wiretap Posted May 8, 2009 Report Share Posted May 8, 2009 I received my Pioneer AVIC-F700BT today, so finally I could get my radio put in. The full install took me about 3.5 hours, and honestly, it went flawlessly. The Evo is by far the easiest car to work on. There's a ton of room.. and I mean a ton of room (behind the dash, glove box, and places to route cables). Everything snaps apart and back together really easily. I think I only had to use a philips screw driver twice. (for the dash trim piece removal, well, and the radio mounts of course) Parts: - Pioneer AVIC F700BT - Pioneer GEX-P920XM - Scosche Dash Kit - 2008+ Mitsubishi Radio Harness I started in the trunk with installing the XM box to get that out of the way. I found the perfect place for it. Used velcro to hold it in place... Then I ran the power and ground over to the battery. The antenna will go straight up on the rear window deck inside. You'll see a picture of that later. The IP-bus cable for the XM unit has to be routed to the front of the car. I removed the back seat bottom to make routing the cable easy, as well as removing the floor trim pieces. Now you have access to the whole cable run tray. The little holders just snap open and closed, so it makes cable routing super easy. From there, the cable gets routed behind the glove box and into the radio area to be plugged in later. I also ran the GPS antenna for the AVIC at the same time to make things easy. I put that on the rear window deck next to the XM receiver. Removed the factory radio. Put the factory vents into the Scosche dash kit. Then I switched gears and felt like running the microphone for the telephone and voice command. I found the perfect spot in the map lights area. It just pops out with no tools required. I routed cable through the headliner and over to the passenger side A-pilar, down behind the rubber stripping, then down behind the glove box and into the radio cavity. Now all the cables have been routed and they're awaiting install. I took a short break and worked on the wiring harness. Notice I did the video bypass trick by grounding the 'mute' and 'parking brake' wires. You also have to move the mute wire to a different pin on the harness. The tutorial is found here: http://avic411.com/wiki/index.php/Hand_Brake_Bypass I then went ahead and put the stock brackets onto the AVIC, plugged everything in, screwed the radio in place, and put the Scosche dash kit on. It looks great! Fitment: Here's the GPS and XM antennas on the rear window deck. They're coming through the child restraint door. (I removed it) Put the trunk all back together and put some wire loom on the wires coming from the XM unit. And in case anyone missed it, here's my glove box mod, which enables USB power for connecting a 2.5'' hard drive to the AVIC unit. Tutorial: viewtopic.php?f=34&t=24072 Finally, it's done! I tested for full functionality, GPS, XM, AM, FM, bluetooth...all working! I didn't mess around much.. I threw a custom boot screen on it, put the test mode files on a SD card, then booted it into Windows mode to make some backups of the unit's files before I go about modding it. Quote Link to post Share on other sites
lludacrisboy Posted May 8, 2009 Report Share Posted May 8, 2009 Absolutely Beautiful!! Great Job! I really love it. Quote Link to post Share on other sites
wiretap Posted May 8, 2009 Author Report Share Posted May 8, 2009 Thanks. Quote Link to post Share on other sites
jamesgaunt Posted May 27, 2009 Report Share Posted May 27, 2009 how is the bluetooth mike sound? I have a mitsubishi outlander with the same map light fitting i was gonna drill it and pass the mike through but yours looks more stealth. Quote Link to post Share on other sites
wiretap Posted May 28, 2009 Author Report Share Posted May 28, 2009 The mic works great. People say they can hear me perfectly, and there's no echo/feedback on their end either. Quote Link to post Share on other sites
R0ME0 Posted August 17, 2009 Report Share Posted August 17, 2009 Do you have SSS? How did you tie it in with the Rockford Amp? Also do you have the diagram of where you tied in the speed sensor wire or is there one? Quote Link to post Share on other sites
wiretap Posted August 22, 2009 Author Report Share Posted August 22, 2009 Don't have the SSS. Didn't use the speed sensor wire---although it is on the harness that's behind the dash already. It's harness C107 pin 31, white with blue stripe. Here's the Rockford Amplifier connection method. http://forums.evolutionm.net/evo-x-audi ... works.html Metra Harness: http://forums.evolutionm.net/evo-x-audi ... -02-a.html Quote Link to post Share on other sites
PMC52 Posted August 7, 2010 Report Share Posted August 7, 2010 How is your XM reception with the antenna inside the car? Quote Link to post Share on other sites
KevinR Posted June 5, 2011 Report Share Posted June 5, 2011 did you order the stock nav bracket from dealer? im looking to do this.... shop used metra kit and the kit itself holds the nav in and its not mounted with brackets. Quote Link to post Share on other sites
