Jump to content
New Maps and POIs SD card available from Poineer
  • Please log in to reply
87 replies to this topic
#76 H2k
H2k
  • Members
  • 19 posts
Posted 22 February 2011 - 09:35 PM
Hopefully we can find someone willing to do it. Maybe send one of us it burned to a disc, and we can put it on an SD card ourselves, then send the disc to the next person in this thread having a problem. I wouldn't mind doing that.
In the meantime, could one of you who have a properly working update give me the UPC that's on the box?
The UPC on my defective update is 884938121323. Also written on the box is CZH8641-A. I am trying to see if there is a way of distinguishing which of these are bad without opening them.
That's not a bad idea, it certainly would be easier than uploading. I wouldn't mind doing that either.
#77 shawnmos
shawnmos
    Member
  • Members
  • 99 posts
Posted 25 February 2011 - 07:43 PM
That is, if someone is willing to help us all out.
#78 shawnmos
shawnmos
    Member
  • Members
  • 99 posts
Posted 12 March 2011 - 03:31 AM
Ok, so I was finally able to get Pioneer to replace the map update with a new one. If anyone wants the update let me know.
#79 shawnmos
shawnmos
    Member
  • Members
  • 99 posts
Posted 12 March 2011 - 05:34 AM
I am attaching only the files which have been changed in this update. Most of the files are unchanged. THIS IS ONLY FOR PEOPLE ALREADY USING VERSION 2.0000!!!
Make sure you make a backup of the contents of the original SD card first, then unzip the files I've attached and overwrite the older files on the SD card.
When you put the new SD card in it should ask if you would like it update. It should not ask you for the activation key this time.
After updating you should now be able to use the additional POIs from Pioneer's site and use the key that came with your update to enable them.
Please note, I have no way of knowing if this will work, so try this at your own risk.
#80 KA4993
KA4993
  • Members
  • 6 posts
Posted 12 March 2011 - 12:04 PM
I'm somewhat confused. I just checked and I'm still running the older version 1.0003 on my U310BT. I have no POI's. In order to upgrade to a new version with new maps and POI's, do I need to spend $100+ for a Pioneer SD card update?
#81 shawnmos
shawnmos
    Member
  • Members
  • 99 posts
Posted 12 March 2011 - 01:49 PM
Yes. The firmware update requires a unique code from Pioneer.
#82 manzter
manzter
  • Members
  • 2 posts
Posted 14 March 2011 - 04:21 AM
IT WORKED!!! After months of calling and sending emails to Pioneers Tech Support and getting nowhere, you my friend saved the day. Thank You Thank You Thank You!!! :)
#83 shawnmos
shawnmos
    Member
  • Members
  • 99 posts
Posted 14 March 2011 - 01:28 PM
YAY! I'm glad I could help!
#84 H2k
H2k
  • Members
  • 19 posts
Posted 15 March 2011 - 09:23 PM
Oh my.. it works! You have really saved the day. THANK YOU SO MUCH!! :mrgreen:
Now I don't have to use my phone to look up addresses anymore, and most importantly... deal with Pioneer's run around tech support. :)
#85 LewnWorx
LewnWorx
  • Members
  • 3 posts
Posted 27 April 2011 - 10:41 PM
Well I ordered the update.
What a PITA. The multi step clear as mud directions sucked.
Were it not for the posts in this thread I'd have had considerably more problems than I had.
FWIW, the currently shipping SD card IS correct in terms of it's version data. The business of having to manually download the POI stuff and put that on a separate card was an epic fail on PIoneer's part.
As for the POI data itself?
Nearly useless.
Search for fast food near me, and expect to see McDonalds, Wendy's, Subway etc, and get one off local places I've never heard of and I've lived here 20 years.
So ok what the hell, I'll search for McDonalds by name as per the manual. It finds "John McDonald Water Purfication Accessories" or something like that 465 miles away.
Stuff that still sucks:
Can't pause the iPod without multiple "center" button pushes on the joystick and selecting the "function" menu, which is practially impossible when driving as every time you hit a bump in the road you can't get the center push to be read correctly. Epic fail.
Seeing the list of directions when driving still requires way too damn much ui navigation. They could learn a thing or two from Garmin.
Gas milage entry: Obtuse at best. Every time you use it it gives you a dialog that no data has been entered, do you wish to continue? What UI moron came up with that? Of course there's no data entered, so why bring up a dialog box.
Documentation: ├╝ber epic fail. Upgrade process was incredibly unclear, and required garnering information from the upgrade kit, the PDF manual, and two separate trips to the website. My "favorite" insult of the process was the bluetooth upgrade. The documentation tells you to consult Pioneer's website to check your phone to see if you need to install the upgrade, and the "link" they gave you was to "http://www.pioneer.com". How about a link to the page in question? After 10 minutes of searching the site (no luck) I rolled the dice and just did the upgrade anyway, figuring since I have an iPhone 4, it should be current. I was lucky.
So in summary:
Pioneer's support sucks as bad now as it did when I was an Elite dealer 20+ years ago. They haven't learned anything.
Oh well, at least I now have maps that are only 6 months out of date.
#86 Schumi
Schumi
  • Members
  • 9 posts
Posted 04 May 2011 - 09:26 PM
Please, tell me, how can i update my device to version 2.0000 ?
P.S. my unit is avic f310bt.
#87 State.of.mind
State.of.mind
  • Members
  • 2 posts
Posted 01 July 2011 - 05:32 PM
Someone should upload the files to megaupload..
#88 ScottG
ScottG
  • Members
  • 1 posts
Posted 07 October 2011 - 06:54 PM
Thanks Shawnmos
Your file did the trick. I recently bought the CNSD-130FM 2010 upgrade from Crutchfileds. Its on sale for $79 since the new 2011 update was just made available. I had the same upgrade problem as others, ending up with version 2.0000. Used your files to overwrite the originals files and after the quick upgrade I was able to also do the POI upgrade.
Why would Pioneer put out an upgrade that you pay $120 and you have to go to a web site to download the biggest part of the update? Also knowing the problem with version issues and not posting a correction on the upgrade website. I know stupid questions.
Anyway thanks for taking the time to post the correction for us!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
