jreiter Posted December 10, 2006 Report Share Posted December 10, 2006 Is there a way to make the AVIC-D2 skip that initial warning screen you get when you first power on the unit? It's not a huge deal, but annoying to have to reach over and hit the 'okay' button every time I start up the car. I'm guessing there probably isn't an easy way to do it, since this is most likely a software issue. I have an Alpine nav unit in my other car with the same sort of warning screen and was never able to bypass that, either. One thing I've always liked about my Garmin Streetpilot III portable unit is that there is (believe it or not) an option in the settings to disable the boot-up warning screen. Handy. Quote Link to post Share on other sites
sportsfan21 Posted December 10, 2006 Report Share Posted December 10, 2006 Search is your friend. This has been discussed over and over again. No there is no way to disable the screen. Quote Link to post Share on other sites
GnatGoSplat Posted December 11, 2006 Report Share Posted December 11, 2006 Some people on the Acura forum managed to hack their factory nav to bypass the warning screen, but the Pioneer system has a different CPU and architecture so we can't hack ours the same way. It basically involved disassembling and reverse-engineering the code. I want to hack ours very badly, but the software image is compressed somehow. At least, when I try to disassemble it with a disassembler, the listings don't make sense. I got stuck there because I'm not smart enough to get past that point and I seem to be the only person interested in doing this. Quote Link to post Share on other sites
madmanfrommars Posted December 11, 2006 Report Share Posted December 11, 2006 I have the voice command kit on my n3, and the voice commands automatically activate so I just have to say "OK" when turning on the car. Quote Link to post Share on other sites
jefbarn Posted December 12, 2006 Report Share Posted December 12, 2006 ...I seem to be the only person interested in doing this. nope. The OS loader starts around 0x1000. I can disassemble there no problem. Another chunk starts at 0x1200. It's using the NEC RX OS. I'll attach some of the documentation I've found so far and the disassembler I'm using. I'm also stuck without a memory map of where the code is loading. There is a memory dump feature in the service menu, but I don't have enough time to search through it. Once we get a good memory map, we can start mapping the functions....shouldn't be too hard from there. Another interesting idea would be if we could get into the memory dump while the interface is running, then we could look for the location of the global that stores the flag. necdocs.zip Quote Link to post Share on other sites
GnatGoSplat Posted December 12, 2006 Report Share Posted December 12, 2006 Jefbarn, Good to see someone else working on this, sounds like you've found more info than I have! Looks like you found the same Nintendo Virtual Boy disassembler that I was using too. I recompiled it with VS.NET 2005 so it has the ability to disassemble larger chunks (or the whole file if you want) and also adds some V830 opcodes so there are fewer invalid opcodes. I've attached it in case it's useful. For some reason, when I start disassembly at 0x1000, there are "Invalid opcodes" at 0x1030. Is that in your listing too? V830_dis.zip Quote Link to post Share on other sites
jefbarn Posted December 12, 2006 Report Share Posted December 12, 2006 Thanks for the updated disassembler, it should help eventually. I'll try to take a look at the code, but I'm going to be pretty busy this week. Quote Link to post Share on other sites
jreiter Posted December 12, 2006 Author Report Share Posted December 12, 2006 Search is your friend. This has been discussed over and over again. I apologize. I am actually a big user of the search function (and have often told people the same thing), but for some reason I was unable to come up with anything useful. Sorry about that. -joe Quote Link to post Share on other sites
bushing Posted January 22, 2007 Report Share Posted January 22, 2007 ...I seem to be the only person interested in doing this. nope. The OS loader starts around 0x1000. I can disassemble there no problem. Another chunk starts at 0x1200. It's using the NEC RX OS. I'll attach some of the documentation I've found so far and the disassembler I'm using. Thanks for posting the instruction set documentation -- I'm going to try to write a V830 processor module plugin for IDA Pro, and will be happy to share my results. (There was talk on a thread on another board (http://cl.acurazine.com/forums/showthread.php?t=169301) that mentioned using IDA Pro, but as far as I can tell it was in error -- the latest version does NOT have support for this chip.) FWIW, the service manual for the D1 breaks the files out as follows: UC050BOT.USA: Bootloader UC050SYS.USA: System Software / OS UC050GPS.PRG: GPS firmware EU050APL.PRG: Application code (loaded into SDRAM) UC050DAT.USA: Language data Any one know where we can find that bootloader, and does anyone know where the nag message is stored? (as a bitmap, as text?) -b Quote Link to post Share on other sites
jreiter Posted January 22, 2007 Author Report Share Posted January 22, 2007 Thanks for looking into this, bushing. I'd definitely like to hear about your results if you can figure something out. Quote Link to post Share on other sites
bushing Posted January 23, 2007 Report Share Posted January 23, 2007 Nothing too crazy yet -- but I did find the text for the warning message in UC050DAT.USA. String 1424 (offset=4a88): 'CAUTION: This Navi product is intended solely as a driving aid. Review instruction manual and select route before driving. Navi is not a substitute for your attentiveness, judgment, and care while driving or moving your vehicle. Always observe safe driving rules and driving laws, and follow road signs even if they contradict Navi's instructions. By pressing OK key, you accept the license agreement in the instruction manual.' I'm attaching a parsed list of the strings from that file, and the simple C program I wrote to make it. Assuming we do eventually figure out what needs to be patched, what's the easiest way to test it? Please don't tell me we'll have to burn a new DL DVD-R each time! uc050dat-strings.zip Quote Link to post Share on other sites
GnatGoSplat Posted January 23, 2007 Report Share Posted January 23, 2007 Assuming we do eventually figure out what needs to be patched, what's the easiest way to test it? Please don't tell me we'll have to burn a new DL DVD-R each time! I think it's possible to slim down the map disc to fit a single layer disc by omitting some POI's and such. Then you can burn it to a DVD-RW. Quote Link to post Share on other sites
cntrylvr79 Posted January 23, 2007 Report Share Posted January 23, 2007 Does that mean we can edit the text at least? If so that could be kinda funny. Quote Link to post Share on other sites
jefbarn Posted January 23, 2007 Report Share Posted January 23, 2007 Does that mean we can edit the text at least? If so that could be kinda funny. Probably not until someone figures out the checksum. Quote Link to post Share on other sites
cntrylvr79 Posted January 23, 2007 Report Share Posted January 23, 2007 Ahh it was worth a shot. Quote Link to post Share on other sites
