djoker04 Posted November 8, 2006 Report Share Posted November 8, 2006 I have 4 monitors in my armada and Have 3 AND the DVD player going to the Fuse box via a dual in-line fuse holder. My Q? is should i use a the proper Fuse AMP for the slot (10) and use a lower for the other or go higher. When Connected it's causing a Batt drain. My other opt is to connect them to a switch and turn it off when I get it out. Thanks in advance Karl Quote Link to post Share on other sites
cntrylvr79 Posted November 8, 2006 Report Share Posted November 8, 2006 Are they hookes up to a constant power feed? If so then move them over to an igniton controlled feed this way they'll turn off when you shut the truck off. Quote Link to post Share on other sites
djoker04 Posted November 9, 2006 Author Report Share Posted November 9, 2006 Are they hookes up to a constant power feed? If so then move them over to an igniton controlled feed this way they'll turn off when you shut the truck off. Yes. I have it like that so that the dvd won't turn off if i stop and have to restart and find the last point of view. What I might do is remove the monitors from that line and place them on ignition conrol and have the dvd on Constant Pwr. I just might go back to my other dvd I had that maintained memory when I turned it off. Thanks AW. K Quote Link to post Share on other sites
