Jump to content
AVIC411.com
Diaftia's Hybrid mods V3.6 - UPDATED: 04/19/11 - Now with auto installer.
Hey Guys!. Quick question.
Oh and Congrats diaftia on the new addition to your family!.
I downloaded the NavTeq maps and noticed Diaftia's mod includes a Map changer. Where does the NT Map need to be placed so that the Map changer can successfully toggle one or the other?
Right now I just copied the NT map to my MAPS folder and it sorta took over the TeleAtlas maps Job. LOL. Even though the TA Map is in the same folder the Avic now reports under "MAPS" as using the 2010 NavTeq Map.
Link to post
Share on other sites
  • Replies 856
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Put TA maps in CONTENT\map and NT maps in CONTENT\map_nt, then use the map changer!
Hmmm well that didn't work. I moved the NT map from the Content\Maps folder and put it in the Content\map_nt. Restarted and the only map avail under the changer is the TA.
I copied the NT map back to Content\Map and Im now using the Navteq map again. Strange that the mapchanger won't see it.
Link to post
I have been trying to get this to take on my system and it just won't. I put the SD card in and boot the system up, but it goes black after the splash screen and does nothing. Is there a way to force the new software onto the system? I have a x910bt
Link to post
Try putting the maps_nt folder into apl2/Igo/content and see if that works.
Link to post
make sure your SD is freshly formatted, I have seen that happen with a "dirty" card.
At the root of your SD you should have 2 folders,
Testmode
My Flash Disk
Anymore or any less can cause you problems. When you are having problems keep it simple.
Link to post
You know that there are many files for the maps right? I just noticed that on a couple of different posts you mentioned putting the NT map into a folder.
Here is a partial diagram of how the SD Card containing the update is setup, with a subset of the maps that I need.
I hope it helps.
+---My Flash Disk
| +---APL
| \---APL2
| \---iGo
| +---3DCars
| +---CONTENT
| | +---map
| | | Canada.fbl
| | | USA_District_Of_Columbia.fbl
| | | USA_Florida.fbl
| | | USA_Georgia.fbl
| | | USA_Maryland.fbl
| | | USA_Michigan.fbl
| | | USA_New_York.fbl
| | | USA_North_Carolina.fbl
| | | USA_Pennsylvania.fbl
| | | USA_South_Carolina.fbl
| | | USA_Vermont.fbl
| | | USA_Virginia.fbl
| | | USA_Waters.fbl
| | | USA_West_Virginia.fbl
| | +---map_nt
| | | Canada83_NT_2010.Q4_110421.fbl
| | | North_America_NT_Easy_2010.Q4_110426.hnr
| | | North_America_NT_Fast_2010.Q4_110426.hnr
| | | North_America_NT_Short_2010.Q4_110426.hnr
| | | USA_District_of_Columbia83_NT_2010.Q4_110415.fbl
| | | USA_Florida83_NT_2010.Q4_110420.fbl
| | | USA_Georgia83_NT_2010.Q4_110415.fbl
| | | USA_Maryland83_NT_2010.Q4_110415.fbl
| | | USA_Michigan83_NT_2010.Q4_110415.fbl
| | | USA_New_York83_NT_2010.Q4_110415.fbl
| | | USA_North_Carolina83_NT_2010.Q4_110415.fbl
| | | USA_Pennsylvania83_NT_2010.Q4_110415.fbl
| | | USA_South_Carolina83_NT_2010.Q4_110415.fbl
| | +---Poi
| | | \---R3-USA-TA-2011-Q1
| | | \---Poi
| | \---SCHEME
| +---Extension
| \---GFX
\---Testmode
\---Utils
Link to post
THanks Fusion. I"ll have another look at that!. I only had just the Florida map in there and it seemed to work so I assumed I didn't need any of the other files such as the
Link to post
I'm trying to install the Daftia 3.6 mod on my avic f900. i donwloaded the file, extracted it, put file on sd card. then i go to car, insert card, turn car/avic on, and nothing happens... no screen to pick version. how do i get it to auto install????
or how do i install manually? i can browse the sd card and move whatever file i need to, but dont know what needs to be copied and pasted to where. any help is much appreciated.
(f900bt with hacked 3.0 installed, software bypass, no nag screens. using a mac computer incase that matters)
Link to post
When I try to install this it tells me I am 16mb short on my Flash Disk and need to delete some files.
I backed them up already but which are safe to delete?
I deleted a few files not in a folder but when I go to install it tells me it cannot create the directory Users/Go or something along those lines?
Any ideas?
Cheers
Link to post
Figured it out...deleted the Hawaii POI and Maps and got it installed.
Once it is done installing however the progress box went green and just sat there so I restarted and all seems well
Cheers man, like the new music layout too!
Now I just wish the AVIC would shuffle music better as every music DVD I use ALWAYS ends up playing the same pack of 5 or so tunes in the same order every hour...irritating.
Link to post
Hi Diaftia..
I have attached the EZRider file from the new 4.001000 firmware posted on the EU pioneer site... I was just wondering if you could modify it with your high elevation mod and the ability to run any maps like you did with the older one you posted.
It is based of IGo Version 8.3.2.188283
ezrider.zip
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
