hanibal Posted March 3, 2010 Report Share Posted March 3, 2010 awsome were do i put the fuel calculator and how do u acess it on the deck? Quote Link to post Share on other sites
ill.die.trying Posted March 3, 2010 Author Report Share Posted March 3, 2010 awsome were do i put the fuel calculator and how do u acess it on the deck? Â when navigating a shortcut for it will pop up, regarding on where to put the fuel calc you have to read the instructions Quote Link to post Share on other sites
hanibal Posted March 3, 2010 Report Share Posted March 3, 2010 I want to place it on another mod not yours? Quote Link to post Share on other sites
ill.die.trying Posted March 3, 2010 Author Report Share Posted March 3, 2010 I want to place it on another mod not yours? Â like i previously said, i don't have the time right now to do it, i'm actually taking a break from modding and just wanted to release this mod before i do Quote Link to post Share on other sites
nissanfrontier Posted March 3, 2010 Report Share Posted March 3, 2010 Thank you for updating this for us. I have been using this since the first release and will never change. Hope all is well up there. Quote Link to post Share on other sites
bigboy Posted March 3, 2010 Report Share Posted March 3, 2010 Great mod thanks . are you planing to add left/right announce of destination to your mod .Thanks in advance. Quote Link to post Share on other sites
ill.die.trying Posted March 4, 2010 Author Report Share Posted March 4, 2010 Great mod thanks . are you planing to add left/right announce of destination to your mod .Thanks in advance. Â AFAIK the sys.txt already has the code neede for the announcement, you just have to find a compatible tts file , Quote Link to post Share on other sites
N-S-E-W Posted March 5, 2010 Report Share Posted March 5, 2010 seriously haven't had time to do it, maybe later on, i'm trying trying to work all the hours i could as i just found out that we're going to be laid off within two weeks, Â Damn, sorry to hear that, IDT. You've definitely have had your share of bad luck. Keep plugging away. It's bound to get better. Quote Link to post Share on other sites
ill.die.trying Posted March 5, 2010 Author Report Share Posted March 5, 2010 seriously haven't had time to do it, maybe later on, i'm trying trying to work all the hours i could as i just found out that we're going to be laid off within two weeks, Â Damn, sorry to hear that, IDT. You've definitely have had your share of bad luck. Keep plugging away. It's bound to get better. Â i just really hope it gets better, i think i've already suffered enough, Quote Link to post Share on other sites
JonA2B3 Posted March 5, 2010 Report Share Posted March 5, 2010 I've loaded v5.5 onto my unit, but when I press the FuelCalc or MapChanger it states Utility is not installed or Utility is not installed. I thought I loaded the Extension folder in the proper place, MYFLASHDISK\APL2\IGO\CONTENT \, but I must be missing a step somewhere. Any help would be appreciated. Quote Link to post Share on other sites
ill.die.trying Posted March 5, 2010 Author Report Share Posted March 5, 2010 I've loaded v5.5 onto my unit, but when I press the FuelCalc or MapChanger it states Utility is not installed or Utility is not installed. I thought I loaded the Extension folder in the proper place, MYFLASHDISK\APL2\IGO\CONTENT \, but I must be missing a step somewhere. Any help would be appreciated. Â it should be in MYFLASHDISK\APL2\IGO\, not in MYFLASHDISK\APL2\IGO\CONTENT \ Quote Link to post Share on other sites
JonA2B3 Posted March 5, 2010 Report Share Posted March 5, 2010 Ok I will do that but this Note is what threw me off. Â NOTE to users, some users use gallons so here's instructions for it, this is assuming that your in testmode 1) go to MYFLASHDISK\APL2\IGO\CONTENT \Extension\Fuelcalc and delete the contents, Quote Link to post Share on other sites
ill.die.trying Posted March 6, 2010 Author Report Share Posted March 6, 2010 Ok I will do that but this Note is what threw me off. NOTE to users, some users use gallons so here's instructions for it, this is assuming that your in testmode 1) go to MYFLASHDISK\APL2\IGO\CONTENT \Extension\Fuelcalc and delete the contents,  thats an error on my part, ill updat the instructions, thanks for pointing out Quote Link to post Share on other sites
nissanfrontier Posted March 8, 2010 Report Share Posted March 8, 2010 IDT, thanks again for this. But I knew I should have left well enough be. Anyways, i sent my AVIC into a slow reboot now. I think it was mainly because I didn't use 7-zip, but regardless I put the old files back and it still does it. Â I'll figure that part out, but had a question on the #7 of the directions. Is there another thread that explains the maps part, or could you help me there. Â Do I delete the old maps folder? Quote Link to post Share on other sites
ill.die.trying Posted March 8, 2010 Author Report Share Posted March 8, 2010 IDT, thanks again for this. But I knew I should have left well enough be. Anyways, i sent my AVIC into a slow reboot now. I think it was mainly because I didn't use 7-zip, but regardless I put the old files back and it still does it. I'll figure that part out, but had a question on the #7 of the directions. Is there another thread that explains the maps part, or could you help me there.  Do I delete the old maps folder?  the only thing you have to do is to create a new folder and name it as map_nt, this is where you would put other maps that you prefer (NAVTEQ, or even a newer or older version of TA), do not delete your map folder, also, copy the basemap.fbl file from your map folder and paste it to the map_nt folder Quote Link to post Share on other sites
Join the conversation
