Jump to content
U310BT Parking Brake Bypass
  • Please log in to reply
38 replies to this topic
#31 cmason100
cmason100
  • Members
  • 3 posts
Posted 18 March 2010 - 05:30 PM
I can access the menus when stopped at a red light, engine running. Just seems odd to me. Some functions are "dim" when the car is in motion, and full functionality (as far as I can tell) comes back when the car stops. Those functions that were "dim" are now "bright". Hope that makes sense.
#32 s????
s????
  • Members
  • 18 posts
Posted 18 March 2010 - 06:00 PM
Have you used the GPS menus when the car is stopped, or just observed the buttons light up? In the "Important Information" flyer than comes with the unit it states the following:
To prevent such functions from being used while the vehicle is in motion, there is an interlock system that senses when the parking brake is set and when the vehicle is moving. If you attempt to use the functions described above while driving, they will become disabled until you stop the vehicle in a safe place, and apply the parking brake.
It reads as though even if the buttons aren't dimmed it will lock you out if you try to use them. You ought to check into that and let us know. If it continues to work while stopped without the brake connected then that would be great, since it gives you a little more flexibility and saves you the trouble of hooking up the brake. I suppose you do risk a future firmware update breaking that functionality (so do bypassers!), but it's not like you can't hook it up the brake as intended if that were to happen.
#33 cmason100
cmason100
  • Members
  • 3 posts
Posted 19 March 2010 - 01:20 AM
yeah, so I checked this afternoon on the ride home. The buttons are dim when the car is rolling, but as I come to a stop light they become active and I am able to use them. I typed addresses, searched POIs, etc. It all appears to work even with the green wire disconnected. As soon as the light goes green and the car is rolling the lights go dim again. Strange I know.
#34 s????
s????
  • Members
  • 18 posts
Posted 21 March 2010 - 06:51 PM
Strange but neat. I'm sure this will help someone else down the line who is thinking of leaving the brake wire unconnected. Thanks for sharing!
#35 tbone
tbone
  • Members
  • 3 posts
Posted 29 April 2010 - 04:08 AM
I installed my U310BT about 2 weeks ago and have the same situation. While driving there are operations of the Navi system that are dimmed out and will not function but as I slow down and reach approx 5 mph they come to life. I have not wired the safety wire to anything at this point but after reading the info here I plan on trying the grounding trick. Not sure how the system knows (what it is monitoring) when I get down around 5 mph but the unit has done this from day one. Still trying to figure out the AVIC Feeds program I downloaded but not having much luck to this point ... but something to mess with.
#36 1loudls
1loudls
    Install Expert
  • Members
  • 2239 posts
  • LocationAnn Arbor MI, USA
Posted 29 April 2010 - 02:32 PM
well the unit is using GPS to track your movement, and is accurate enough to know exactly how fast you are going.
MECP Advanced AutoTech
2003 Lincoln LS V8
AVH-X3500BHS                 AVIC-F900BT (retired)
Alpine Type R components (x2) powered by Kicker SX600.2 (x2)
Kicker 15" L7 (x2) powered by a Kicker SX1250.1
Springfield XDm
#37 tbone
tbone
  • Members
  • 3 posts
Posted 07 May 2010 - 04:17 AM
Whoops ... sorry about that one ... I guess I didn't look at the obvious. I was thinking more mechanical.
#38 alexo1us
alexo1us
  • Members
  • 2 posts
Posted 28 September 2010 - 03:25 PM
Just thought I would throw my 2 cents
on this model the parking brake wire senses ground (not positive) the PB switch (on most) completes a ground for the light to turn on in the dash.
This is a nav unit so I grounded mine to ground wire in the harness on my 310 it shows the parking brake on.
Since it has been mentioned and I did do a test it work with out connecting the green wire and uses the satnav as a motion sensor of sorts. Which is why it turns off some more thought and attn processes when moving. (pretty smart)
For the 310 the PB wire is sort of a manual override bypassing satnav function.
Since the PB is almost never on and I want my passenger (me most times) to be able to work the thing when driving. I hooked mine up.
On a side note this unit has work perfect so far its accurate and fast recalulates fast for stops and side trips.
for the price this is the best SatNav with audio funtion on the market.
I should also point out I'm on OS version 0002
#39 pionara
pionara
    Member
  • Members
  • 780 posts
Posted 04 January 2012 - 06:37 PM
update for this thread... while hacking u310bt 2.x update, we noticed that grounding PKB alone was insufficient to disable safety mode...
see thread: here .. need to additionally ground KMODE pin 13...
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
