hanibal Posted February 22, 2010 Report Share Posted February 22, 2010 How do u just install the fuel calculation ? Quote Link to post Share on other sites
ill.die.trying Posted February 22, 2010 Author Report Share Posted February 22, 2010 How do u just install the fuel calculation ? what mod are you using? Quote Link to post Share on other sites
hanibal Posted February 22, 2010 Report Share Posted February 22, 2010 dpdurst 3.0 mod v1.5 Final Quote Link to post Share on other sites
ill.die.trying Posted February 22, 2010 Author Report Share Posted February 22, 2010 dpdurst 3.0 mod v1.5 Final i will try to create a how to regarding this for those who want to add the fuelcalc on their own mod, no ETA's as i'm busy right now but i 'll do it when i get a chance Quote Link to post Share on other sites
hanibal Posted February 22, 2010 Report Share Posted February 22, 2010 Thanks Quote Link to post Share on other sites
Hube2002 Posted February 22, 2010 Report Share Posted February 22, 2010 You have something messed up, I will see if I can send you my schemes and DATA.zip when I get done work. That should work providing that you hgave the GFX folder proerly installed Could it be corrupt images? I may be off base but some of the key images will not open and if i view them in a folder windows can't render a thumbnail image? i downloaded everything again and they come out the same but i am wondering if this is why changing the sky image in the gfx folder fixes some problems? notice in the screen shot you can see some images as thumbnails and not others and not the moon.bmp? is this what is causing the errors in certain schemes and why i never get a big moon? is this normal or is this part of the problem? Quote Link to post Share on other sites
ill.die.trying Posted February 23, 2010 Author Report Share Posted February 23, 2010 You have something messed up, I will see if I can send you my schemes and DATA.zip when I get done work. That should work providing that you hgave the GFX folder proerly installed Could it be corrupt images? I may be off base but some of the key images will not open and if i view them in a folder windows can't render a thumbnail image? i downloaded everything again and they come out the same but i am wondering if this is why changing the sky image in the gfx folder fixes some problems? notice in the screen shot you can see some images as thumbnails and not others and not the moon.bmp? is this what is causing the errors in certain schemes and why i never get a big moon? is this normal or is this part of the problem? it's not sorrupt, it's a compressed image, Quote Link to post Share on other sites
Hube2002 Posted February 23, 2010 Report Share Posted February 23, 2010 shows my skill level...no? Quote Link to post Share on other sites
speed Posted February 23, 2010 Report Share Posted February 23, 2010 Hey IDT Just wondering if you could tell me where to enable the signboards for the gps in the data.zip. Thanks Quote Link to post Share on other sites
Hube2002 Posted February 23, 2010 Report Share Posted February 23, 2010 I had a similar problem when I used Diaftias mod and Alex suggested I get a fresh 3.0 and start over, it fixed my problem then and i think i will revert back to that backup and start fresh.I think Abb1 is willing to help so i'm sure i'll get it figured out. Thanks for the quick answer. I really like your work. Quote Link to post Share on other sites
abb1 Posted February 23, 2010 Report Share Posted February 23, 2010 You have something messed up, I will see if I can send you my schemes and DATA.zip when I get done work. That should work providing that you hgave the GFX folder proerly installed Could it be corrupt images? I may be off base but some of the key images will not open and if i view them in a folder windows can't render a thumbnail image? i downloaded everything again and they come out the same but i am wondering if this is why changing the sky image in the gfx folder fixes some problems? notice in the screen shot you can see some images as thumbnails and not others and not the moon.bmp? is this what is causing the errors in certain schemes and why i never get a big moon? is this normal or is this part of the problem? I found out what the problem is with the schemes. The older schemes (easy, JohnCougar, Monopoly, Gerd, Realview, and pioneer default, day and night) have the background images corrupted. This was probably an oversight from DPHurst, I didnt even notice it as I did not use the older schemes much. THE GOOD NEWS I have fixed pretty much most of them except the Pioneer schemes as they are the default schemes and I didnt want to touch them. Keep the GFX folder in the IGO folder and leave it the way it is. Delete all schemes from the content folder. Install my Schemes into the content folder. I tested them and they are now all working. Make sure that you extract the SCHEMES.zip folder and then put the Schemes folder into the IGO folder and you should be good to go *PS---MAKE SURE THAT YOU HAVE THE IGO8 FOLDER INSTALLED IN YOUR DATA.ZIP BEFORE INSTALLING THESE SCHEMES Scheme.zip Quote Link to post Share on other sites
abb1 Posted February 23, 2010 Report Share Posted February 23, 2010 Hube2002, make sure that you have 'sky_night.bmp' in your GFX folder (I cant see as you have half the folder cut off in the pic) as that is the bmp with the big Moon and I have that bmp installed in a lot of these schemes, so if you do not have that file, you will get either a blank background or an error message Quote Link to post Share on other sites
Hube2002 Posted February 23, 2010 Report Share Posted February 23, 2010 cool...thought you'd never get home..lol... haven't had time to try it cause i just read it but i'm sure your right and i knew it would be you.... thank you..... Quote Link to post Share on other sites
figueroaw Posted February 23, 2010 Report Share Posted February 23, 2010 IDT, I don't know if is a bug or my unit, but the trip computer does not work for me. All numbers stay on zero. I have tested several time. ...with the previous version of your mod it work! Quote Link to post Share on other sites
ill.die.trying Posted February 23, 2010 Author Report Share Posted February 23, 2010 IDT, I don't know if is a bug or my unit, but the trip computer does not work for me. All numbers stay on zero. I have tested several time. ...with the previous version of your mod it work! trip computer is a known problem on all mods laeding us to believe that the problem is caused by the unit, Quote Link to post Share on other sites
