jgcir1 Posted September 10, 2014 Report Share Posted September 10, 2014 Usual Disclaimer: These files are for hobbyist use only. Use them at your own risk I can not be responsible for your actions if something goes wrong. Make sure you take a backup of your system prior to any changes *************************************************************** This Update is for V3 Firmware only *************************************************************** Contained in this release: Test mode for V3 Australian Sensis R16.1 Map (Released June 09) 3D Bulidings 3D Petrol Stations Updated POI's Updated Speed Cam Spoken Street Name Corections (Phoneme.ph file) Map Warning Bypass Updated EzRider Updated SYS.TXT Udated Map License files Updated Terrain (more detailed evevations) This release has been tested on the Australian AVIC-F900BT Download files from {C}http://www.4shared.com/file/160754980/9 ... part1.html{C} {C}http://www.4shared.com/file/160828063/9 ... part2.html{C} or {C}http://www.4shared.com/dir/24382274/615 ... dates.html{C} Instructions This update will just fit on a 1Gb SD card but it is advisable to use a SD card greater than 1Gb. 1. Start your AVIC normally and verify you have the V2 Firmware installed. 2. Check your map version. Go into Settings / Navi Settings / About / Maps Your Maps will display Sensis R15.1 3. Check your frirmware version. Go into Settings / System Settings / Service Information Next to Version you must have 3.xxxxxx 4. Extract this update to the root of an empty SD card. Do not modify the directory structure and extract both files. The best software to extract with is winrar 5. Insert the SD card and Start the AVIC 6. Use Test mode to backup your unit. Make a Directory called "Backup" on the below storage card and copy "My Flash Disk" to this directory Read the AVIC411 Faq's If you are unsure on Test Mode or make a backup 7. Copy The directories below Storage Card\My Flash Disk to "My Flash Disk" on your AVIC. Overwrite files as needed 8. Restart Your AVIC 9. Verify you have the new Maps Go into Settings / Navi Settings / About / Maps The Map will now be "Australia R16dot1 Sensis 10. Verify you have Buildings Working. Zoom into a CBD location to see buildings 11. Verify you have updated POI's. Open POI's and search for McDonalds, you will find it under restaurants if browsing POI's 12. Verify Warning Bypass. Go to the map scraeen and restart the AVIC. Press Map and check the warning is bypassed Enjoy 34by151 Hey man. Any chance you'd be able to reupload these somewhere? Would seriously, seriously save my life. Quote Link to post Share on other sites
Join the conversation
