Mephs2ph Posted February 27, 2011 Report Share Posted February 27, 2011 Hey all, Thought I would turn to the collective wisdom out there and see if anyone knows what to do here. I have been running an x910bt with Sirius for a year now, and everything has worked fine (well, as fine as the buggy 910 seems to be, anyways). My Sirius connection died a week or two ago, and I thought it was just my subscription. But, having looked, my subscription is fine, but the radio seems frozen on the one channel and will not do anything. I can't change to a different preset, I can't directly go to a different channel, including 000, and it never does aything. Doesn't appear to be tryng to find a signal, either. I have tried resetting the radio, I have pulled the fuse for a number of minutes, but when the radio restarts Sirius is still stuck on the same channel with no aduio or anything. Thoughts or ideas? I really don't want to be pulling apart my dash in the middle of winter to start unplugging stuff... Thanks in advance. Quote Link to post Share on other sites
rgarjr Posted February 28, 2011 Report Share Posted February 28, 2011 Maybe Sirius de-activated the tuner, I dunno. Quote Link to post Share on other sites
JasonH Posted February 28, 2011 Report Share Posted February 28, 2011 The sirus/xm tuners are wired to constant power. Pulling the radio fuse probably won't do it. If access to the tuner is difficult, try disconnecting the battery. If it still doesn't work, the tuner probably died. Quote Link to post Share on other sites
seeburg200 Posted April 22, 2011 Report Share Posted April 22, 2011 I know the original post was a couple of months ago, but I wanted to say thanks to the guy who said to disconnect that battery. That worked for me. I searched for hours on google trying to find a solution to my problem. Typeing everything I could think of. I have a Pioneer AVIC-F900BT that was stuck on one channel and had no sound. I too thought maybe I forgot to pay my bill, but that wasn't the problem. But everyone wants to suggest that first. Then they say to replace it or repair it. I even talked to someone about just getting a new one. But I have all the Options, such as the camera and bluetooth. It would have been expensive to change radios, and I like this one when it works. The installer didn't even want to touch my car, because he never even seen a smart car before. So off to the Internet I went. Searching, and searching. And then I came across this post. I found other sites of people with the same problem, but know one ever comes back and states if the suggestion works. Not even on this sight, so I wanted to make sure people knew. So off to fix it I went. I didn't even know where my battery was, so I had to do a little research. The battery was under the passenger Floorboard. Who Knew? And after 5 minutes, I plugged it in and as I said it worked. Then I told myself, I would get back on and post this. But then I had problems with this site. I was trying to use my computer at work, but it wouldn't access this site very well, on version of internet explorer or a firewall problem wouldn't show the graphic to type the password. Then I type things wrong and I could establish account. I hate those pictures that I have to type the text. I always get the 1IL mixed up and It usually take me like 10 times to get it right. Did I say I hate them. So I almost gave up, but this sight saved me alot of money so I thought it was worth another try. I hope this helps someone as it has helped me. Quote Link to post Share on other sites
