impulsive.ca Posted August 3, 2009 Report Share Posted August 3, 2009 Here's the problem: I installed an AVIC-F90BT (premiere) headunit a year ago. I performed the Pioneer Firmware upgrade to fix a few of the popular issues (bluetooth, boot-up time, nav bugs, etc.. as it has its own built-in flash drive). Everything worked perfectly afterwords, until about 3 months ago when I noticed the headunit would never remember what screen/menu it was at last when I'd turn the car back on. It remembered what source to use, but would always boot-up in the main menu instead of going to the source screen/map or where ever it was before I'd turn the car off. I had the same issue in the AVIC-F900BT I have in another car I have. I resolved it by going into the headunit's O/S (using testmode via an SDcard), deleting all the files on the unit's flash drive and replacing them with a complete OEM file backup. Ever since then, that units worked wonderfully. To make a long story short, I did the same thing on the AVIC-F90BT. However, something must have happened after I deleted the files on the flash-drive, because now I can't even get into the unit's O/S to put the back-up files back in. It just turns off completely just before loading up the O/S (which is windows CE). I've looked up the issue on here and have only found 1 thread where someone has had this issue, where the person ended up sending it to Pioneer. Now, I bought it on eBay and I'm not sure of the warranty status on it. I'd really rather not go months without music in my car, hence why I'm trying to figure out if there's something I can do that I may not be informed of. I've tried going to local Pioneer distributors, but all they do is sell/install.. Not repair. Short of sending the unit to Pioneer, is there anything I've overlooked? Is there anything I can do? Any help would be GREATLY appreciated!! Quote Link to post Share on other sites
impulsive.ca Posted August 3, 2009 Author Report Share Posted August 3, 2009 13+ views and no reply? c'mon guys... Quote Link to post Share on other sites
pwnin o'brien Posted August 3, 2009 Report Share Posted August 3, 2009 Can you get into the service menu? If you can, then try updating WinCE to the latest version (the version that comes with 3.0). Make sure you use the Format option, this will clear the flash memory completely. Once the WinCE update is finished, try going back into TestMode. Quote Link to post Share on other sites
impulsive.ca Posted August 3, 2009 Author Report Share Posted August 3, 2009 Nope, testmode initializes fine, then just as it's about to finish the unit turns off. And I mean completely off.. the backlit buttons, screen.. everything goes black. But I can still hear the unit's fan spinning, meaning there is power going to it. I want to contact Pioneer and ask them what to do, but as it's a civic holiday here in Canada, they're closed. Quote Link to post Share on other sites
impulsive.ca Posted August 3, 2009 Author Report Share Posted August 3, 2009 I'll give service mode a try. I'm pretty sure I can do a WinCE update and get back into testmode. If I can do that, I can load up the OEM files and fix the system properly. I'll post up the results as soon as I can. ...Fingers crossed... Quote Link to post Share on other sites
impulsive.ca Posted August 3, 2009 Author Report Share Posted August 3, 2009 Well, so much for that. I'm able to get into service mode, but the unit shuts off after roughly 13-15 seconds. No matter what I do, the unit simply turns itself off (yet the cooling fan is still on? wtf) after a short amount of time.. No where near enough time to do anything. FAWWKK!!!!!! Quote Link to post Share on other sites
pwnin o'brien Posted August 3, 2009 Report Share Posted August 3, 2009 Are you absolutely sure you entered the service menu correctly? When I was updating WinCE I was pressing the buttons incorrectly. If you do not press them right, it will still go into the service menu, but the screen will shut off after 10 or so seconds while the power remains on. Also, if you only do a partial format (if the unit restarts during the WinCE updating process), the unit will go to a black screen on startup. The correct process to get into the service menu is as follows: 1. Immediately after turning your key to accessory, you want to hold the Reset, Eject, Map, and Menu buttons. 2. After four or five seconds (the screen will still be black), you want to release the reset button. 3. After a couple of seconds, you will get the blue service menu screen, release the eject button. 4. After you release the eject button, you can release the Menu and Map buttons simultaneously. Before pressing any buttons, wait to make sure the unit will stay booted in the service menu. Wait approximately 15 seconds to be sure. If it stays booted, then you are good and you should be able to restore the unit from there. Quote Link to post Share on other sites
impulsive.ca Posted August 3, 2009 Author Report Share Posted August 3, 2009 Alright, I was finally able to stay in a stable Service Mode screen. I updated the winCE img using the one from the 2.06 firmware update. I rebooted the system with an SD chip inside with the Testmode folders. It comes up with an error message regarding mapDBxxxx. roughly 3 seconds after the error message, the unit cuts again like the previous fashion. What now... Quote Link to post Share on other sites
pwnin o'brien Posted August 3, 2009 Report Share Posted August 3, 2009 My recommendation would be to do the 3.0 upgrade. Just re-update WinCE and copy all of the 3.0 files over. The tutorial on how to upgrade to 3.0 is floating around somewhere on here. Quote Link to post Share on other sites
tail24 Posted August 3, 2009 Report Share Posted August 3, 2009 You need to download and use the testmode v2.3 I'm order to access that firmware correctly. Quote Link to post Share on other sites
another gsxr 1k Posted August 4, 2009 Report Share Posted August 4, 2009 I'd try using the v2.3 test mode files first before doing anything radical. If you can get in using the new test mode. you can restore your unit. just replace the mapDBxxxx. file Quote Link to post Share on other sites
impulsive.ca Posted August 4, 2009 Author Report Share Posted August 4, 2009 Thanks fellas. I'll give this a shot this evening once I get home from work. Will keep you posted! Quote Link to post Share on other sites
impulsive.ca Posted August 5, 2009 Author Report Share Posted August 5, 2009 Alright, so I did everything as instructed in the WinCE 3.0 update thread to a tee. I got the new WinCE img in using service mode, was able to get into test mode 2.3 and transfered the files over (x910 backup) and the 'data' files just fine. I reboot the system, took the SD card out, pressed reset and eject (as instructed) and hoped to see a nice Pioneer splash screen come up. Yeah, instead I get a black screen and nothing else. The unit stays on though and doesn't shut itself off after 15-ish seconds. The only thing I did that I -think- I may have done wrong is transfered the contents of the 'data' folder directly into the igo folder, meaning there isn't a 'data' folder in the 'igo' directory, just the files. Was that my mistake? If so, how do I go about undoing it? If not, what else could be the problem?? Quote Link to post Share on other sites
tail24 Posted August 5, 2009 Report Share Posted August 5, 2009 Go back in with test mode... Copy the whole x910 and put it on there let it run... dont touch anything after that. See if it loads up. Quote Link to post Share on other sites
impulsive.ca Posted August 5, 2009 Author Report Share Posted August 5, 2009 should i do another wince format first? or just delete the files on the unit's flash-drive and copy all the x910 files back on it? Quote Link to post Share on other sites
