Jump to content
AVIC411.com
FX3.1 Complete Firmware Image
  • Replies 893
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
This is the latest and greatest. You will not see a 4.0 upgrade to the F series as it is discontinued and has reached it's end of life for Pioneer.   You will love the 3.1 upgrade.
Posted Images
Alright I'm downloading again on my desktop. I downloaded winrar as well. The containing folder has the winrar logo (3 books stacked) so I guess it Auto winrar'd it? Anyway do I just drag the containing folder to the sd card, or do I have to open the containing folder and drag a secondary folder to the sd card?
Link to post
Share on other sites
  • 4 weeks later...
http://avic411.com/index.php?/topic/27807-fx31-complete-firmware-image/?p=218239
Hey
I did everything as the link above said and i have problem with turning on my AVIC F500 BT
When it turns on (the pionieer start up screen) Its only on for about 3 seconds, then it turns off automatically...
Do you know any solution to the problem that i have?
Thanx alot.
Link to post
Okay so what I've done is simple, I took what I considered to be the basic mods that would be appealing to almost everyone, without drastically changing the look and feel of the system.
This download contains:
Windows CE firmware
X Series 3.0201 update
Complete TA 2009.6 Map Upgrade (USA & Canada)
No nag screens
POI Branding
Speed camera/red light mod
Software speed bypass
Download: <!-- m -->http://thepiratebay.org/torrent/5546342<!-- m -->
You need only a single SD card, at least 2gb in size. Copy the entire contents of the RAR file to the root of SD card.
1. Insert SD card into AVIC and turn it on.
2. When the pioneer logo comes up, press and hold the menu, map, eject and the reset buttons at the same time. When your screen goes completely blank, let go of the reset button but continue to hold menu, map, and eject buttons. This will bring you to a blue screen, telling you to reset the unit (ignore this), you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
3. Select Wince Upgrade
4. Select Update SD Format
5. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in.
6. You should be greeted with testmode (It will look very similar to normal windows). Open Explorer and copy the contents of the "My Flash Drive" Folder from the SD card to the "My Flash Drive" that is located on the unit. Overwrite everything. (It will the copying will take 140min but will only take about 20)
7. Press and hold reset for 5 seconds.
8. Select your language and voice options.
Tested on AVIC-f90bt. 05/08/10
FAQ:
How do I extract this rar thing?
<!-- m -->http://www.rarlabs.com/download.htm<!-- m -->
In test mode it says there isn't enough space to copy the files, how come?
This means you didn't select the SD format option in step 4, select everything on the "flash disk" and delete it, then copy your new files over
How do I know if my download completed properly?
The reason I stored everything in the RAR is because Winrar checks to make sure the download is perfect, if it didn't download properly, you would receive an error when extracting.
My unit just keeps booting to test mode?
Take your SD card out and then reset.
Why did my unit take so long to start the first 2 times?
That is normal, all the software is adapting to your AVIC
this does not work on x910bt
Link to post
  • 1 month later...
  • 3 weeks later...
I'm also looking for the FX31 file. Does not seem to be available anymore. Can anyone share again?
I have the comple FX31.rar on my server again. Its 1.71gb in size, and kills my badwidth when its shared and downloaded. If you would like to donate a few bucks to help with the cost of hosting a large download, I would greatly appreciate it.
Donations via Paypal: YaTwice@cox.net
Download Link: http://www.deserttuners.com/FX31.rar
If a mod or admin would like to add the links above to the main post, they are more than welcome to do so.
Link to post
  • 3 weeks later...
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
