shaz408 Posted May 23, 2010 Report Share Posted May 23, 2010 Unit Description Unit: F700BT US Version (using in UK) FW: X Series 3.0201 update, Using this Thread (viewtopic.php?f=34&t=32351) I have upgraded from version 2 to 302.01 directly using the above thread instruction and image files. Problem Description Every thing is working fine. I have changed the maps of US to UK one and the navi is working good. MY biggest issue is this the unit can not detect SD card while in normal state. i.e playing My unit can detect the SD card if used in test mode, and it can go into test mode. But when playing normal no matter what it does not dtect my SD cards. I have formatted SD card with Fat 32 also i have been through different threads explaining what types of files F700 can play. I am only putting mp3 and avi files. But the unit is not detecting the card and it SD card icon is dead in AV sources. PLEASE HELP !!!!!! Regards Shaz Quote Link to post Share on other sites
shaz408 Posted May 25, 2010 Author Report Share Posted May 25, 2010 HI GUYS ANY HELP.... ANY COMMENTS ...... Quote Link to post Share on other sites
another gsxr 1k Posted May 25, 2010 Report Share Posted May 25, 2010 How big is the card you are using? I can't remember exactly, but I think the SD card reader is size limited. You might want to try a different card too. Quote Link to post Share on other sites
shaz408 Posted May 25, 2010 Author Report Share Posted May 25, 2010 How big is the card you are using? I can't remember exactly, but I think the SD card reader is size limited. You might want to try a different card too. Thanks for your reply. I am using 2 GB capacity SD card. I will try 1 GB one to see if it works Regards Shaz Quote Link to post Share on other sites
shaz408 Posted May 26, 2010 Author Report Share Posted May 26, 2010 I have tried 1GB cared but it is not detected. Unit still can detect SD card in test mode Regards Shaz Quote Link to post Share on other sites
LittleSteven Posted May 29, 2010 Report Share Posted May 29, 2010 I have found an odd behaviour which MAY be your prob as well. I found that my F500 would not see and SD if I inserted it BEFORE switching it on. Obviously, all I do is pop in the SD just before hitting AV. It drove me mad at first and I went on a crusade to find out what the problem. Hopefully, yours is same reason. Quote Link to post Share on other sites
shaz408 Posted June 2, 2010 Author Report Share Posted June 2, 2010 Thanks for the tip. I will try today once get at home. Will update the thread with result. Regards Shaz Quote Link to post Share on other sites
