ndy4eva Posted January 21, 2010 Report Share Posted January 21, 2010 I tried out U310BT unit on my Jag last night. Everything seem to work fine. I used harness kit, and antenna kit for the wirings. I was pretty impressed with Pioneer sound quality compare to the factory radio. One thing that bothered me. Whenever I press hard key or touch-screen key, I hear the noise from the speakers. When there's music playing (mp3, cd or radio), it's very hard to notice. But when it isn't, you can hear the static noise. I did hard-wire by-pass for hand-brake. Would it create the noise? possible grounding issue? I guess I could disconnect hand-brake wire but I don't want to re-solder it later. Any thoughts or suggestions? Thanks! Quote Link to post Share on other sites
ndy4eva Posted January 25, 2010 Author Report Share Posted January 25, 2010 I tried without parking brake bypass. The static noise is still there. I think I might have faulty unit. Uhmmm... I think I will drop by the store ask for replacement. Quote Link to post Share on other sites
VBLUE42 Posted January 25, 2010 Report Share Posted January 25, 2010 Does your vehicle have a factory installed power amp? Quote Link to post Share on other sites
ndy4eva Posted January 25, 2010 Author Report Share Posted January 25, 2010 Nope.. The noise comes after the button release for about 1-2 seconds. Quote Link to post Share on other sites
AVIC-U310BT Posted January 25, 2010 Report Share Posted January 25, 2010 The only two things I can think of off-hand are bad wiring or a hardware problem. Once you've double-checked the wiring, bringing it back to the store for an exchange is the way I would go. Quote Link to post Share on other sites
