Jump to content
AVIC411.com
external hard drive issues. can anyone help?
ok no worries, any thoughts on how i can get it to automatically recognise the hard drive is there after switching it off? i have got it on a 32kb cluster/allocation size but sill wont automatically recognise it and i still have to unplug and plug back in again on the usb
Hmmm, not sure about it. Mine is always recognized automatically after startup, but sometimes it takes a while. How do you have it powered? Might be a timing issue...
Link to post
Share on other sites
  • Replies 49
  • Created
  • Last Reply
Top Posters In This Topic
At the moment i have it wired to a house hold extension lead with it plugged in to test it out untill i can hard wire it to the actual car at the weekend. Going to hook it up to a 12v line from the rear of the HU so if its a timing issue hopefully that will sort it.
Link to post
ok so i had the f700bt installed in my mustang a couple days ago. and i purchased a 250G external hard drive because i was told i could upload songs/vids to the hard drive and plug it into the USB connection in my glovebox. so i did just that. but when i plug the hard drive into the USB the f700 isnt recognizing it, the USB key is still grey on the screen. anyone have an idea what might be wrong? any help is greatly appreciated. thank you
The drive probably requires too much power for the AVIC. Try getting an external drive that can take power from the cigarrete lighter and only use the USB for data (not data and power).
Link to post
ok so finally I got my y cable and tried it with my f900. first things first recognition of the drive takes like 2 or 3 mints. Also it is not recognized if it was plugged in as the unit starts. I have to unplug my drive and then plug it back in and after like a mint or mint and a half the drive is recognized. My drive as I stated earlier is a seagate 250 gig freeagent go black. I have about 23 gigs of mp3s on it and they work pretty well. The only problem I have is that I have to unplug and replug my drive every time the unit starts. Other then that everything else is fine and I can live with the late drive recognition.
Link to post
have you tried formatting it with a cluster size of 32k?
Link to post
Ramon: So your squeelin' pig finally powers up, right? The recognition thing with the HD is a problem.
I wanted to update you...I finally got 29.9GB of music on my 32GB Verbatim flash and it is working just as the 16GB does. I can turn off my rig, come back, start it up and after 30 sec to 1 min music starts playing again right where it left off. I'm thinking that this might just be the way to go unless I read that someone has got the HD thing dialed in.
Let me know when you get 40+GB of Music on your 250
? Boris: How much music do you have on your HD now?
Link to post
Oh yah I got the squealer under control. And also I realized that plugged in from the start the system does recognize the hard drive it just takes time. I found out that the damn usb car lighter thing I use is a bit loose and that is why it dosnt recognize from the start up. Also the cluster size is 32 kb Since fat32formatter always formats to that cluster size. A flash drive sure does sound convenient. Who knows if I get problems pat 40 gigs I might just switch to a 64 gig one or maybe a 1.8 hard drive. On another note I have been look at the linux os that seems to be running on the f-series and was wondering what space limits that might have. Just a thought though I am not running to get my unit bricked or anything any time soon.
Link to post
It's running Windows...
Link to post
I have a Western Digital Passport Portable Hard Drive 500gb. I used the 12v to 5v cigarette lighter to usb adapter and it works fine out of the box.
I have the same issue with it not booting up from a cold start. I need to unplug and plug it back into the hard drive to get it to recognize. Is there anyway to make it recognize without doing so?
Link to post
My 100GB won't cold boot either.. same issue. Mine is powered properly, and I formatted it with the Windows CE disk management, also trying 32KB cluster sizes previously. I think it's a problem with recognizing certain volume sizes upon boot in Windows CE.. I'm not sure though. It would be nice if someone found a fix. But yes, it does work fine once the unit is booted and I re-plug it.
For reference, I'm using a 100GB hard drive. At the moment I have a little over 17GB of music, and 28GB of TV shows on it. I'm adding more and more every day. I have around 165GB of music but haven't loaded my HDD up with much yet. I don't listen to half the music I have.. lol. A lot of it is my brother's and friend's that I backup on my server for them.
Link to post
I don't think so.. I wish there was a folder tree list like the audio. :( I just put mine in folders by show/season. Then when I jump from folder to folder, I can tell by the short label I tagged the folder with. It sucks, but it's the only way I know to navigate it.
Link to post
I know boris had it start from a cold start and maybe someone else. I have seagate freeagent go 250 and it sometimes got recognized from a cold start until I found out that my usb adapter was faulty and got a new one. Now it dosnt start unless I unplug and plug it back in.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
