parruso Posted September 21, 2010 Report Share Posted September 21, 2010 Why are some Schemes make 3D buildings from being transparent? All RealView and similar buildings do not display correctly, but others, such as Red or Blue Pioneer if they do. You can see the building in 3D, texture, etc, but a bit transparent Do you know which is the parameter that governs the transparency? Is it a parameter of the Scheme or the Data.zip? Thank you. Quote Link to post Share on other sites
parruso Posted September 25, 2010 Author Report Share Posted September 25, 2010 Somebody? Quote Link to post Share on other sites
N-S-E-W Posted September 26, 2010 Report Share Posted September 26, 2010 It's in the schemes. If you have a scheme that the buildings are rendered to your liking, create a txt file copying the [clip_planes] section from the scheme. Rename the txt file to clip_planes.ini and copy it to your data.zip in the common folder. You may also search in the mods forum for additional info regarding clip_planes Quote Link to post Share on other sites
