tycoonbob Posted April 28, 2009 Report Share Posted April 28, 2009 Alright, so I finally got my Avic-F90BT to boot back up and back to normal. I had the problem that a lot of other people have been having lately, and that problem is the one where the unit boots to the splash screen, goes black, and the illumi-buttons go off. Then it re-boots and does that over and over again. Here is a simple, anti-fancy guide as to how I fixed my problem. **[WARNING]. Step-by-step: 1] Copy the firmware 2.0 update to your SD card, as if you had an old firmware version and you were updating it to the 2.0 version. All this does is stabilizes the unit and keeps the screen lit-up allowing you to enter test-mode. [Download can be found here 2a] Pop your SD card back into your computer, delete the 2.0 update, and copy testmode onto your SD card. [A guide to using testmode can be found here 2b] Copy a back up copy of myflashdisk to that same sd card. NOTE: MAKE SURE YOU HAVE THE RIGHT VERSION OF THE FILES. (i.e., if you have a F90BT...only the F90BT files will work, F900BT on the F900BT, and the F700BT on the F700BT. That was my problem on getting mine fixed) --F90BT Back-up files can be found here --F900BT [anyone have a link to these files???] --F700BT [anyone have a link to these files???] 3a] Now that you have your appropriate back-up files and the testmode files on your sd card, put the sd card in your AVIC, and start your car. Go into testmode like you always have, and first and for most...make sure ALL the back-up files are on your SD card. [i take no responsibility if they are not and your mess your unit up] 3b] Open "myflashdisk" inside the file explorer on your AVIC, click Edit>Options, and uncheck all 3 of those boxes allowing all files to be seen. Hit ok. No Click Edit>Select All, then click File>Delete. Click "yes to all" if it pops up, and allow it to delete all files. This can take a few minutes. After this is finished, ensure there is no files left in "myflashdisk". If there is, delete them one by one til they are all gone. 4] Go back a screen, and open your SD card. Move the "Testmode" and the "MiTACAP" folders out of the way by click and dragging them, and select all the other files. Click Edit>Copy. Go back, and open "myflashdisk" once again. Click Edit>Paste. Allow all those files to copy over, which can take 10+ minutes. 5] Once that is done copying over, Ensure there is the same amount of files/folders in "myflashdrive", as there is on your sd card [there should be 2 additional folders on your sd card, those are your testmode folders]. close File explorer just to ensure all is done. 6] Turn your car off, remove the sd card, start the car back up. Your AVIC should boot-up like the day you had it installed. You will loose your contacts, saved info, and all that...but you have a working $600-1000 radio again. **[WARNING]. If you have any questions, problems, comments, whatever...post and I will see what I can do. Thanks. Quote Link to post Share on other sites
matt1212 Posted April 30, 2009 Report Share Posted April 30, 2009 ALL THIS ISNT EVEN NECESSARY Just got off the phone with pioneer who told me that this problem occurs because the unit is bypassed, which it is. They said it would have to be wired correctly to fix the issue. I refuse to accept that. I was able to fix my unit myself. It would show the splash screen for about 10 seconds then go to a black screen. After the black screen was up for about 45 seconds i would have to press the map button and then the screen would show. Not the end of the world but annoying none the less. It turns out the problem is in the backup camera setting (i have no backup camera connected). Go into settings>system settings>backup camera both buttons will appear unselected. push the off button, back out of the settings screen, and try turning the car on and off. Unit should reboot normally. This worked for me hope it works for you too. Quote Link to post Share on other sites
Pioneer4x4 Posted May 1, 2009 Report Share Posted May 1, 2009 i have no backup camera connected. Do you have the backup wire connected? Quote Link to post Share on other sites
StatiK76 Posted May 1, 2009 Report Share Posted May 1, 2009 success for me. thank you! Quote Link to post Share on other sites
tycoonbob Posted May 2, 2009 Author Report Share Posted May 2, 2009 matt1212, that fix didn't work for me. I have no back up camera, and the reverse wire isn't hooked up. I pulled the unit out, removed the yellow wire [by-pass] and hooked it up properly, and it never fixed anything. Pushing the buttons made no sound, and did not keep the screen on. What I did, worked for me. Mines fixed, so I'm glad. Quote Link to post Share on other sites
Raydee Posted May 3, 2009 Report Share Posted May 3, 2009 I can't get past step one....Even with the update SD card in the unit won't stay on. It lights the buttons for about 10 seconds and then shuts down. I can hear the fan running but that is about it. Quote Link to post Share on other sites
tjacobsn Posted May 4, 2009 Report Share Posted May 4, 2009 I just bought the Scion XB & it had came with the Pioneer Avic F900BT. I have had the car for a few weeks now & just had the XM tuner installed. Everything has been installed properly...but now I had the screen go black & not turn on. So, I tried to install the 2.0 firmware but when it is almost finished, I get an error message that reads, [Error Code = 18 message = 'mabe disk space is sizefull']. I cannot get past that section. However, now my system is rebooting as mentioned in this thread. So, I was going to try the test mode solution. But, I don't think I have the back up files. Can I just use the files from the update? What should I do? Quote Link to post Share on other sites
badassgoat Posted May 5, 2009 Report Share Posted May 5, 2009 http://www.avic411.com/forum/viewtopic.php?f=33&t=23922 Quote Link to post Share on other sites
funk101 Posted May 10, 2009 Report Share Posted May 10, 2009 Thanks to tycoonbob for the instructions and minifreezer for posting the necessary backup files! I had the reboot issue mentioned above on my f90 and everything is working fine now. For those having problems getting into testmode because your unit keeps rebooting before recognizing the SD card: I pressed the RESET and eject buttind at the same time, then let go of the reset and keep holding eject for a few more seconds. You will notice that the led's start to "breathe". I guess that's some type of safemode reboot? Not really sure what it is or where I read to do it, but it works and allows the unit to reboot for testmode access. Quote Link to post Share on other sites
tjacobsn Posted May 14, 2009 Report Share Posted May 14, 2009 Best solution for me....take the car back to the dealer & have them take care of it! It worked...I got a whole new system & they told me that it was a short that caused it. No matter...it works & I love it! Does anyone know how to back up the system? How do I save the custom screen at start up? Quote Link to post Share on other sites
tia Posted May 14, 2009 Report Share Posted May 14, 2009 I have the avic f900bt with the 2.0 firmware update. Unit worked great for first couple months, then one morning decided to show exact same problem. Unit would light up and show splash screen then black out. Tried the reset button but nothing seemed to work. Read the post for reinstalling the firmware update and was just about to attempt all of that but thought would try one last thing first. I started it up, same thing.. went to the black screen, after it was in this screen i pressed and held the reset button at the same time as the eject button for 5 seconds and ...presto she was working again. Not sure what this did, but tried all aspects and seems to be working fine again... Lets hope it stays that way!!! Quote Link to post Share on other sites
sebshep18 Posted May 18, 2009 Report Share Posted May 18, 2009 i was wondering if anybody can help me, iv done this and its kind of working although the splash screen dosnt come on and i have to press the menu button to view the home screen, then one the home screen only the contacts button works all the others allow me to press them and acknowledge they have been pressed but dont seem to be linked to anything i have deleted all the information twice and its still not working. i used the "F-Series F90BT Backup Files" that are on this site they are around 1.6gb but im not sure what the file structure is, there dosnt seem to be as many files from when i saw the original set of files before it broke any help will be great or any ideas thanks Quote Link to post Share on other sites
xcritic Posted May 18, 2009 Report Share Posted May 18, 2009 Add me to this list, experienced the same problem last night on my f700 and now the unit is useless. I tried reinstalling the 2.0 update, but it only makes it to 37% than gives error 18 (something about being out of memory). But now at least it will freeze at the splash screen and if I push the map button it will drop me into the brightness settings, and i can move around from there, but nothing actually works. Does anyone have a f700bt backup they can send me so i can try fixing this thing. I can setup a ftp if necessary if you email me at david@struvedesigns.com. I'm really avoiding having to send this thing back to pioneer for repair. Quote Link to post Share on other sites
sebshep18 Posted May 19, 2009 Report Share Posted May 19, 2009 can anybody help im really stuck, i have used these files and it has worked thanks, but all i can press is the settings buttons, which then all i can press inside there is system settings not the av sound or av button the screen registers the presses and changes the images as if they have been touched but dosnt bring up the next page, ie if i press the av button on the main menu it dosnt bring up the page to select what AV i want and that is the same on all the buttons im not sure what controls this any help would be great thanks again Quote Link to post Share on other sites
xcritic Posted May 20, 2009 Report Share Posted May 20, 2009 Thanks to another gsxr for the f700bt files, unfortunately It appears the flash drive has been corrupted with 200+ un-deletable files that are using up the space necessary to install the new files. So off to pioneer it goes, and they better have a good fix because my warranty is up next month and I dont want to do this again. Quote Link to post Share on other sites
