johnread5629 Posted May 4, 2014 Report Share Posted May 4, 2014 Ron S. Newbie here, can you explain or throw me a link on how to apply a patch offset. I have upgraded to 5.0. Quote Link to post Share on other sites
Alexei Navalny Posted May 4, 2014 Report Share Posted May 4, 2014 Ron S. Newbie here, can you explain or throw me a link on how to apply a patch offset. I have upgraded to 5.0. Are you asking how to patch the file, or how to install it in the HU (using testmode)? Either way, I can't give you keypress by kepress instructions from memory. You need a hex editor on your PC - I use free HxD. It is pretty easy. You can use the file NAVI.exe from the SD you used to do the install. I recommend copying it to the PC, modifying it, then copy the modified file to a different SD along with testmode.key - don't loose the original just in case. Insert the SD in the HU, it should boot into TestMode Go to File Maintenance Navigate to /USER If PRG.FLG exists, go to PRG1 folder, otherwise go to PRG0 Delete NAVI.exe Navigate to your SD and select NAVI.exe them select COPY Go back to where you deleted (/USER/PRG0 or PRG1) and paste the file. Remove the SD and reboot. Quote Link to post Share on other sites
rgarjr Posted May 6, 2014 Report Share Posted May 6, 2014 I have the 110BT upgraded to the 5.0 FW. Can someone with the same unit and FW post the modified NAVI.exe file. Quote Link to post Share on other sites
mds2004 Posted May 26, 2014 Report Share Posted May 26, 2014 Can someone post the modified Navi.exe for a 110 modified with the 5.1 Application version? Thanks Quote Link to post Share on other sites
mds2004 Posted May 26, 2014 Report Share Posted May 26, 2014 I cannot see BE9A4, but only BE9A0. I have a Z110bt upgraded to 5.1. Should I upgrade this line instead? Thanks Quote Link to post Share on other sites
Alexei Navalny Posted May 27, 2014 Report Share Posted May 27, 2014 I cannot see BE9A4, but only BE9A0. I have a Z110bt upgraded to 5.1. Should I upgrade this line instead? Thanks Sounds like you don't understand how a dump works. The line you highlighted starts at 0xBE9A0 and shows 16 (0x10) bytes. The next line starts at 0xBE9B0. So the patched bytes would start in the 5th column : BE9A0, BE9A1, BE9A2, BE9A3, BE9A4...... Quote Link to post Share on other sites
mds2004 Posted May 30, 2014 Report Share Posted May 30, 2014 Sounds like you don't understand how a dump works. The line you highlighted starts at 0xBE9A0 and shows 16 (0x10) bytes. The next line starts at 0xBE9B0. So the patched bytes would start in the 5th column : BE9A0, BE9A1, BE9A2, BE9A3, BE9A4...... Thanks that makes more sense. I edited the file and it worked. Quote Link to post Share on other sites
AvYogi Posted January 11, 2016 Report Share Posted January 11, 2016 Has anyone explored how to disable this with the NEX units (8100, 7100, etc)? Quote Link to post Share on other sites
