GPS Favorite backup from firmware v2 to v3 ???
favourites.dat in the igo/user/userdata/save folder.
it may be in the apl2/user/userdata/save now that I think of it.
My Flash Disk\User\UserData\iGO
EZRider from 3 picks up favorites.dat from 2.0 just fine.
  • 1 month later...
well, on my unit, my favourites were lost after the update (legit). Maybe because i clicked not to keep my boot screen. Anyway, thanks for the info, i will try to restore them from my backup
Update wipes out everything in saved iGO preferences (those aren't compatible between 2 and 3), regardless of boot screen option. If you have the backup, just restore favorites.dat and you should be all set though.
  • 2 weeks later...
My Favouites tab simply does not come on after the update....it is not highlighted so cannot click on it altogether...
This is because your favorites.dat got overwritten with the upgrade, so there are no favorites saved. As explained, you need to take the favorites.dat file from your backup (you DID make a backup, right?) and copy it to the /user/userdata/save folder in MY Flash Disk.
-Eric
-Eric
there is no file called favourites.dat in my user/userdata/save folder in my backup....i have 2 different backups of my f500bt flash disc........one on an external HD and one on my PC. Both backups dont have favourites.dat file in the user/userdata/igo/save
any ideas or suggestions wat i should do?
Try looking in my flash drive\user\userdata\igo\save if you have any favourites then that is where they will be in favourites.dat. :)
That is where i looked. There is no file by that name...not in my flash drive backup on my pc and not even on my F500 unit. I went to my flash drive\user\userdata\igo\save through wince as well and there is no favourite.dat file....
i basically have no favourite.dat file...not in my backup and not even in my unit....
pls help cause i need them favourites....thanks
hm, might be a stupid question, but still: Did you ever add any favs and if yes, how exactly did you do it. You don't happen to look for the recent adresses? Those are in a different file - unfortunately I don't know, but it will be in save-folder and the name will content "recent" - I suppose.
