buddhabar Posted September 16, 2009 Report Share Posted September 16, 2009 Here comes one of scheme I use! JohnCougar1-Day.zip Quote Link to post Share on other sites
buddhabar Posted September 16, 2009 Report Share Posted September 16, 2009 I don`t know if sys.txt I use is wrong one. because I edit sys.txt from 746UC to 749EW. Quote Link to post Share on other sites
spiceditup Posted September 16, 2009 Report Share Posted September 16, 2009 the latest one has the most current update regarding it, though i still have to poslish something regarding the color changer on the date and time but aside from that everything is a-ok I see, so as of right now there is no fix for manually changing the clock colors right? pushing the day scheme would easily fix it, the problem here is on the initial start up, after the first boot it would work i'm having a problem with changing the color of the clock with v4.3. Normally, i would go into navigatemap_800_480.ui and change the clock colors - ;TIME but this color converts back to stock (black with yellow highlights), I'm not having this problem with the V3.5. Quote Link to post Share on other sites
ill.die.trying Posted September 16, 2009 Author Report Share Posted September 16, 2009 Here comes one of scheme I use! [attachment=0]JohnCougar1-Day.zip[/attachment] they are the same with the one i'm using, proceed with the reloading of the files and let me know how it goes, if you could post a pic of it that would be great Quote Link to post Share on other sites
ill.die.trying Posted September 16, 2009 Author Report Share Posted September 16, 2009 the latest one has the most current update regarding it, though i still have to poslish something regarding the color changer on the date and time but aside from that everything is a-ok I see, so as of right now there is no fix for manually changing the clock colors right? pushing the day scheme would easily fix it, the problem here is on the initial start up, after the first boot it would work i'm having a problem with changing the color of the clock with v4.3. Normally, i would go into navigatemap_800_480.ui and change the clock colors - ;TIME but this color converts back to stock (black with yellow highlights), I'm not having this problem with the V3.5. that is because there's some scripts in navigatemap.ui that sets them to a color depending on the time of the day Quote Link to post Share on other sites
spiceditup Posted September 16, 2009 Report Share Posted September 16, 2009 pushing the day scheme would easily fix it, the problem here is on the initial start up, after the first boot it would work i'm having a problem with changing the color of the clock with v4.3. Normally, i would go into navigatemap_800_480.ui and change the clock colors - ;TIME but this color converts back to stock (black with yellow highlights), I'm not having this problem with the V3.5. that is because there's some scripts in navigatemap.ui that sets them to a color depending on the time of the day ok, that i understand, but is there a way to change what color the script is using? Nevermind, i think i found the solution. Thanks IDT. Quote Link to post Share on other sites
ill.die.trying Posted September 16, 2009 Author Report Share Posted September 16, 2009 pushing the day scheme would easily fix it, the problem here is on the initial start up, after the first boot it would work i'm having a problem with changing the color of the clock with v4.3. Normally, i would go into navigatemap_800_480.ui and change the clock colors - ;TIME but this color converts back to stock (black with yellow highlights), I'm not having this problem with the V3.5. that is because there's some scripts in navigatemap.ui that sets them to a color depending on the time of the day ok, that i understand, but is there a way to change what color the script is using? Nevermind, i think i found the solution. Thanks IDT. i'll figure something out regarding this, i'm currently looking for something to reference night and day so that proper colors will be set for them, Quote Link to post Share on other sites
spiceditup Posted September 16, 2009 Report Share Posted September 16, 2009 ok, that i understand, but is there a way to change what color the script is using? Nevermind, i think i found the solution. Thanks IDT. i'll figure something out regarding this, i'm currently looking for something to reference night and day so that proper colors will be set for them, I changed the default colors of the script for both day and night view. What do you guys think? Quote Link to post Share on other sites
buddhabar Posted September 16, 2009 Report Share Posted September 16, 2009 Here comes one of scheme I use! [attachment=0]JohnCougar1-Day.zip[/attachment] they are the same with the one i'm using, proceed with the reloading of the files and let me know how it goes, if you could post a pic of it that would be great I reloaded all files but no solution. I can`t load any pic. right now. can it be wrong that edit sys.txt 746EW??? Quote Link to post Share on other sites
hanibal Posted September 16, 2009 Report Share Posted September 16, 2009 I changed the default colors of the script for both day and night view. What do you guys think? I like the way the clock is bigger!! How do we make the clock bigger? Quote Link to post Share on other sites
ill.die.trying Posted September 16, 2009 Author Report Share Posted September 16, 2009 Here comes one of scheme I use! [attachment=0]JohnCougar1-Day.zip[/attachment] they are the same with the one i'm using, proceed with the reloading of the files and let me know how it goes, if you could post a pic of it that would be great I reloaded all files but no solution. I can`t load any pic. right now. can it be wrong that edit sys.txt 746EW??? what unit do you have? Quote Link to post Share on other sites
ttorski Posted September 16, 2009 Report Share Posted September 16, 2009 ok, that i understand, but is there a way to change what color the script is using? Nevermind, i think i found the solution. Thanks IDT. i'll figure something out regarding this, i'm currently looking for something to reference night and day so that proper colors will be set for them, I changed the default colors of the script for both day and night view. What do you guys think? Are you using my data.zip - window for the clock is coming from my file, made by IDT for me Quote Link to post Share on other sites
buddhabar Posted September 16, 2009 Report Share Posted September 16, 2009 f500bt eu Quote Link to post Share on other sites
ill.die.trying Posted September 16, 2009 Author Report Share Posted September 16, 2009 f500bt eu did you change the device type to reflect F500? try that Quote Link to post Share on other sites
lotust Posted September 17, 2009 Report Share Posted September 17, 2009 forgive me if this has been discussed before. But on my F500BT I can see all the schemes when booted up. I can see them on the flash drive. IS the 500BT just too old to see them? Hardware wise? thanks Quote Link to post Share on other sites
Join the conversation
