Smac61 Posted May 2, 2010 Report Share Posted May 2, 2010 Just installed a new to me N2. Its working fairly well however the GPS over steers every corner and takes about 100 yards or so to snap back onto the street I'm on. Is this a common issue? Does it work out after it "learns" the vehicle, or is it just the way it is? Another question, I have a copy of the 90 maps, is there any risk using these on my unit? N2 - original software - bypassed - e brake wire grounded - vss and reverse lines hooked up - hide a way flat, properly oriented, and secured to floor under passenger seat with velcro. Thanks, Smac Quote Link to post Share on other sites
tunez Posted May 10, 2010 Report Share Posted May 10, 2010 I have had problems in the past taking a NAV out of one car and putting it into another but what I have found is that you need to clear everything out of its memory as far as the screen that has a picture of a car with green bars around it. I don't have one in front of me right now but it will clear speed pulses average speed and some other stuff, should be good to go after that. Quote Link to post Share on other sites
Smac61 Posted May 11, 2010 Author Report Share Posted May 11, 2010 I stumbled across that screen and did exactly that and its been good since. I guess that confirms what did it... Thanks, Sean Quote Link to post Share on other sites
tttomttt Posted May 11, 2010 Report Share Posted May 11, 2010 Could you elaborate on the car with green bars around it. Where did you find that screen? I find that my arrow sometimes does not face in the direction I am traveling. Quote Link to post Share on other sites
Smac61 Posted May 11, 2010 Author Report Share Posted May 11, 2010 Settings - Hardware info - 3D calibration Reset all the sensors. Good luck, Sean Quote Link to post Share on other sites
tttomttt Posted May 12, 2010 Report Share Posted May 12, 2010 Gave it a shot this afternoon I'll have to see if it works.Thanks for the tip. tommy t Quote Link to post Share on other sites
tttomttt Posted May 24, 2010 Report Share Posted May 24, 2010 Hey Guys, The reset seems to have worked. Thanks for the tip. Quote Link to post Share on other sites
