DJEurobeat Posted March 16, 2009 Author Report Share Posted March 16, 2009 My TTS its NOT working either. It will not work with Avic S1 , I made several attempts to solve it but couldn't . One more thing , dont try to install different scheems or scheem changer IT WILL NOT WORK with Avic S1 Pioneer cant run it . Quote Link to post Share on other sites
DJEurobeat Posted March 16, 2009 Author Report Share Posted March 16, 2009 http://rapidshare.com/files/208420886/navi.rar no pass TIP: Changing only the .exe file into the old 8.3.2.X structure with the one from the upper link, you will have the standard IGO8 loading and About screens: Quote Link to post Share on other sites
DJEurobeat Posted March 16, 2009 Author Report Share Posted March 16, 2009 http://www.mediafire.com/?ldyjmzklmwm Mirror 2 http://www.badongo.com/file/13837478 Next Navigator 8 (YE-G 828) - v8.3.2.79297 (March 2 2009) Nav N Go iGO 8 R3 series Requirements: WinCE operating system 300 MHz processor, 64 MB memory, QVGA or VGA touch screen display Overview: GPS Navigation Software for Windows Mobile based PNA devices featuring stunning 3D navigation with outstanding graphics of buildings, landmarks, and entire cities. This version has been extracted from Next YE-G 828 PNA device and as usual, it has been patched to work on PNA devices. TIP: If you are using the previous version of IGO 8.3.2.x just replace "IGO8.exe". Use the data.zip and branding.zip from this release with caution, as they do not contain all resolutions and they are not tested yet especially when using skins. The branding (inclusive POIs icons) are different than in the previous versions (customized for Next). Recommended use: -add all licenses from the package in this thread to license folder;There are a lot of license related problems with different IGO8 builds,which are fixed using the correct license(s). -replace (overwrite) data.zip and branding.zip with LZF v9d (or newer) provided in this thread. -of course,you need to populate the content (maps.pois, dem, buildings,languages and voices) NOTE: IGO8 software by NNG is in a continuous development cycle.As the software is used in a number of PNA devices (like this version) newer builds than the official retail one become available. Common sense tells that a newer build may have fixed bugs and/or new features, but this might not be the case. A new build may also introduce new bugs , so use caution when upgrading a version you already have. It is HIGHLY recommended that you delete your save folder content when you change your software version (remember,you will lose your current settings,and any saved routes, favorites and other user saving in this case but may eliminate some problems do to compatibility between versions). If you use a skin, and you have problems switch to the default skin, and check if the problem is still there. Many skins work only with some specific builds ( in general if data.zip is compatible between version the skins will work also). Also, do a hard reset as some devices keep some setting in memory. Quote Link to post Share on other sites
DJEurobeat Posted March 16, 2009 Author Report Share Posted March 16, 2009 Enjoy guy's these new releases !!! I have decided to sell Avic S1 after many days and nights playing getting maximum out of it , but the unit is very out dated to have it all And I can do much more with newer units . So I dont know if I will be on this forum very often . Anyway I always ready to help if I can . Quote Link to post Share on other sites
PysiekChicago Posted March 23, 2009 Report Share Posted March 23, 2009 http://www.uploadjockey.com/download...8/nextnavi.rar The link is not working Quote Link to post Share on other sites
cj121204 Posted March 26, 2009 Report Share Posted March 26, 2009 can i put igo on my avic s1 if i can only get to the blue screen ? if not can someone help me to load what i to do it ? Quote Link to post Share on other sites
PysiekChicago Posted March 26, 2009 Report Share Posted March 26, 2009 What blue screen?? Anyway u can't load it.Because to install it u need to be on the desktop of your GPS unit. Quote Link to post Share on other sites
cj121204 Posted March 26, 2009 Report Share Posted March 26, 2009 the blue screen where u load wince.exe file i reformatted it by mistake can anyone tell me how to reformat it so then i can put igo on it Quote Link to post Share on other sites
PysiekChicago Posted March 26, 2009 Report Share Posted March 26, 2009 what u have to do is to load a unlocker on the memory card,insert to GPS and do soft reset.Black button on the back. After that everything should load automaticly. Quote Link to post Share on other sites
DJEurobeat Posted March 27, 2009 Author Report Share Posted March 27, 2009 what u have to do is to load a unlocker on the memory card,insert to GPS and do soft reset.Black button on the back. After that everything should load automaticly. Yes , that is correct !! If its not the hardware problem then everything will work just fine Quote Link to post Share on other sites
DJEurobeat Posted March 27, 2009 Author Report Share Posted March 27, 2009 UPDATE - Nav N Go iGO8 v8.3.2.80621 (Mar 10 2009) - March '09 update. This release is patched to work with the Generic WorldWide license that enables TMC Pro feature in some European countries. Download Instructions: - complete navigation software excluding the Content: Download : http://rapidshare.com/files/213506387/nav_mar10.rar pass: squirrel NOTE: Please remove any other licenses present in your license folder as this release won't recognize them! Enjoy Quote Link to post Share on other sites
whill64 Posted May 16, 2009 Report Share Posted May 16, 2009 Yahooo !!! I got iGO8 v8.3.2.71348 Jan 07 2009 going on my Avic S1Tested on the road and it works amazing !!!! i am new here. i have a avic s1 can you please help me to get the 2009 update for mine Quote Link to post Share on other sites
asplodzor Posted June 5, 2009 Report Share Posted June 5, 2009 I'm thinking about installing this software on my AVIC-S2, but I don't want to lose the possibility of reverting back later on. Does this wipe the original Pioneer software, or just load alongside it? Thanks! Quote Link to post Share on other sites
alizee Posted June 5, 2009 Report Share Posted June 5, 2009 if anybody needs help with getting AVIC map update, installing igo map on s-1 or s-2 please just write at: service@gps.pol.pl OR~ dont't you want watching movies on your's gps navigation? yes there is some possibility watching *.avi movies on AVIC s-1 & s-2 Quote Link to post Share on other sites
DJEurobeat Posted May 4, 2010 Author Report Share Posted May 4, 2010 FREE ..............FREE.............FREE !!!!! Software !!!!! MAPS !!!!! LOOK AT MY NEW POST : viewtopic.php?f=22&t=32146 Enjoy ! Quote Link to post Share on other sites
