Jump to content
FINALLY: NO MORE RED DIAMOND ICON
  • Please log in to reply
59 replies to this topic
#46 N-S-E-W
N-S-E-W
    Member
  • Members
  • 685 posts
Posted 14 March 2010 - 08:04 PM
I never saw a diamond on my unit with the sys.txt entry listed above.
As you can see here i get the diamonds but only on this screen which is okay, i'm happy with it.
[attachment=0]abb diamond.jpg[/attachment]
Since I don't ever use the 2d view, I never noticed that. Good to know. Thanks!
#47 Hube2002
Hube2002
    Member
  • Members
  • 172 posts
  • LocationHeart of the South U.S.A.
Posted 19 March 2010 - 01:05 AM
Finally had time to follow up on this more. I looked through Diaftia's mod and noticed in his data file he had 3 sub folders in his icon folder (poi, pioneer_poi & sys) All three have the multipoi.icon file.
VBLUE42 stated earlier that
If your on 3.0 the path to find the multipoi.icon has changed. Its in data.zip/ui_pioneer/icons/sys
This is true but i noticed that Alex had the multipoi.icon file in all 3 folders but the only one with the values changed to 79 from 74 was in the poi folder, the other two remain at 74, I followed this and added the multipoi.icon file back to the poi folder and it does indeed remove the red diamond in 2D mode
So you guys are both correct, I guess, but if you want the diamond gone on all screens then you will have to have the file in the poi folder. At least this is what finally fixed it for me in all modes, I no longer have any diamonds anywhere and I'm sure you can accomplish this by just the changing of the value as VBLUE42 had stated. It just seems that it has to be in the poi folder, regardless of the same file being in the other 2 folders.
Make any sense?
Hube2002
2006 F-150 King Ranch
Avic F-900BT
#48 Chuck88
Chuck88
    Established Member
  • Members
  • 1412 posts
  • LocationCanada
Posted 07 April 2010 - 03:39 AM
Hey VBLUE42, is it possible that the red diamond icon is still show in the 2D view?
Thanks.
Chuck88
Enjoy every bit of life but don’t take it too seriously, because you won’t make out of it alive anyway!
#49 VBLUE42
VBLUE42
    Established Member
  • Moderators
  • 8798 posts
  • LocationMS
Posted 07 April 2010 - 03:55 AM
It doesn't on my unit. I am using Diaftia's mod.
2010 SCION TC, iPhone 5, SPH-DA100 APPRADIO 2, APPRADIO EXTENSIONS, ROCKFORD FOSGATE 3SIXTY.2 PROCESSOR, POLK DXI 6500 COMPONENTS IN FRONT, JL AUDIO SEALED POWER WEDGE 12" SUB, SMITH & WESSON.
#50 Chuck88
Chuck88
    Established Member
  • Members
  • 1412 posts
  • LocationCanada
Posted 12 April 2010 - 08:00 PM
When zipping back to DATA.zip after modifying multipoi.icon, can someone remind me which method to use?
1) With 7-Zip, zip to DATA.7z, then rename to DATA.zip; or
2) With 7-Zip, directly zip to DATA.zip; or
3) With WinZip or any other zip utility, directly zip to DATA.zip.
I always use method #2 and it works. But if I use method #1, the file size is signficantly smaller. Please note that Image.res is zipped with method 1. However, 7zip.dll is not presented in the iGo folder.
Thanks.
Chuck88
#51 Chuck88
Chuck88
    Established Member
  • Members
  • 1412 posts
  • LocationCanada
Posted 13 April 2010 - 12:06 PM
1) NOT working.
2) WORKING.
3) NOT working.
Chuck88
#52 Marlysa
Marlysa
  • Members
  • 18 posts
  • LocationFrance - Paris
Posted 05 June 2010 - 09:17 AM
Hello,
On my Avic [European F900BT upgraded in F910BT] with
[poi]
use_multi_poi_icon=0
I don't have any red diamond in 3D mode and I can see all icones. But in 2D, I already have this red diamond.
Do you have any suggestion to remove this diamond and show all icones (The solution to hide all icons is not good for me and I prefer to have the red diamond)
Member of AVIC411.com Forum and French AVIC Forum
The french AVIC Forum presents many tutorials, Tools and Tips for AVIC Fx00 and Fx10.
#53 Chuck88
Chuck88
    Established Member
  • Members
  • 1412 posts
  • LocationCanada
Posted 05 June 2010 - 11:42 AM
Hi Marlysa,
For the 2D fix, there is a file called multipoi.icon in your ui_pioneer\icon\poi folder under the DATA.zip. All you have to do is open it, change the value of both lines from 74 to 79, and rezip it.
Voila!
Chuck88
#54 Marlysa
Marlysa
  • Members
  • 18 posts
Posted 05 June 2010 - 06:39 PM
Hi Chuck88,
I already did it but this replace the diamond icon by a blank one and we don't see anymore if there is some POI or not. I don't like this solution and I prefer to have the red diamond.
For your information I found a solution to do it without any modification of the data.zip. [We are testing this solution with some other french AVIC users and I'll come back to explain here how to do it :wink: ]
My previous asking is to know if it is possible to display all icons in 2D view even if there is an overlap (Like in 3D).
#55 VBLUE42
VBLUE42
    Established Member
  • Moderators
  • 8798 posts
  • LocationMS
Posted 05 June 2010 - 10:48 PM
No.
#56 Chuck88
Chuck88
    Established Member
  • Members
  • 1412 posts
  • LocationCanada
Posted 06 June 2010 - 01:09 AM
Hi Marlysa,
I afraid that I have to say no, like VBLUE42 had said. In the 2D mode there is no such thing as graphic overlay, so impossible to display one icon over another.
A bit off topic, since you have a forum, can you help me for this one: I have smartzoom enabled but I find that the default zoom is too far (I want the view to get closer to the car or the arrow). What is the [SmartZoom] parameter that I have to adjust in order to default a closer zoom distance? This should be set in the SYS.TXT file.
I tried defaultzoom3d=xxx parameter but didn't work (=100 or =2000 is the same). Any idea?
Chuck.
Chuck88
#57 Hube2002
Hube2002
    Member
  • Members
  • 172 posts
Posted 27 June 2010 - 03:34 AM
Hi Guys, don't know if anyone else has posted on this, I been away for a minute, but i just formatted my unit to get rid of junks files that had accumilated and decided to go with the FX3.1 Complete Firmware Image thread to see if it was an improvement over what I had and the first thing I noticed when I was in split screen was a kfc icon in 2d mode, never seen it before, after i got rid of red diamond there were no icons in 2d until today. Again, this might not be news but was a first for me.
http://avic411.com/f...hp?f=34&t=32351
on a different note, i have always used winrar for zip files because i can click on the file and a window opens to show contents without unzipping. I edit all the files in this window as well as drag and drop to overwrite, it confirms the change and then i just close the window. No unzipping and re-zipping. it is very simple and the best program i have ever used for zip files, it's on the bay, as all good things are :)
Hube2002
Avic F-900BT
#58 Marlysa
Marlysa
  • Members
  • 18 posts
Posted 03 July 2010 - 10:06 AM
Hello,
As I promised some days ago, I found a solution to suppress the red icon without any modification in data.zip. My solution is to introduce in branding.zip some specific files:
In folder: \ui_pioneer\icons\poi\ add this file:
multipoi.icon
$poi_mapclose.spr	79
poi_mapclose.spr	79
[Nota]
As bonus, I give you another tip to have your own icon for your personnal POI (For the example I consider my File AVICMBkml.bmp]
In folder: \ui_pioneer\icons\poi\ add this files: kmlpoi.icon
$AvicMBkml.spr	0
AvicMBkml.spr	0
And place you personnal icon and its .spr file in folder: ui_pioneer\common\
For the example: AVICMBkml.bmp and AVICMBkml.spr
BmpFlags = 0
DefFlags = ALPHA_PIXEL | ALPHA_LAYER
DefPhase = 1
Stripes = 30
DefAlpha = 22
#59 LRR1215
LRR1215
  • Members
  • 13 posts
Posted 25 April 2013 - 12:27 AM
Hey guys ive tried every which way to do this but i alway keeps getting the error when i reload into my avic. I always unzip the DATA.ZIP file make the changes to the multipoint.poi to 79 save the file, Rezip it. And then overwrite the previous DATA.ZIP file and it never works? ive tried zipping from my mac, from windows, nothing ever works?
i get an program application database not found or something like that error upon boot up it says system is starting up and then it just reboots. As soon as i put the original DATA.ZIP file back startup works fine again...ive tried changing the sys.txt file too with no luck? any other ideas
i know i did it the write way because its not rocket science here....
#60 LRR1215
LRR1215
  • Members
  • 13 posts
Posted 25 April 2013 - 07:46 AM
ok got it taken care of
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
