Carter Posted February 24, 2009 Report Share Posted February 24, 2009 I parked in an underground parking yesterday. Of course, the GPS signal was lost. Got outside of the parking and the map was moving, but soon after the little arrow was no longer on a street. Before long, it's way off from my actual location, but still trying to do something like dead reckoning. Checking the hardware setup, it says the antenna is disconnected. So, before I start pulling everything apart only to find that it needed a reboot... have any of you seen this before? Thanks 'c' Quote Link to post Share on other sites
wastedtime2525 Posted February 24, 2009 Report Share Posted February 24, 2009 if your arrow keeps moving and does not turn or if it stops altogether you most likely have a dead gps antenna. I have burned out 2 antennas thus far on my avic unit in the last 6 years. You can also try repositioning the antenna, removing it altogether and making sure its not getin crushed by something in the car, but most likely its a busted antenna Quote Link to post Share on other sites
Carter Posted February 24, 2009 Author Report Share Posted February 24, 2009 Thank you for that. I was hoping. The antenna wire runs in between the soft rubber and the door, and most likely the door opened and closed one to many times. I'll try the new antenna before I get out the pry bars. 'c' Quote Link to post Share on other sites
Carter Posted February 26, 2009 Author Report Share Posted February 26, 2009 Thanks WastedTime2525 That was EXACTLY what was wrong. Posting follow up here in case future searches will solve your problem also. Symptoms: Map moved like it was tracking, but not in correct actual location. Checking hardware settings>connection reveals "GPS antenna faulty, check with service". I was lucky enough to have a car stereo store nearby that happened to have Pioneer antenna in the spare parts bin and after plugging it in and the displayed worked as it should, paid for the antenna and finished the install. Carter Quote Link to post Share on other sites
jimmy303 Posted March 1, 2009 Report Share Posted March 1, 2009 The GPS antennae are a bit delicate, and they do not usually take well to car washes and pressure cleaners. Glad to hear you got fixed up... Quote Link to post Share on other sites
wastedtime2525 Posted March 3, 2009 Report Share Posted March 3, 2009 Thanks WastedTime2525 That was EXACTLY what was wrong. Posting follow up here in case future searches will solve your problem also. Symptoms: Map moved like it was tracking, but not in correct actual location. Checking hardware settings>connection reveals "GPS antenna faulty, check with service". I was lucky enough to have a car stereo store nearby that happened to have Pioneer antenna in the spare parts bin and after plugging it in and the displayed worked as it should, paid for the antenna and finished the install. Carter glad i could help. Ive gotten so much help on these forums its nice to return the favor back to someone. Quote Link to post Share on other sites
