scottf876 Posted May 22, 2009 Report Share Posted May 22, 2009 I have a Z1, upgraded to Z3. I have the bypass, but it always stays in DAY mode. What did I do wrong? The illumination wire? Should it be hooked up? And if so, to what? Thanks in advance, and sorry about the ignorance. Quote Link to post Share on other sites
Hyperite Posted May 22, 2009 Report Share Posted May 22, 2009 I have a Z1, upgraded to Z3. I have the bypass, but it always stays in DAY mode. What did I do wrong? The illumination wire? Should it be hooked up? And if so, to what? Thanks in advance, and sorry about the ignorance. Illumination wire should be hooked up to the illumination wire of your car. Quote Link to post Share on other sites
scottf876 Posted May 22, 2009 Author Report Share Posted May 22, 2009 Yeah, thats what I thought. I'm pretty sure it is. But its always on DAY. I'll double check to make sure. Thanks Quote Link to post Share on other sites
jwq Posted May 22, 2009 Report Share Posted May 22, 2009 Yeah, thats what I thought. I'm pretty sure it is. But its always on DAY. I'll double check to make sure. Thanks You can check it works in the "hardware" menu.... (settings > hardware > connections ) Quote Link to post Share on other sites
