verifying vss is working
Just installed the 920BT in a 2011 F250. Everything seems to work great.(including mod)
I Connected the VSS to the Black and Grey wire in the radio harness(pin #4). My question is: how do I know that it is corrrect?
Also, do I need to hook up the reverse gear wire if I don't have a rear view camera?
Thanks for the help
Look under Navi Settings -> 3D Status
No, you don't need reverse.
Calibrated speed should match speedometer?
Not necessarily. You have to keep in mind that your speedometer is not 100% accurate. There are factors (including tire size variance) that determine what your speedometer thinks you are traveling vs what you actually are. Typically GPS is a more accurate reading.
  • 2 years later...
  • 4 weeks later...
  • 2 months later...
  • 2 weeks later...
Get the plug and play harness from Enfig.com . They are very knowledgeable and you don't have to hack up your cars harness. I have a Audi and found it ridiculous to have to search for a random wire behind my fuse panel for a vss wire. Crutchfield should have it together enough to supply people with the correct harnesses. Christian from Enfig will supply you with the correct harness.
