RonS Posted April 6, 2011 Report Share Posted April 6, 2011 Format SD (Right click sd card under my computer and format) format in FAT32 DEFAULT ALLOCATION SIZE!!!!!! The card needs to be 4gb or larger to complete all steps! Now Copy the folder c:/update/AVICZ110 to the root of the SD card. Lets say your sd card is j: drive. You will now have one folder on the j: drive. j:/AVICZ110 (Plus all the contents of this folder.) Now insert the SD to your Z110BT and it should start updating automatically. Directly from john_tsouris post on 27 Feb 2011 @ 11:01 AM OK, you said your SD had 1 file in the previous post. I assume ShortFuse's patched files are already in the correct directories in your C:\update folder? Quote Link to post Share on other sites
Don Omar Posted April 15, 2011 Report Share Posted April 15, 2011 Wow just like the other users stated. Follow the instructions to the letter and you will be in good shape. I had a couple of problems the first time because I didn't copy over the .dll and it dldnt let me enter in the letters as password. but once I copied and replaced the files for the first part of the update everything else worked perfectly without a hitch. this is awesome. Thanks to everybody involved for making this happen. Quote Link to post Share on other sites
garyw Posted April 30, 2011 Report Share Posted April 30, 2011 I have been doing this upload today and I am in the middle of the first sd card OS update and my system is frozen at 39 per cent saying wrong sd card inserted. Any helpfull ideas? Quote Link to post Share on other sites
garyw Posted April 30, 2011 Report Share Posted April 30, 2011 I have been doing this upload today and I am in the middle of the first sd card OS update and my system is frozen at 39 per cent saying wrong sd card inserted. Any helpfull ideas? So my solution was not using such a massive sd card (32G) but using a 8G and the problem was solved. Quote Link to post Share on other sites
RonS Posted April 30, 2011 Report Share Posted April 30, 2011 So my solution was not using such a massive sd card (32G) but using a 8G and the problem was solved. Thanks for posting your solution. You'd be suprised how many people have similar problems. Hardly any ever say what they did to get by it. Those who never had any issues, have no clue on how to proceed except "try again. Try a different SD...". We kind of get tired of repeating the same advice. BTW, the back of the manual says 16GB SD max. So odds are that you are out-of-luck using that 32 gigger for MP3s or vids. But give it a try, you might get lucky. Quote Link to post Share on other sites
RonS Posted April 30, 2011 Report Share Posted April 30, 2011 I studdered. Duplicate. Deleted. Quote Link to post Share on other sites
luisenonine Posted May 4, 2011 Report Share Posted May 4, 2011 each time i try the utorrent and drop the cdsd-110fm file it tells me invalid file. what am i doing wrong Quote Link to post Share on other sites
djneil29 Posted May 5, 2011 Report Share Posted May 5, 2011 hi i'm trying to mod my z110bt bt for some reason it only work on the first step, after that it's not working for the next 2 file CNSD-110FM 1&2, its not loading automatically, i try like 4times not working i want to know what i did wrong. Quote Link to post Share on other sites
RonS Posted May 5, 2011 Report Share Posted May 5, 2011 i want to know what i did wrong. Are you kidding? With no information other than "I try like 4times not working", we're supposed to figure out what you did wrong? You need to go back and read - 1st the instructions, then all the posts. The instructions are correct, so you did something wrong or you mis-interpretted them. If you have a specific question about any step, ask. And once you figure out your problem, post the solution so others can learn. Quote Link to post Share on other sites
NavyCricket Posted May 10, 2011 Report Share Posted May 10, 2011 Is there any reason this would prevent upgrading to Z130BT when the new firmware is released? I'm not sure if I should give this a go now and legitimately update later, or just wait for the update and skip this update. Quote Link to post Share on other sites
JBY Posted May 11, 2011 Report Share Posted May 11, 2011 Worked great. No issues whatsoever upgrading my 110 to the 120 update. Thanks so much! Quote Link to post Share on other sites
mwalsh13 Posted May 14, 2011 Report Share Posted May 14, 2011 So let me ask the real ignorant question here (and by no means with any intent to insult the contributors to this post). i followed Shortfuse's instructions and succeeded in all updates. now sitting on version 2.0000 and 3.11 for bluetooth; but really, is all i got out of this upgrade a flashy new UI for the A/V features?? still cant jump to the artists/albums/etc. using the index... says "not found" when i select "F" to jump to foo fighters, for example. maybe it's an ipod issue? everything else looks the exact same; what is ECO? that seems new; not sure if the handsfree/voice-guided features for anything has improved yet. it used to take 10 minutes for the engine to "start up" and never understood what i said; oh, and the stock microphone quality is still bullsh... people hate speaking to me via BT when im on the road. thank goodness i paid premium for that function :/ sorry for the frustration, but what really did i get out of this? i ask for sanity, and any suggestions/advice regarding my other issues with the AVIC would be respectfully received. educate me! also, what are the references above to 2.03? did i miss something? is there another upgrade worth installing? what is the forecast for avic o/s v3?? THANKS Quote Link to post Share on other sites
James Reid Posted May 16, 2011 Report Share Posted May 16, 2011 Has anyone got this to work with the EU version ? AVIC F10BT? Quote Link to post Share on other sites
xaxxon Posted May 21, 2011 Report Share Posted May 21, 2011 Just successfully downloaded the torrent at ~1MB(yte)/s -- it's a biggie. Quote Link to post Share on other sites
Fat Tony Posted May 22, 2011 Report Share Posted May 22, 2011 Need help, please. I am stuck. I downloaded the first part and replaced the files just fine. Installed those without a problem. I downloaded the torrent, unzipped it and installed it to the SD card. When I install the SD card it will NOT prompt me for the password. Yet I did the BT update just to see if it would work and it did (both of them). Now I am trying to get the unit to ask for the password and it wont. Please help? Quote Link to post Share on other sites
Join the conversation
