bogiedogie Posted November 17, 2009 Report Share Posted November 17, 2009 I see someone asked this already, but no one replied. will the parking brake bypass for the 700 work for the 710? Quote Link to post Share on other sites
RossGo Posted November 28, 2009 Report Share Posted November 28, 2009 I used to have a f700 and did a bunch of mods, my first being the speed sensor raise to allow constant video playing ability. However, I put the x710 in for my cousin and have been unable to get it to work so far. You need a newer testmode file to boot into windows, but when you change the speed sensor value it does not boot correctly. I am looking to find a way to do this so I hope someone can shed some light Quote Link to post Share on other sites
abb1 Posted December 2, 2009 Report Share Posted December 2, 2009 I used to have a f700 and did a bunch of mods, my first being the speed sensor raise to allow constant video playing ability. However, I put the x710 in for my cousin and have been unable to get it to work so far. You need a newer testmode file to boot into windows, but when you change the speed sensor value it does not boot correctly. I am looking to find a way to do this so I hope someone can shed some light YES, it will work! you must be doing something wrong. make sure that you follow ALL the directions and have both, the mute wire and parking break properly grounded. Also, if the mute pin is not properly connected in its socket, it will not work. Make sure that all the prongs are visible and look the same in the opening. Quote Link to post Share on other sites
