ill.die.trying Posted August 23, 2009 Author Report Share Posted August 23, 2009 Any ideas? have you tried changing the 'type' part of your system text to your whatever the f500 unit has? Perfect, that did the trick, thanks! F500BT type is: [device] type="PIONEER749UC" no problem Quote Link to post Share on other sites
catastrat Posted August 25, 2009 Report Share Posted August 25, 2009 I've started to use this mod today, after I've been using several others - so far it's the best one, so thanks a lot for all the efforts and sharing. I have 2 questions - I looked for answers on this topic, but it seems nobody discussed about this. There are 2 basic functions, very useful for me, that are working on my PND using iGo 8.x: - a way to switch between distance/time to destination and to the next via; this is possible on PND when pressing the area with those indications - a way to recalculate the route for various events: e.g. stop by next gas station, detour for the next x kilometers, drop next via point (very useful when the via was placed just to force the route on a particular road). Thank you again. Quote Link to post Share on other sites
ill.die.trying Posted August 25, 2009 Author Report Share Posted August 25, 2009 I've started to use this mod today, after I've been using several others - so far it's the best one, so thanks a lot for all the efforts and sharing.I have 2 questions - I looked for answers on this topic, but it seems nobody discussed about this. There are 2 basic functions, very useful for me, that are working on my PND using iGo 8.x: - a way to switch between distance/time to destination and to the next via; this is possible on PND when pressing the area with those indications - a way to recalculate the route for various events: e.g. stop by next gas station, detour for the next x kilometers, drop next via point (very useful when the via was placed just to force the route on a particular road). Thank you again. as much as i wanted to help you i can't, i have upgraded to 3.0 and have started a new set of mods to work for it, the only way i could help you out is to revert back to 2.0 and mod the file but it's going to eat atleast 1 hour just reverting back, for your request, 1) yes it is possible to toggle between the two, you just need to copy some scripts from CMH's/GTIMATT mod for the toggle button 2) not sure what you're referring to Quote Link to post Share on other sites
catastrat Posted August 27, 2009 Report Share Posted August 27, 2009 Thanks for replying. I would love to move to iGo 8.3, but as I said on another topic, I did update to fw 3.0101, but having an US unit and living in Europe, I have to stick with the old ezrider and 8.0 maps for now, as I was unable to make the hacked ezrider 3.0 towork. For 1): can you point me to that code, ideally with some guidance? Although I've been using GTiMatt's one and I don't remember having that feature For 2): let's say there is an active route. Pressing a button (or accessing a menu) would bring up a menu for recalculating the route, wit the following options: - Drop next via point - useful when there is a multipoint route and you simply want to drop the next via (inserted just to force the unit to calculate a particular route) - Detour next 1/2/5/10 km - useful if there is a roadblock ahead, for finding alternative route - Add a via along the route (e.g. stop at the next gas station). I know this should be possible, as I have it on my PND running iGo 8.x. Quote Link to post Share on other sites
catastrat Posted September 1, 2009 Report Share Posted September 1, 2009 I have two questions related to this mod, as I was not able to figure it out: 1. Is there any way to have the car speed displayed when there is a route, the same like when there is no route selected? I know I can use one of those 3 selectable info fields, but that would be too small. 2. Also about speed: is there any way to show the speed limit info from the map, also without using one of those 3 selectable fields? Something like the speed limit in a red circle. Thank you. Quote Link to post Share on other sites
ill.die.trying Posted September 1, 2009 Author Report Share Posted September 1, 2009 I have two questions related to this mod, as I was not able to figure it out:1. Is there any way to have the car speed displayed when there is a route, the same like when there is no route selected? I know I can use one of those 3 selectable info fields, but that would be too small. 2. Also about speed: is there any way to show the speed limit info from the map, also without using one of those 3 selectable fields? Something like the speed limit in a red circle. Thank you. 1) you could add this script on your navigatemap_800_480.ui just under the current clocked speed section 2) if you have the setting turned on then they should show up if the map data has the speed limit available Quote Link to post Share on other sites
Join the conversation
