CNDV-900HD 2009 Map Update Install Completed
Ok so I have a question. If the 900HD image files are now available then this should be as simple as burning everything to an 8.5gb dual layer dvd and then using the created back up copy disc to update the Z1-Z3's correct? I've done this in the past for a factory nav that I have in one of my cars. Just wondering why it would still be necessary to go in and pull hard drives out and get cable adaptors, etc.
I'm kinda new to working with the pioneer updates & hacks so bare with me 8)
  • Replies 93
See the following thread for the info you seek: viewtopic.php?f=20&t=9446
The Z will not read the upgrade DVD disc without a password. The password is generated on the Pioneer website and requires the Media Key (from the update DVD, and can only be used once), and the serial number of the Z. If you do not enter the correct password, the Z will not update. If you own 2 Z's and only buy 1 update DVD, you can only update one unit. See the catch?
Anyone else experience their backup camera is now mirrored from what it was before the upgrade?
I had to cut a tiny jumper loop on the camera during install to reverse the image so it'd be appropriate to view and use to back up, and now there's no way I'll be able to solder it back.
Seemed to be a problem in my camera. I've had power issues in the car that I had to resolve with a battery replacement. My camera is tapped into a wire that's always hot, so I think the fluky power supply must have messed it up. I power-cycled it by removing the fuse and the problem was resolved.
Hey G35mass, I downloaded the files and when I went to extract it asked for a password. I assumed it was avic411.com but I keep getting and error saying wrong password.!
C:\Documents and Settings\Desktop\z1 files\Z3_2009_virgin_torrent.part044.rar: CRC failed in the encrypted file z3_2009_virgin6.tib (wrong password ?)
It has said this for every tib file. Any help would be aprreciated.
Dan
The file was corrupted, re-download it.
I see my rapidshare uploads have been downloaded by a numerous people. How is it working? Any problems? Sometimes the .rar files get corrupted, especially when the original files are so large
G35mass,
Thank you for the rapidshare uploads. However I downloaded the files and when I was extracting it went to part 008 then error, I continued the extraction then had an error on a eight or nine other parts???. I redownloaded the files and made certain that I used the correct password(avic411.com) and again had exactly the same problem??? Has anybody downloaded and extrcted succsessfully? Maybe I am not downloading or extracting correctly. Please advise
Thank you,
Henryj
I have downloaded from G35 Mass' links and posted it over on megaupload for those that need it.
http://www.megaupload.com/?d=6BAQ1F5A
http://www.megaupload.com/?d=0ESFP2X0
http://www.megaupload.com/?d=91WZUT4M
http://www.megaupload.com/?d=U2O4VQ5I
http://www.megaupload.com/?d=2GMMT28U
http://www.megaupload.com/?d=UCXPN2H8
http://www.megaupload.com/?d=FX052QBC
http://www.megaupload.com/?d=XS65JVHM
http://www.megaupload.com/?d=RHZ6KLJ2
http://www.megaupload.com/?d=MPU94X0T
http://www.megaupload.com/?d=EZC2RCAH
http://www.megaupload.com/?d=GVOYL0F8
http://www.megaupload.com/?d=BLJTJ89G
http://www.megaupload.com/?d=G0WQVC83
http://www.megaupload.com/?d=FAYMCAH4
http://www.megaupload.com/?d=VAJ5GIYE
http://www.megaupload.com/?d=60IY2R6O
http://www.megaupload.com/?d=YZHYYJ3H
http://www.megaupload.com/?d=WF5NOX9Z
http://www.megaupload.com/?d=O42UMVHP
http://www.megaupload.com/?d=J80GO1KJ
http://www.megaupload.com/?d=8R7Y18SY
http://www.megaupload.com/?d=8FG8HZOH
http://www.megaupload.com/?d=DZ9YACPB
http://www.megaupload.com/?d=LLL4P5M1
http://www.megaupload.com/?d=R58LRK6G
http://www.megaupload.com/?d=X1TWRAHE
http://www.megaupload.com/?d=3L83WEF0
http://www.megaupload.com/?d=60A62OMM
http://www.megaupload.com/?d=Z4G9M61X
http://www.megaupload.com/?d=AFXYE88T
http://www.megaupload.com/?d=GP0VSXIJ
http://www.megaupload.com/?d=E1ZH7UD3
http://www.megaupload.com/?d=XAV1HDC2
http://www.megaupload.com/?d=U16QP7N2
http://www.megaupload.com/?d=5N09USS0
http://www.megaupload.com/?d=EOCBUDCK
http://www.megaupload.com/?d=77ZE9NHY
http://www.megaupload.com/?d=ZCQRNL3J
http://www.megaupload.com/?d=2W55FW2K
http://www.megaupload.com/?d=WDFWJ09X
http://www.megaupload.com/?d=CGRNO1DD
http://www.megaupload.com/?d=HJH8LMW9
http://www.megaupload.com/?d=DCJEI0WL
http://www.megaupload.com/?d=HAPKC6U8
http://www.megaupload.com/?d=HFNLWJQW
http://www.megaupload.com/?d=RVSRY4MN
http://www.megaupload.com/?d=KOS3NDK2
http://www.megaupload.com/?d=SS0KDZEW
http://www.megaupload.com/?d=08JFOKQK
http://www.megaupload.com/?d=ALWJX0SD
http://www.megaupload.com/?d=PFIUU38X
http://www.megaupload.com/?d=LA9RUNQR
http://www.megaupload.com/?d=ULEZFJDL
http://www.megaupload.com/?d=80KCQ4EX
http://www.megaupload.com/?d=3NYGW4L2
http://www.megaupload.com/?d=SLG28D46
http://www.megaupload.com/?d=P409RTUQ
http://www.megaupload.com/?d=5VH8VHBT
http://www.megaupload.com/?d=N73X0GWE
http://www.megaupload.com/?d=PKVTS4LZ
http://www.megaupload.com/?d=IM5HJ1PN
http://www.megaupload.com/?d=6O2HOOAO
http://www.megaupload.com/?d=GA5QH1BQ
http://www.megaupload.com/?d=S07BCRBY
http://www.megaupload.com/?d=203ZL603
http://www.megaupload.com/?d=02HXVSQX
http://www.megaupload.com/?d=IDDH49P9
http://www.megaupload.com/?d=NV43FXSD
http://www.megaupload.com/?d=P4NEQXH0
http://www.megaupload.com/?d=GFJ6HWEV
http://www.megaupload.com/?d=ZNQ7F8RH
http://www.megaupload.com/?d=5Q7LXT2K
http://www.megaupload.com/?d=DJGUMMHN
http://www.megaupload.com/?d=CU9AG4RN
http://www.megaupload.com/?d=XTUE73SA
http://www.megaupload.com/?d=89Y6B7WZ
http://www.megaupload.com/?d=ZPGKICVR
http://www.megaupload.com/?d=RAJESWIO
http://www.megaupload.com/?d=QXGQ7XSE
http://www.megaupload.com/?d=TOGGTMH6
http://www.megaupload.com/?d=MSL98AXZ
http://www.megaupload.com/?d=DKGEYTK1
http://www.megaupload.com/?d=CMTXQ4FQ
http://www.megaupload.com/?d=FLQF1OP8
http://www.megaupload.com/?d=HV5U01LF
http://www.megaupload.com/?d=10HJNRFI
http://www.megaupload.com/?d=AF44OWJ1
http://www.megaupload.com/?d=R962QCB5
