grendel Posted March 6, 2011 Report Share Posted March 6, 2011 If you're still doing the pins, I am interested in one of the wired ones. I need to keep my mute wire. Quote Link to post Share on other sites
nrightinhead Posted April 24, 2011 Report Share Posted April 24, 2011 I ordered some of these pins and could not get them into the connector. Does anyone have the secret to this. Quote Link to post Share on other sites
Alexei Navalny Posted April 24, 2011 Report Share Posted April 24, 2011 I ordered some of these pins and could not get them into the connector. Does anyone have the secret to this. Do you have a Z110/120 or a Z130? Just wondering if you got the correct pins. Since the harness is different on the Z130, I wouln't asssume the pins are the same size. If they are the correct ones, you might try rotating 90 degrees and try again. Keep rotating until you do the full 360. Quote Link to post Share on other sites
quarky42 Posted April 26, 2011 Author Report Share Posted April 26, 2011 Are you sure you pulled the cap on the side up far enough (without removing it)? The pins will not go into the connector unless the locking cap is PARTIALLY removed... not pulled out all the way, just lifted to allow the pin to slide into place. Quote Link to post Share on other sites
Mike900 Posted April 27, 2011 Report Share Posted April 27, 2011 I know you guys are probably bored to death with this topic, so I appologize in advance! lol. But, the Molex Part# 08-70-1040 Pin Connector, are they availabe at radioshack? I've got a Z120bt in an 03 silverado with Onstar (wich you dont need the mute wire for). I destroyed the the pin trying to get it out and am now in search of another pin without buying a new harness. Quote Link to post Share on other sites
quarky42 Posted April 27, 2011 Author Report Share Posted April 27, 2011 No, I don't think so. I linked the cheapest place I could find with the smallest minimum order in the original post. Quote Link to post Share on other sites
Mike900 Posted April 27, 2011 Report Share Posted April 27, 2011 Ok, thanks. Since you seem pretty knowledgable in this area, i have 1 more question. Would it be possible to take a lead off of each side of the actual PB switch, add a diode and splce them together with the Green PB wire? Quote Link to post Share on other sites
Matt L Posted June 25, 2011 Report Share Posted June 25, 2011 Has anyone confirmed if this works for the 130? Like a dumbass, I broke the wire for the mute and I'm most likely not going to be able to get it out. I would prefer to not buy a whole new harness if I don't have to. Quote Link to post Share on other sites
Alexei Navalny Posted June 25, 2011 Report Share Posted June 25, 2011 Has anyone confirmed if this works for the 130? Like a dumbass, I broke the wire for the mute and I'm most likely not going to be able to get it out. I would prefer to not buy a whole new harness if I don't have to. You still should be able to extract the metal part from the cable connector using the correct technique and a small needle-nose pliers. Then you can just solder the wire back on and insert it into the new position. I think you can even slice the plastic open (with a razor knife) if necesary to remove it. Don't know if the diode thing will work on a Z130 (or Z120), If it did, we wouldn't be messing with the harness in the 1st place. Quote Link to post Share on other sites
Matt L Posted June 26, 2011 Report Share Posted June 26, 2011 You still should be able to extract the metal part from the cable connector using the correct technique and a small needle-nose pliers. Then you can just solder the wire back on and insert it into the new position. I think you can even slice the plastic open (with a razor knife) if necesary to remove it. Don't know if the diode thing will work on a Z130 (or Z120), If it did, we wouldn't be messing with the harness in the 1st place. I have a pin extractor at work that we use for DB9 and DB25 connectors. Any idea if that would work to release the pin from its holding place? Kinda looks like this: pin extractor Quote Link to post Share on other sites
Alexei Navalny Posted June 26, 2011 Report Share Posted June 26, 2011 I have a pin extractor at work that we use for DB9 and DB25 connectors. Any idea if that would work to release the pin from its holding place? Kinda looks like this: pin extractor I think the DB9/25 pins are larger. I had one too and it didn't help on my Z110. I ended up slicing open the nylon connector because I couldn't get mine to release. Quote Link to post Share on other sites
tcfennell Posted August 8, 2011 Report Share Posted August 8, 2011 If you are looking to order these pins the following link has them at a goog price and small quanties. http://parts.digikey.com/1/parts/270905-conn-term-female-22-28awg-crimp-08-70-1040.html Quote Link to post Share on other sites
ascribner Posted April 8, 2012 Report Share Posted April 8, 2012 Looks like the minimum order from jameco is 30 now. Anyone have a couple laying around that they are willing to sell? Quote Link to post Share on other sites
codec Posted August 14, 2012 Report Share Posted August 14, 2012 I'm in the same situation with my z140. I ripped the mute wire out of the pin by mistake. i was able to get the rest of it out by slicing the plastic with a knife and working it out from there, but it's too screwed up to try to solder back on the wire. Will it mess up the unit if i just plug the rca back in until the new pins arrive in the mail? Quote Link to post Share on other sites
pionara Posted September 20, 2012 Report Share Posted September 20, 2012 yes - I found that the power cable pins from old 3.5" floppy drive off of an old dead computer power supply works great and fits in the a/v harness pin holes perfectly you dont have to tear up the connector the trick is htere is a lift-up "bar" tab across the side of the connector. use a small screwdriver/pry tool to unlock/lift-up the bar at each end, and it will allow the pins to just slide out. I fiddled with it for a while thinking they were back/front locking pins, til i realized there is that snap in bar on the side holding them in. Quote Link to post Share on other sites
