map] follow_gps=1 ;3d_brunnel_shutdown= alternative_roadnames=0 stop_rotate_on_map_move=1 ;map_mode="3D" ;cross_border_routes=1 show_labels=1 ; textured_poly=1 zoomscale_disappearing=1 ; works with show_zoombar auto_nightmode=0 ; see also nightmode show_oneway=1 inertia_on_map_move=1 shields=1 3d_landmarks=1 3d_buildings=1 3d_buildings_distance=2 3d_dem=1 3d_dem_detail=2 terrain_in_2d=0 3d_roads=1 3d_tunnels=1 3d_max_tiltlevel=7500 3d_max_zoomlevel=2000 3d_min_zoomlevel=40 3d_max_zfar=500 3d_scale_carmodel=1 3dcarsizemin=5000 3dcarsizemax=10000 3dcarsizemul=30000 minPolyDistances0 = 500 minPolyDistances1 = 500 minPolyDistances2 = 500 minPolyDistances3 = 500 maxPolyDistances0 = 2000 maxPolyDistances1 = 3000 maxPolyDistances2 = 4000 maxPolyDistances3 = 5000 minTrackDistances0 = 500 minTrackDistances1 = 500 minTrackDistances2 = 500 minTrackDistances3 = 500 maxTrackDistances0 = 2500 maxTrackDistances1 = 3500 maxTrackDistances2 = 4500 maxTrackDistances3 = 5500 maxFovRatioForPoly=8 roadblockicon_maxzoom=2000 [msnd] ; How does msdn work? Movies, Weather, Petrol prices, etc..... msnd.start=0 [mydata] max_favorites=16 ;num_favicons=7 ;favicon="" max_histories=40 [mydata.tracks] auto_track_visible=1 record_auto_track=0 ;tracklog_folder="" [navigation] skip_grab_viewchanging=1 sim_speed_factor=1.0 show_current_city=1 show_countrychange=1 autoreplan_action="AUTO" gps_pos_to_road=1 [other] demo_mode=1 [phone] ;driver="TAPI" ;exe_path="\Windows\cprog.exe" ;win_name="Phone" [poi] enable_pois_before_080217=1 ;080217 is the date can be changed as needed multipoi=1 ;allows you to use more than one set of POIs at a time (will show duplicates though) [power] ;backlight_sync_with_OS=1 ;powermgm_state=0 backlight_day=100 backlight_night=54 ;power_off_mode=1 ;power_off_timeout=300 battery_warning_limit=10 ;backlight_slow_api=1 [rawdisplay] highres=0 ;driver=GX ;GDI or GX ;class="landscape" ; or rlandscape, portrait, square,wide screen_x=320 screen_y=240 stretch=0 [route] correctness=80 ; we used to have a slider for that allow_unpaved=0 allow_highway=1 allow_ferry=1 allow_charge=1 allow_uturn=1 allow_special=0 allow_carpool=0 route_type="ECO" planned_route_weight=7 scenic_highway_weight=4 scenic_scenic_weight=2 tmc_weight=6 cross_border_routes=1 ;vehicle_type="truck" ;slow_car_speed ;slow_car_multiplactor ;fast_car_speed ;fast_car_multiplactor ;motorcycle_speed ;motorcycle_multiplactor [screen] nightmode=0 menu_animation=0 ;focus=1 ;focus_type=2 ;focus_color ;focus_sprite ;focus_halign ;focus_valign ;focus_followlinks ;focus_list_move_before_scroll ;focus_list_keyup ;focus_list_keydown ;focus_list_keyleft ;focus_list_keyright ;focus_activator_key ;current_background="default.bmp" [settings] accident_recalc=0 accident_map=1 accident_panel=1 closed_recalc=0 closed_map=1 closed_panel=1 heavy_recalc=0 heavy_map=1 heavy_panel=1 congestion_recalc=0 congestion_map=1 congestion_panel=1 roadworks_recalc=0 roadworks_map=1 roadworks_panel=1 closures_recalc=0 closures_map=1 closures_panel=1 danger_recalc=0 danger_map=1 danger_panel=1 weather_recalc=0 weather_map=1 weather_panel=1 police_recalc=0 police_map=1 police_panel=1 invalid_recalc=0 invalid_map=1 invalid_panel=1 [smartzoom] restore_smartzoom_on=1 enabled=1 enabled2d=1 ;use2d is to use separate smartzoom for 2d and 3d. Once this is implemented in a UI it should be set to 1. use2d=1 minzoom=60 maxzoom=250 auto_follow_on=1 autozoom_coord=200 autozoom_address=100 autozoom_cos=200 auto_follow_time=10 auto_smartzoom_time=8 zoom_after_find=1 default_visibility_altitude=4000 overview=0 overview_zoomlevel=10000 overview_distance=20000 minangle=8 maxangle=85 [speedcam] usemio=-12,90,37,27 disable="_SUI", "_GER", "_AUT" ;speedcam_sound="!alert1" enable_at_startup=1 [sound] queue_length=200 ding=0 sound_volume=255 voice_volume=255 sound_muted=0 voice_muted=0 ;device_samplerate= ;device_bps= ;device_stereo= ;suspend_time=5 ;timeout for wavedev to goto sleep ;use_os_volume=1 dynamic_volume_type=1 dynamic_volume_minspeed=40 dynamic_volume_maxspeed=100 dynamic_volume_voicemaxspeed=80 dynamic_volume_voice_volume_max=100 dynamic_volume_os_volume_max=255 ;incomingcallsetting=0 [timezone] default_timezone=29 ; GMT+1 amsterdam index=29 auto_index=29 sync_time=1 reset_os_timezone=0 sync_os_timezone=0 use_auto=1 manual_dst=0 [tmc] port="COM,1" baud=38400 source="gns" ;harman eten galik opentmc2 opentmc1 hyundai samsung amaryllo royaltek gns auto_detour_calc=0 ;announce_total_route=1 ignore_all_events=0 [tripcomputer] num_of_trips=4 ; default igo8 has only 3 [tts] tts_buffer=131072 announce_exit_directions=1 tts_logics=3 priority="HIGH" always_say_road_names=1 announce_street_name=1 skip_exit_numbers=0 [usb] enable_on_shutdown=1 disable_on_startup=0 quitmap_msg_quits=0 [warning] speedwarn_alt_builtup_based=1 pedestrian_warning=0 speedcam_visualtype=1 speedcam_soundtype=1 speedcam_warning=1 speedlimit_warning_voice=1 speedlimit_warning_visual=1 speedwarn_tolerance=110 speedlimit_warning=1 ;pedestrian_warning_threshold= ;speedwarn_toltype ;speedwarn_alt_toltype ;speedwarn_alt_limit ;speedwarn_alt_builtup_based ;speedwarn_alt_tolerance approach_beep_distances=200 warn_distances=100 section_beep_distance=200 ;speedcam_max_angle=20 speedcam_snap_distance=200 speedcam_max_lookahead=400 speedcam_maxdistance_from_road=10 overspeed_sound= "!alert3" ; speedcam sound ;max_section_time=240 section_beep_sound= "!sectionbeepA" approach_beep_sound="!sectionbeepB" section_start_sound="!sectionstartA" section_end_sound= "!sectionend" Quote Link to post Share on other sites
superman8262 Posted February 16, 2009 Report Share Posted February 16, 2009 now this looks helpful and awesome. but what does this mean? 2d map north up? thanks for the search =) Quote Link to post Share on other sites
paQ Posted February 16, 2009 Report Share Posted February 16, 2009 now this looks helpful and awesome. but what does this mean? 2d map north up? thanks for the search =) Hopefully that it puts North facing up in 2D. Any confirm on this? Also the last bit should indicate there is span set for the alarm on the speedcam. Quote Link to post Share on other sites
S4 Posted February 16, 2009 Report Share Posted February 16, 2009 Which version of iGo did this come from? I believe in the latest (8.3?) 2D North up has been fixed. Quote Link to post Share on other sites
ill.die.trying Posted February 16, 2009 Author Report Share Posted February 16, 2009 this is for 8.0 Quote Link to post Share on other sites
S4 Posted February 16, 2009 Report Share Posted February 16, 2009 Have you tried it yet? If I remember to try after work I will and see what happens Quote Link to post Share on other sites
skicrave Posted February 16, 2009 Report Share Posted February 16, 2009 Many of those settings won't apply to the F-Series, but it's still worth trying (I can't remember if anyone has tested it before). Let us know what you find. Quote Link to post Share on other sites
BorisM Posted February 16, 2009 Report Share Posted February 16, 2009 Many of those settings won't apply to the F-Series, but it's still worth trying (I can't remember if anyone has tested it before). Let us know what you find. Some were tested (i.e. 3D arrow sizxe control, original speedcamera hack... all in SYS.TXT). Some only apply to smartphones, but the rest could be useful. Quote Link to post Share on other sites
skicrave Posted February 16, 2009 Report Share Posted February 16, 2009 So really we need someone to take the time to go through line-by-line and apply comments to each setting regarding the functionality and whether or not it applies to the F-Series. Maybe we can all just start biting off small pieces as we make other mods, and post them to this thread? I'll compile a complete list if we get enough useful information. Quote Link to post Share on other sites
ill.die.trying Posted February 16, 2009 Author Report Share Posted February 16, 2009 i'll start, [navigation] skip_grab_viewchanging=1 sim_speed_factor=1.0 show_current_city=1 show_countrychange=1 autoreplan_action="AUTO" gps_pos_to_road=1 ; snap to road option, on/off selection is on route setting for this to work add the highlited one on your setting_800_480.ui ;****************************** ; Route *********************** ;****************************** Quote Link to post Share on other sites
N-S-E-W Posted February 17, 2009 Report Share Posted February 17, 2009 [mydata] max_favorites=16 ;num_favicons=7 ;favicon="" max_histories=40 ;works. Our units appeared to be set at 32 stock. [navigation] skip_grab_viewchanging=1 sim_speed_factor=1.0 show_current_city=1 show_countrychange=1 autoreplan_action="AUTO" ;not sure if it works 100% of the time but the unit has not said off-route and not re-calculate since I put it on about 2 weeks ago. gps_pos_to_road=1 3d_max_tiltlevel=7500 3d_max_zoomlevel=2000 3d_min_zoomlevel=40 3d_max_zfar=500 3d_scale_carmodel=1 3dcarsizemin=5000 3dcarsizemax=10000 3dcarsizemul=30000 ;all work as has been discussed in many other threads. You'll need to play with values to get the view and car size that's suitable for you. Quote Link to post Share on other sites
mhejl Posted March 1, 2009 Report Share Posted March 1, 2009 Even with the edit above, the (new) radio button is disabled if vehicle type is "Car" (F90BT). This is disabled in common/ui/setting.ui and then defaulted to off in other cases. Comment out the following (note the comma in the first edit): : [...] ;-----my init ui_SettingRoute.y 0 runif nVehicle 0 'nVehicleTmp.set "Car", btn_vehicle_value.set "Car"' else_runif nVehicle 5 'nVehicleTmp.set "Pedestrian", btn_vehicle_value.set "Pedestrian" ;, btnSR_AlignToRoad.DISABLE' runif nVehicle 5 'rdkeepposon.enable, rdkeepposoff.enable' else_runif nVehicle 6 'rdkeepposon.enable, rdkeepposoff.enable' ;else_run 'rdkeepposon.disable, rdkeepposoff.disable' With these two edits, there is no need for the hard coded gps_pos_to_road=0 in sys.txt! Quote Link to post Share on other sites
paQ Posted March 2, 2009 Report Share Posted March 2, 2009 is there a line for the sys.txt which takes care of that tiny black dot (the actual GPS position) which is under, over and besides my arrow icon? It annoys me Quote Link to post Share on other sites
dumpystig Posted March 2, 2009 Report Share Posted March 2, 2009 is there a line for the sys.txt which takes care of that tiny black dot (the actual GPS position) which is under, over and besides my arrow icon?It annoys me Maybe this: [navigation] gps_pos_to_road=1 ??? Change to: [navigation] gps_pos_to_road=0 ??? Quote Link to post Share on other sites
N-S-E-W Posted March 4, 2009 Report Share Posted March 4, 2009 [mydata] max_favorites=16 Works. I set this to 60 before my trip. Just checked all 60spots are filled. Quote Link to post Share on other sites
