shaker281 Posted April 26, 2010 Report Share Posted April 26, 2010 I have a F900BT and just performed to 3.0 update and It seems to be OK. I have a few questions. 1. I see there is no 3.02 update on the Pioneer site for F900BT, but a 3.0201 for the F910BT. Are people applying 3.0201 to their F900BTs? What value is it? 2. What map version is this unofficial 3.0 equipped with? Is it 2009.06 TA? Exactly, how can you determine this? BTW, I was able to perform the update using a single 1 Gb SD card. I just removed the "Map" folder (from (/igo/content) and copied over everything else. Popped out the SD card and deleted all but testmode and then copied back and pasted the "map" folder to "/igo/content" directory. FWIW. Quote Link to post Share on other sites
shaker281 Posted April 27, 2010 Report Share Posted April 27, 2010 I should add that my "Map Version" under System Information says 2.000300. Are there more up-to-date US Maps? Quote Link to post Share on other sites
Zoidbort Posted April 29, 2010 Report Share Posted April 29, 2010 Just bought the F90BT off eBay so I would love to do this "update" but the links are dead for the 3.0 file. Any new links or can someone host it by chance? Cheers! Quote Link to post Share on other sites
djpez2001 Posted April 29, 2010 Report Share Posted April 29, 2010 thanks everybody for all the information posted here, without it I would not have been able to update my AVIC. I did have some problems updating as many of you have had, the rebooting every five minutes, the freezing of the maps, and the system startup banner not going away, but thankfully I was able to fix it. I am not certain what the problem was, but I believe when I tried to do the speed mod on my mac that's when the problem started. In order to correct I erased everything from My Flash Disk/USER/UserData/iGo/Save on the AVIC. I also erased everything from My Flash Disk/USER/UserData/iGo/SETUP also on the AVIC. The original DATA.zip file from the download I do not think it was corrupted, but when I unzipped to modify the speed settings and then zipped it back up...something must have happened that corrupted the file and my unit would not read it properly, so I reloaded on the AVIC just the DATA.zip and everything was ok after rebooting. But like I said, everything is running fine and I got 3.0 update on my unit. Thanks for all the good information guys. Quote Link to post Share on other sites
shaker281 Posted May 4, 2010 Report Share Posted May 4, 2010 Just bought the F90BT off eBay so I would love to do this "update" but the links are dead for the 3.0 file. Any new links or can someone host it by chance? Cheers! See the bottom of page 40 for the links I used last week. Quote Link to post Share on other sites
Guess Posted May 5, 2010 Report Share Posted May 5, 2010 I am from Lithuania (Europe), can i do this (US units) update? Or i must do update with EU units? Quote Link to post Share on other sites
Retell Posted May 6, 2010 Author Report Share Posted May 6, 2010 Hey guys, I am going to pick up my F90bt tomorrow, so I'll be back in the game. Torrent and other links should be online tomorrow, just paid my hosting bill Quote Link to post Share on other sites
Ford1 Posted May 8, 2010 Report Share Posted May 8, 2010 3.0 up and running! I'm not sure if it was the vodka or what but after I thought about it this morning I realized that the original post was a little different on step 11. I made the proper adjustments and there you have it. Thanks for the hulp abb1. Now the MODS....... Quote Link to post Share on other sites
Retell Posted May 8, 2010 Author Report Share Posted May 8, 2010 Sorry for the delay guys, I will be making a new thread tonight containing a new torrent of what I like to call AVIC FX3.1. It contains: Windows CE 6 firmware X Series 3.0201 update NavTeq 2009Q2 USA/Canada maps No nag screens Trip Computer POI Branding Speed camera/red light mod Software speed hack Quote Link to post Share on other sites
Chuck88 Posted May 11, 2010 Report Share Posted May 11, 2010 Just want to post the link to Retell's post for new readers of the forum: http://www.avic411.com/forum/viewtopic.php?f=34&t=32351 Enjoy. Quote Link to post Share on other sites
DavidAl Posted May 31, 2010 Report Share Posted May 31, 2010 So reading the posts still don't get it I have a AVIC-F900BT with version 2.0 upgraded from factory specs and want 3.0 so will this one :AVIC_X-Series_Firmware_Update_3.020100 work for me ? Quote Link to post Share on other sites
dvine1 Posted June 4, 2010 Report Share Posted June 4, 2010 HackZ wrote: Ok so i am having issues with the park where: Once you see Step 7: Wait till it says restart in the bottom center. I see that just fine. I swap out my SD car with the card that has the test mode files on it. Then i press RESET with a pin Then the unit reboots then I see test mode and a box with a blue loading bar. Now here is the ISSUE Once the bar moves to half way the unit restarts and goes BLACK.... Driving me crazy... p.s i picked: choose update only WITH FORMAT OPTION This is the exact same problem that I'm having with the 3.1 upgrade!!!! HELP ME PLEASE!!!! Quote Link to post Share on other sites
MyITGuy Posted June 5, 2010 Report Share Posted June 5, 2010 HackZ wrote:Ok so i am having issues with the park where: Once you see Step 7: Wait till it says restart in the bottom center. I see that just fine. I swap out my SD car with the card that has the test mode files on it. Then i press RESET with a pin Then the unit reboots then I see test mode and a box with a blue loading bar. Now here is the ISSUE Once the bar moves to half way the unit restarts and goes BLACK.... Driving me crazy... p.s i picked: choose update only WITH FORMAT OPTION This is the exact same problem that I'm having with the 3.1 upgrade!!!! HELP ME PLEASE!!!! If your seeing the test mode, after you removed the SD card and after the reset then you copied the entire SD card to your unit. Start the process over and only copy the CONTENTS of the "My Flash Disk" folder on the SD Card to the "My Flash Disk" drive on your unit. Quote Link to post Share on other sites
nyce hoffa Posted June 18, 2010 Report Share Posted June 18, 2010 Is there anyway I cn get my ipod Touch 3.1.3 to work with this unit?? Quote Link to post Share on other sites
Chuck88 Posted June 18, 2010 Report Share Posted June 18, 2010 Is there anyway I cn get my ipod Touch 3.1.3 to work with this unit?? It should be working ... check the Pioneer compatibility chart at their website. Quote Link to post Share on other sites
