Jump to content
AVIC411.com
Anyway to get rid of the caution screen "ok" on bootup?
  • Replies 82
  • Created
  • Last Reply
Top Posters In This Topic
Ron S.
Newbie here, can you explain or throw me a link on how to apply a patch offset. I have upgraded to 5.0.
Are you asking how to patch the file, or how to install it in the HU (using testmode)?
Either way, I can't give you keypress by kepress instructions from memory.
You need a hex editor on your PC - I use free HxD. It is pretty easy.
You can use the file NAVI.exe from the SD you used to do the install. I recommend copying it to the PC, modifying it, then copy the modified file to a different SD along with testmode.key - don't loose the original just in case.
Insert the SD in the HU, it should boot into TestMode
Go to File Maintenance
Navigate to /USER
If PRG.FLG exists, go to PRG1 folder, otherwise go to PRG0
Delete NAVI.exe
Navigate to your SD and select NAVI.exe them select COPY
Go back to where you deleted (/USER/PRG0 or PRG1) and paste the file.
Remove the SD and reboot.
Link to post
Share on other sites
  • 3 weeks later...
I cannot see BE9A4, but only BE9A0. I have a Z110bt upgraded to 5.1. Should I upgrade this line instead?
Sounds like you don't understand how a dump works. The line you highlighted starts at 0xBE9A0 and shows 16 (0x10) bytes. The next line starts at 0xBE9B0. So the patched bytes would start in the 5th column :
BE9A0, BE9A1, BE9A2, BE9A3, BE9A4......
Link to post
Thanks that makes more sense. I edited the file and it worked.
Link to post
  • 1 year later...
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
