Alexei Navalny Posted October 17, 2011 Report Share Posted October 17, 2011 Hi All, Looks like a fairly simple bypass. Call me stupid, but can you tell me if I have to buy each wire adaptor? Or does it come with the unit itself? Secondly, I had an AVIC Z-2 that was bypassed. My truck was broken into and the jerk stole the unit. Can I reuse the adapters? Or will I need new ones for the Z130BT? The HU comes with its necessary wiring harnesses that plug in to the back of the unit. These are model specific and are different than the Z2. An "adapter" would be used to interface with your vehicle's factory radio harness. The Pioneer harness would connect to this, rather than cutting and splicing your factory wiring. If you had (and still have - after the jerk) an adapter for your vehicle, you will need to cut/splice the new HU harness to the adapter wires. You'll still need to connect things like VSS, PB, B/U, ILL that may not be part of the factory radio harness. Quote Link to post Share on other sites
rrolff Posted October 17, 2011 Report Share Posted October 17, 2011 Does anyone have a picture of the connector you move? I broke mine, and couldn't pull that one out - so I need a new pin. While I have a million different pins at work - I need to know what it looks like to grab a smattering of em... TIA... Quote Link to post Share on other sites
kyzmyss Posted October 19, 2011 Report Share Posted October 19, 2011 The HU comes with its necessary wiring harnesses that plug in to the back of the unit. These are model specific and are different than the Z2. An "adapter" would be used to interface with your vehicle's factory radio harness. The Pioneer harness would connect to this, rather than cutting and splicing your factory wiring. If you had (and still have - after the jerk) an adapter for your vehicle, you will need to cut/splice the new HU harness to the adapter wires. You'll still need to connect things like VSS, PB, B/U, ILL that may not be part of the factory radio harness. Thanks for the help! This clarifies it quite simply. Quote Link to post Share on other sites
King_corral Posted October 24, 2011 Report Share Posted October 24, 2011 Is this something I should disconnect the battery for? Or is the car of just as simple? Quote Link to post Share on other sites
rrolff Posted October 31, 2011 Report Share Posted October 31, 2011 Just an FYI - the pin is really a bitch to move... I broke it in the process of moving it (thankfully a local EBayer sells the harness for $40). Called a local car stereo shop, best $10 I've spent they did it in like 60 seconds... Quote Link to post Share on other sites
King_corral Posted November 2, 2011 Report Share Posted November 2, 2011 I got the z130bt and i put the four wires together with a butt connector still I get that message its detected parking brake is yada yada what do I do!? Plus some of my radio stations don't work... Quote Link to post Share on other sites
bones302 Posted January 30, 2012 Report Share Posted January 30, 2012 moved. Quote Link to post Share on other sites
kyzmyss Posted January 30, 2012 Report Share Posted January 30, 2012 Ok...call me stupid...After I connect the yellow mute wire, the parking brake wire, and the ground together, do they still need to be grounded to somewhere metal on the truck? Or by putting them together, and attaching a connector to it, that suffices for it being "grounded"? Quote Link to post Share on other sites
skeelo58 Posted January 31, 2012 Report Share Posted January 31, 2012 ^^^^^^^^ You connect all 3 of those wires together, and it gets connected to the black ground wire of the vehicle. So 4 wires are involved. The 3 from the unit, and 1 from the vehicle. Quote Link to post Share on other sites
kyzmyss Posted January 31, 2012 Report Share Posted January 31, 2012 Makes perfect sense...Thus the connector that has an open end on it (in the video..)... Thanks! Quote Link to post Share on other sites
Duramax21 Posted February 26, 2012 Report Share Posted February 26, 2012 i have an 08 chevy silverado 2500 Duramax and want to know if theres anything special i need to do when doing the bypass because of on star or anything. i already had the HU installed but they wouldnt bypass for me... and my pioneer date is april 2011 i think wanted to know if they made it unable to do the bypass???? i read something on youtube about it let me know thanks Quote Link to post Share on other sites
Duramax21 Posted February 27, 2012 Report Share Posted February 27, 2012 need anyones input on this gotta get in done tomorrow in hurry thanks Quote Link to post Share on other sites
Alexei Navalny Posted February 27, 2012 Report Share Posted February 27, 2012 i have an 08 chevy silverado 2500 Duramax and want to know if theres anything special i need to do when doing the bypass because of on star or anything. i already had the HU installed but they wouldnt bypass for me... and my pioneer date is april 2011 i think wanted to know if they made it unable to do the bypass???? i read something on youtube about it let me know thanks OnStar has nothing to do with the bypass - except that the Mute wire, which is normally moved to do the bypass, might already be used by OnStar. That would be a problem - only because you need some compatible wire to insert into the "bypass" position in the harness. The Mute wire is the common choice - only because it is normally not used. You'll need another wire to insert instead. Sorry, I can't help with Onstar, never touched one. Quote Link to post Share on other sites
Duramax21 Posted February 28, 2012 Report Share Posted February 28, 2012 well i had the audio shop put everything in and they didnt use the mute wire and i did the bypass and it works hope everything else works but i dont use onstar let me know if anyone else has done one with on star and thanks for the info and help RonS Quote Link to post Share on other sites
BootyHunter57 Posted March 12, 2012 Report Share Posted March 12, 2012 will this work on an avic z140? Quote Link to post Share on other sites
